kazuma
#7726 Post by kazuma » Fri Oct 28, 2022 1:33 pm
what is this for program? and what is the purpose? how do i use it? i think something with subtitles.
https://ibb.co/b77JxmG
ArArdin
#7727 Post by ArArdin » Fri Oct 28, 2022 1:39 pm
darrrkmanxxx wrote:
Fri Oct 28, 2022 12:21 pm
Still, how can I find out if the fel is processed or not?
Not sure. Maybe the manual or specs provide with more info. Perhaps the tv shows meaningfull data during DV playback.
A visual comparison of displays from P7 FEL source and its P8.1 counterpart could also tell you more.
ArArdin
#7728 Post by ArArdin » Fri Oct 28, 2022 1:42 pm
Don't know it. But looking at it and given the name, I'm pretty sure it's a tool for extracting only the subtitles that are flagged as "forced" in a PGS stream. PGS (aka SUP) is the subtitle format used on (UHD)BD.
darrrkmanxxx
#7729 Post by darrrkmanxxx » Fri Oct 28, 2022 1:47 pm
Any key aspects to narrow it down? What would be typical for FEL? Wich advantage has P7 FEL over P8 (RPU only)?
ArArdin
#7730 Post by ArArdin » Fri Oct 28, 2022 3:32 pm
Major difference with FEL being processed is that output will be full-blown 12 bit DV. Vs 10 bit when there's no FEL. Change in dynamics and color is noticable, but I can't say I'm overwhelmed. To my eyes, having a tv calibrated yields more awe. It's much discussed how much (and if) the 2 bits really make a difference, since nowadays tv's even can't saturate fully on 10 bit luminance. And very few (if any) are able to process 12 bit with RPU internally. I think it all depends on personal taste and type of (player and) tv. There's people that prefer (10 bit) HDR10+ over DV FEL+RPU. Everybody should decide for themselves, on their own equipment. Which also goes for tv-led vs LLDV, I'd say.
ragico
#7731 Post by ragico » Fri Oct 28, 2022 11:42 pm
Updated version (1.65) of RESET_9999 Dovi Scripts is available from his signature.
daddy
#7732 Post by daddy » Sat Oct 29, 2022 11:32 am
ragico wrote:
Thu Oct 27, 2022 7:39 pm
in my opinion this forum had 3 great contributors:
1 -@Yusesope
2 -@Quietvoid
3 _@RESET_9999
Yusesope we dont know what happened to him. He is Italian like me but I cant trace him in Italy.
Quietvoid does not like to write too much in the forum.
And then RESET_9999 who is carrying the forum forward and almost in solitude.
For me it's Grencola and later Yusesope that opened the way. Thanks to them.
ragico
#7733 Post by ragico » Sat Oct 29, 2022 12:04 pm
Yes I forgot to mention Grencola, it was years ago.
FLarnhill
#7734 Post by FLarnhill » Sun Oct 30, 2022 10:10 pm
Probably a silly question but I know the UB820 isn't recommended for file playback but I love its tone-mapping feature. Should I just keep that if I wanna play discs and use the x800m2 for files? Does self-tone-mapping even matter for files, DoVi or otherwise? For reference, I use a ForMovie Theater for display.
staknhalo
#7735 Post by staknhalo » Sun Oct 30, 2022 10:27 pm
https://mega.nz/file/VSYQHLaT#KrMwvoO4 ... ej9gTN2P7o
DV test files
edit: Apple devices will need to remux files first in mp4box
smartrobot
#7736 Post by smartrobot » Mon Oct 31, 2022 12:26 am
Hello everyone,
I have been following this thread for a while now which lead me to buy a sony x800m2
My biggest frustration with this device was all of the clicking that was required to select a movie
I decided I needed a movie wall so I hacked together a prototype this weekend
It utilizes plex for all of the media metadata, posters and file paths
I put together a small python backend + nginx host video files
Cheers!
DonaldFaQ
#7737 Post by DonaldFaQ » Mon Oct 31, 2022 1:59 pm
FEL playback works only with 2 players, the OPPO and his Clone. And FEL will be only triggered if the Source is an ISO file or in the m2ts container.
There is no chance fpr playback FEL within mkv or mp4 container.
saba30
#7738 Post by saba30 » Mon Oct 31, 2022 2:26 pm
DoVi_Script (1.6.5.1 beta) bug
7-2-4
ac3 audio stream not exporting
15402-15408
bug in 15405 %EID%:"%TEMP% -> %EID% "%TEMP%
:skip.dual
if "%ec3%"=="y" "%ffmpeg_path%" -i %video_path% -map 0:%FID% -c:v copy -c:a ac3 -c:s copy "%TEMP%audio.ac3" & set audio="%TEMP%audio.ac3"&goto :skip
if not "%ac3%"=="y" "%eac3to_path%" %video_path% %EID%:"%TEMP%audio.ac3" & set audio="%TEMP%audio.ac3"
:skip
if "%video.count%"=="2" goto :skip.ST
::--------------------------------------------------------------------------------------------RPU processing----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
staknhalo
#7739 Post by staknhalo » Mon Oct 31, 2022 2:37 pm
Full FEL works on Chromecast w Google TV 4k and Tivo Stream 4k, been discussed here plenty before. I do it myself with both of mine and single stream dual layer FEL in MP4.
darrrkmanxxx
#7740 Post by darrrkmanxxx » Mon Oct 31, 2022 3:25 pm
So if I only can playback Single Layer P7 files, then I guess FEL won't be a thing since this will always be 10-bit, right?
e.g.:
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 10 min
Bit rate                                 : 69.1 Mb/s
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 62.9 GiB (86%)
Maximum Content Light Level              : 922 cd/m2
Maximum Frame-Average Light Level        : 600 cd/m2
because of:
edit: in an mkv container, of course
