I bought a 5.25 inch Pioneer BDR-212UBK internal drive NOT realizing my PC doesn't have space for an Optical drive.
I can get either an ASUS SBW-06D2X OR an ASUS SBC-06D2X but I have to act quick to cancel the Pioneer, which is an online purchase.
HELP!
EDIT: I may be able to return the Pioneer at the dealer locally if it is too late to cancel the order.
Need to know which drives are OK for 4k ripping? TIME SENSITIVE!
urbanracer34
Re: Need to know which drives are OK for 4k ripping? TIME SENSITIVE!
Do not get either of those ASUS's. The Pioneer drive should be UHD rip capable. You could get an external enclosure for it or a SATA to USB powered adapter. Otherwise, look here: viewtopic.php?f=16&t=19634urbanracer34 wrote: ↑Sun Oct 30, 2022 10:34 pmI bought a 5.25 inch Pioneer BDR-212UBK internal drive NOT realizing my PC doesn't have space for an Optical drive.
HELP!
urbanracer34
OK. No ASUS drives. Would this external enclosure work? https://www.memoryexpress.com/Products/MX65528MartyMcNuts wrote: ↑Sun Oct 30, 2022 11:32 pmDo not get either of those ASUS's. The Pioneer drive should be UHD rip capable. You could get an external enclosure for it or a SATA to USB powered adapter. Otherwise, look here: viewtopic.php?f=16&t=19634urbanracer34 wrote: ↑Sun Oct 30, 2022 10:34 pmI bought a 5.25 inch Pioneer BDR-212UBK internal drive NOT realizing my PC doesn't have space for an Optical drive.
HELP!
ENCLOSURE MENTIONED ABOVE ORDERED!
Yep.urbanracer34 wrote: ↑Sun Oct 30, 2022 11:38 pmOK. No ASUS drives. Would this external enclosure work? https://www.memoryexpress.com/Products/MX65528MartyMcNuts wrote: ↑Sun Oct 30, 2022 11:32 pmDo not get either of those ASUS's. The Pioneer drive should be UHD rip capable. You could get an external enclosure for it or a SATA to USB powered adapter. Otherwise, look here: viewtopic.php?f=16&t=19634urbanracer34 wrote: ↑Sun Oct 30, 2022 10:34 pmI bought a 5.25 inch Pioneer BDR-212UBK internal drive NOT realizing my PC doesn't have space for an Optical drive.
HELP!
urbanracer34
Thank you very much!MartyMcNuts wrote: ↑Mon Oct 31, 2022 12:11 amYep.urbanracer34 wrote: ↑Sun Oct 30, 2022 11:38 pmOK. No ASUS drives. Would this external enclosure work? https://www.memoryexpress.com/Products/MX65528MartyMcNuts wrote: ↑Sun Oct 30, 2022 11:32 pm
