staknhalo
Post by staknhalo »
https://mega.nz/file/VSYQHLaT#KrMwvoO4 ... ej9gTN2P7o
DV test files
edit: Apple devices will need to remux files first in mp4box
smartrobot
Post by smartrobot »
Hello everyone,
I have been following this thread for a while now which lead me to buy a sony x800m2
My biggest frustration with this device was all of the clicking that was required to select a movie
I decided I needed a movie wall so I hacked together a prototype this weekend
It utilizes plex for all of the media metadata, posters and file paths
I put together a small python backend + nginx host video files
Cheers!
DonaldFaQ
Post by DonaldFaQ »
FEL playback works only with 2 players, the OPPO and his Clone. And FEL will be only triggered if the Source is an ISO file or in the m2ts container.
There is no chance fpr playback FEL within mkv or mp4 container.
saba30
Post by saba30 »
DoVi_Script (1.6.5.1 beta) bug
7-2-4
ac3 audio stream not exporting
15402-15408
bug in 15405 %EID%:"%TEMP% -> %EID% "%TEMP%
:skip.dual
if "%ec3%"=="y" "%ffmpeg_path%" -i %video_path% -map 0:%FID% -c:v copy -c:a ac3 -c:s copy "%TEMP%audio.ac3" & set audio="%TEMP%audio.ac3"&goto :skip
if not "%ac3%"=="y" "%eac3to_path%" %video_path% %EID%:"%TEMP%audio.ac3" & set audio="%TEMP%audio.ac3"
:skip
if "%video.count%"=="2" goto :skip.ST
::--------------------------------------------------------------------------------------------RPU processing----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
staknhalo
Post by staknhalo »
DonaldFaQ wrote:
Mon Oct 31, 2022 1:59 pm
Full FEL works on Chromecast w Google TV 4k and Tivo Stream 4k, been discussed here plenty before. I do it myself with both of mine and single stream dual layer FEL in MP4.
darrrkmanxxx
Post by darrrkmanxxx »
ArArdin wrote:
Fri Oct 28, 2022 3:32 pm
Major difference with FEL being processed is that output will be full-blown 12 bit DV. Vs 10 bit when there's no FEL. Change in dynamics and color is noticable, but I can't say I'm overwhelmed. To my eyes, having a tv calibrated yields more awe. It's much discussed how much (and if) the 2 bits really make a difference, since nowadays tv's even can't saturate fully on 10 bit luminance. And very few (if any) are able to process 12 bit with RPU internally. I think it all depends on personal taste and type of (player and) tv. There's people that prefer (10 bit) HDR10+ over DV FEL+RPU. Everybody should decide for themselves, on their own equipment. Which also goes for tv-led vs LLDV, I'd say.
So if I only can playback Single Layer P7 files, then I guess FEL won't be a thing since this will always be 10-bit, right?
e.g.:
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 10 min
Bit rate                                 : 69.1 Mb/s
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 62.9 GiB (86%)
Maximum Content Light Level              : 922 cd/m2
Maximum Frame-Average Light Level        : 600 cd/m2
because of:
edit: in an mkv container, of course
daddy
Post by daddy »
LG C7, C8 C9 play FEL in mp4 perfectly.
FEL in not something that can be ignored. On some movies it's 15-20% of the movie size.
Général
Nom complet                              : F:\Basic Instinct.mp4
Profil du format                         : Base Media
Identifiant du codec                     : isom (isom)
Taille du fichier                        : 65,6 Gio
Durée                                    : 2 h 8 min
Type de débit global                     : Variable
Débit global moyen                       : 73,2 Mb/s
Date d'encodage                          : UTC 2021-06-16 17:20:27
Date de marquage                         : UTC 2021-06-16 17:20:27
Vidéo #1
Profil du format                         : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : hev1
Identifiant du codec/Info                : High Efficiency Video Coding
Durée                                    : 2 h 8 min
Débit                                    : 56,0 Mb/s
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Type d'images/s                          : Constant
Images par seconde                       : 24,000 Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Profondeur des couleurs                  : 10 bits
Bits/(Pixel*Image)                       : 0.281
Taille du flux                           : 50,2 Gio (76%)
Default                                  : Non
Date d'encodage                          : UTC 2021-06-16 16:46:02
Date de marquage                         : UTC 2021-06-16 17:27:14
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Codec configuration box                  : hvcC
Vidéo #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 2 h 8 min
Débit                                    : 14,1 Mb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
Bits/(Pixel*Image)                       : 0.283
Taille du flux                           : 12,6 Gio (19%)
Default                                  : Non
Audio
Format                                   : DTS XLL
Nom commercial                           : DTS-HD Master Audio
Identifiant du codec                     : mp4a-A9
Durée                                    : 2 h 8 min
Type de débit                            : Variable
Débit                                    : 3 153 kb/s
Débit maximum                            : 3 877 kb/s / 3 153 kb/s
Canaux                                   : 6 canaux
Channel layout                           : C L R Ls Rs LFE
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 93,750 Im/s (512 SPF)
Profondeur des couleurs                  : 24 bits
Mode de compression                      : Sans perte
Taille du flux                           : 2,82 Gio (4%)
Langue                                   : Français
Default                                  : Oui
DonaldFaQ
Post by DonaldFaQ »
You can mux a P7 Dual Layer mp4, thats not the Problem, DV will be triggered. But only MEL will be displayed. There are many Tests in the www, Original UHD BD ISO with OPPO vs. Dual Layer MP4 / MKV. Also Shield Pro 2019 and other players like Zidoo triggered DV with a Dual Layer file, but the playback is only in MEL. Trust me or not, your choice.
You can test it easy, make a DV P8.1 file of the Dual Layered file and playback both. You see no difference. Good movie for testing is Braveheart, superb FEL Layer.
ArArdin
Post by ArArdin »
darrrkmanxxx wrote:
Mon Oct 31, 2022 3:25 pm
Yes, playback of BL only will be 10 bit.
If FEL can't be processed, of course there's no need for it. Nevertheless it may be convenient to keep FEL muxed. Maybe in the near future FEL playback (in mkv) will be more commonly supported by players. Also, as @daddy mentions, already tv's process FEL properly.
Note that single layer P7 doesn't exist. P7 always carries BL and EL. It doesn't matter whether these layers are interleaved into one videotrack (single track dual layer) or they're carried in two separate videotracks (dual track dual layer).
Two well-known single layer DV files are P8.1 and P5. P8.1 carries a (backwards compatible) HEVC HDR10 baselayer, like you find on UHDBD.
P5 - often delivered by streaming services - carries a (non-backwards compatible) baselayer encoded in 10 bit IPTPQc2 full-ranged colorspace, proprietary to Dolby.
darrrkmanxxx
ArArdin wrote:
Tue Nov 01, 2022 5:19 pm
well here's the thing. Plex version 8.something used to playback P7 mkv files. After a couple updates Plex stopped playing back p7 files. One software player tja6t is left, which is playing back p7 files is VIMU. So I guess is just a matter of software. We need a good software player which will playback all dv profiles and display info if fel is dropped etc. :D
staknhalo
Post by staknhalo »
DonaldFaQ wrote:
Tue Nov 01, 2022 11:44 am
Again Chromecast with Google 4k and Tivo Stream 4k display full FEL information not just up to MEL
You can use those test files to confirm yourself just like me and others have here long ago
danbez
Post by danbez »
That's correct. The only problem with those devices is the lack of Lossless sound support. Does anyone have any info about the new fireTV Cube? Does it also work with FEL titles?
FrostByte
Post by FrostByte »
danbez wrote:
Wed Nov 02, 2022 12:28 am
I don't believe it even supports DV7 if I'm reading this correctly.
https://developer.amazon.com/docs/fire- ... -cube.html
mattmarsden
Post by mattmarsden »
Would someone be able to give me a quick run down of how to convert HDR10 mkvs to Dovi mkv using MadVR? Thanks very much.
BadSector81
Post by BadSector81 »
mattmarsden wrote:
Wed Nov 02, 2022 3:09 pm
use this: https://youtu.be/ZdFiqATo_j8
