darrrkmanxxx
#7726 Post by darrrkmanxxx » Fri Oct 28, 2022 1:47 pm
ArArdin wrote: Fri Oct 28, 2022 1:39 pm
darrrkmanxxx wrote: Fri Oct 28, 2022 12:21 pmStill, how can I find out if the fel is processed or not?
Not sure. Maybe the manual or specs provide with more info. Perhaps the tv shows meaningfull data during DV playback.
A visual comparison of displays from P7 FEL source and its P8.1 counterpart could also tell you more.
Any key aspects to narrow it down? What would be typical for FEL? Wich advantage has P7 FEL over P8 (RPU only)?
ArArdin
#7727 Post by ArArdin » Fri Oct 28, 2022 3:32 pm
Major difference with FEL being processed is that output will be full-blown 12 bit DV. Vs 10 bit when there's no FEL. Change in dynamics and color is noticable, but I can't say I'm overwhelmed. To my eyes, having a tv calibrated yields more awe. It's much discussed how much (and if) the 2 bits really make a difference, since nowadays tv's even can't saturate fully on 10 bit luminance. And very few (if any) are able to process 12 bit with RPU internally. I think it all depends on personal taste and type of (player and) tv. There's people that prefer (10 bit) HDR10+ over DV FEL+RPU. Everybody should decide for themselves, on their own equipment. Which also goes for tv-led vs LLDV, I'd say.
ragico
#7728 Post by ragico » Fri Oct 28, 2022 11:42 pm
Updated version (1.65) of RESET_9999 Dovi Scripts is available from his signature.
daddy
#7729 Post by daddy » Sat Oct 29, 2022 11:32 am
ragico wrote: Thu Oct 27, 2022 7:39 pm in my opinion this forum had 3 great contributors:
1 -@Yusesope
2 -@Quietvoid
3 _@RESET_9999
Yusesope we dont know what happened to him. He is Italian like me but I cant trace him in Italy.
Quietvoid does not like to write too much in the forum.
And then RESET_9999 who is carrying the forum forward and almost in solitude.
For me it's Grencola and later Yusesope that opened the way. Thanks to them.
ragico
#7730 Post by ragico » Sat Oct 29, 2022 12:04 pm
daddy wrote: Sat Oct 29, 2022 11:32 am For me it's Grencola and later Yusesope that opened the way. Thanks to them.
Yes I forgot to mention Grencola, it was years ago.
FLarnhill
#7731 Post by FLarnhill » Sun Oct 30, 2022 10:10 pm
Probably a silly question but I know the UB820 isn't recommended for file playback but I love its tone-mapping feature. Should I just keep that if I wanna play discs and use the x800m2 for files? Does self-tone-mapping even matter for files, DoVi or otherwise? For reference, I use a ForMovie Theater for display.
staknhalo
#7732 Post by staknhalo » Sun Oct 30, 2022 10:27 pm
https://mega.nz/file/VSYQHLaT#KrMwvoO4 ... ej9gTN2P7o
DV test files
edit: Apple devices will need to remux files first in mp4box
smartrobot
#7733 Post by smartrobot » Mon Oct 31, 2022 12:26 am
Hello everyone,
I have been following this thread for a while now which lead me to buy a sony x800m2
My biggest frustration with this device was all of the clicking that was required to select a movie
I decided I needed a movie wall so I hacked together a prototype this weekend
It utilizes plex for all of the media metadata, posters and file paths
I put together a small python backend + nginx host video files
Cheers!
DonaldFaQ
#7734 Post by DonaldFaQ » Mon Oct 31, 2022 1:59 pm
FEL playback works only with 2 players, the OPPO and his Clone. And FEL will be only triggered if the Source is an ISO file or in the m2ts container.
There is no chance fpr playback FEL within mkv or mp4 container.
saba30
#7735 Post by saba30 » Mon Oct 31, 2022 2:26 pm
DoVi_Script (1.6.5.1 beta) bug
7-2-4
ac3 audio stream not exporting
15402-15408
bug in 15405 %EID%:"%TEMP% -> %EID% "%TEMP%
:skip.dual
if "%ec3%"=="y" "%ffmpeg_path%" -i %video_path% -map 0:%FID% -c:v copy -c:a ac3 -c:s copy "%TEMP%audio.ac3" & set audio="%TEMP%audio.ac3"&goto :skip
if not "%ac3%"=="y" "%eac3to_path%" %video_path% %EID%:"%TEMP%audio.ac3" & set audio="%TEMP%audio.ac3"
:skip
if "%video.count%"=="2" goto :skip.ST
::--------------------------------------------------------------------------------------------RPU processing----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
staknhalo
#7736 Post by staknhalo » Mon Oct 31, 2022 2:37 pm
DonaldFaQ wrote: Mon Oct 31, 2022 1:59 pm FEL playback works only with 2 players, the OPPO and his Clone. And FEL will be only triggered if the Source is an ISO file or in the m2ts container.
Full FEL works on Chromecast w Google TV 4k and Tivo Stream 4k, been discussed here plenty before. I do it myself with both of mine and single stream dual layer FEL in MP4.
darrrkmanxxx
#7737 Post by darrrkmanxxx » Mon Oct 31, 2022 3:25 pm
ArArdin wrote: Fri Oct 28, 2022 3:32 pm Major difference with FEL being processed is that output will be full-blown 12 bit DV. Vs 10 bit when there's no FEL. Change in dynamics and color is noticable, but I can't say I'm overwhelmed. To my eyes, having a tv calibrated yields more awe. It's much discussed how much (and if) the 2 bits really make a difference, since nowadays tv's even can't saturate fully on 10 bit luminance. And very few (if any) are able to process 12 bit with RPU internally. I think it all depends on personal taste and type of (player and) tv. There's people that prefer (10 bit) HDR10+ over DV FEL+RPU. Everybody should decide for themselves, on their own equipment. Which also goes for tv-led vs LLDV, I'd say.
So if I only can playback Single Layer P7 files, then I guess FEL won't be a thing since this will always be 10-bit, right?
e.g.:
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Duration                                 : 2 h 10 min
Bit rate                                 : 69.1 Mb/s
Bits/(Pixel*Frame)                       : 0.347
Stream size                              : 62.9 GiB (86%)
Maximum Content Light Level              : 922 cd/m2
Maximum Frame-Average Light Level        : 600 cd/m2
because of:
edit: in an mkv container, of course
daddy
#7738 Post by daddy » Mon Oct 31, 2022 5:49 pm
LG C7, C8 C9 play FEL in mp4 perfectly.
FEL in not something that can be ignored. On some movies it's 15-20% of the movie size.
Général
Nom complet                              : F:\Basic Instinct.mp4
Profil du format                         : Base Media
Identifiant du codec                     : isom (isom)
Taille du fichier                        : 65,6 Gio
Durée                                    : 2 h 8 min
Type de débit global                     : Variable
Débit global moyen                       : 73,2 Mb/s
Date d'encodage                          : UTC 2021-06-16 17:20:27
Date de marquage                         : UTC 2021-06-16 17:20:27
Vidéo #1
Profil du format                         : Main 10@L5.1@High
HDR format                               : SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : hev1
Identifiant du codec/Info                : High Efficiency Video Coding
Durée                                    : 2 h 8 min
Débit                                    : 56,0 Mb/s
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Type d'images/s                          : Constant
Images par seconde                       : 24,000 Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Profondeur des couleurs                  : 10 bits
Bits/(Pixel*Image)                       : 0.281
Taille du flux                           : 50,2 Gio (76%)
Default                                  : Non
Date d'encodage                          : UTC 2021-06-16 16:46:02
Date de marquage                         : UTC 2021-06-16 17:27:14
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
Mastering display color primaries        : BT.2020
Codec configuration box                  : hvcC
Vidéo #2
HDR format                               : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 2 h 8 min
Débit                                    : 14,1 Mb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
Bits/(Pixel*Image)                       : 0.283
Taille du flux                           : 12,6 Gio (19%)
Default                                  : Non
Audio
Format                                   : DTS XLL
Nom commercial                           : DTS-HD Master Audio
Identifiant du codec                     : mp4a-A9
Durée                                    : 2 h 8 min
Type de débit                            : Variable
Débit                                    : 3 153 kb/s
Débit maximum                            : 3 877 kb/s / 3 153 kb/s
Canaux                                   : 6 canaux
Channel layout                           : C L R Ls Rs LFE
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 93,750 Im/s (512 SPF)
Profondeur des couleurs                  : 24 bits
Mode de compression                      : Sans perte
Taille du flux                           : 2,82 Gio (4%)
Langue                                   : Français
Default                                  : Oui
DonaldFaQ
#7739 Post by DonaldFaQ » Tue Nov 01, 2022 11:44 am
You can mux a P7 Dual Layer mp4, thats not the Problem, DV will be triggered. But only MEL will be displayed. There are many Tests in the www, Original UHD BD ISO with OPPO vs. Dual Layer MP4 / MKV. Also Shield Pro 2019 and other players like Zidoo triggered DV with a Dual Layer file, but the playback is only in MEL. Trust me or not, your choice.
You can test it easy, make a DV P8.1 file of the Dual Layered file and playback both. You see no difference. Good movie for testing is Braveheart, superb FEL Layer.
ArArdin
#7740 Post by ArArdin » Tue Nov 01, 2022 5:19 pm
darrrkmanxxx wrote: Mon Oct 31, 2022 3:25 pmSo if I only can playback Single Layer P7 files, then I guess FEL won't be a thing since this will always be 10-bit, right?
Yes, playback of BL only will be 10 bit.
If FEL can't be processed, of course there's no need for it. Nevertheless it may be convenient to keep FEL muxed. Maybe in the near future FEL playback (in mkv) will be more commonly supported by players. Also, as @daddy mentions, already tv's process FEL properly.
Note that single layer P7 doesn't exist. P7 always carries BL and EL. It doesn't matter whether these layers are interleaved into one videotrack (single track dual layer) or they're carried in two separate videotracks (dual track dual layer).
Two well-known single layer DV files are P8.1 and P5. P8.1 carries a (backwards compatible) HEVC HDR10 baselayer, like you find on UHDBD.
P5 - often delivered by streaming services - carries a (non-backwards compatible) baselayer encoded in 10 bit IPTPQc2 full-ranged colorspace, proprietary to Dolby.
