Cr4z33
Post
by Cr4z33 » Wed Oct 26, 2022 8:20 am
Cr4z33 wrote: ↑Tue Oct 25, 2022 8:59 am
RESET_9999 wrote: ↑Sun Mar 21, 2021 7:11 pm
it is a single layer profile 5 dolby vision from streaming services and it's very different from the dual layer dolby vision you find on bluray discs.
you can add external audio by doing this:
MKV:
1-remux the mp4 with mkvtoolnix (add external audio/subs).
2- import the mkv into the latest makemkv and create a new DV mkv..
TS:
use nightly tsmuxer. (you might have to demux the mp4 first)
MP4:
use mp4box to add external audio.
So I've used this method for a while remuxing ENG MKVs with Italian audio tracks, but since when I am getting mixed HDR/DV MKVs I always end up by being able to watch them in HDR only (at least this happens in Plex).
What do I have to do to force a "DV only" remuxing and/or get rid also of the HDR informations?
Can anyone help me?
It is my understanding that there are two DoVi tools out now that *might* do the HDR removing job?
The video track of my MKV has this specs:
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 53 min
Bit rate : 8 109 kb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.041
Stream size : 6.42 GiB (85%)
Language : Italian
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Nvidia Shield TV Pro -> DENON AVR-X2200W -> LG OLED65GX6
ArArdin
Post
by ArArdin » Wed Oct 26, 2022 10:50 am
RESET_9999's quote was about adding audio/subs to dual layer Dolby Vision. As your mkv video data concerns single layer Dolby Vision (BL+RPU), I partly miss out on the connection here.
What makes HDR video is that it's encoded that way. And which you can't just remove with a remux. "Removing" HDR would require tone remapping and reencoding.
Not sure, but possibly you're confusing with HDR10+ metadata, which can be carried by HDR video. Also, HDR10+ can be carried together with RPU. They are both dynamic metadata. A "DV only remux" as I understand it, is stripping HDR10+ from video that also carries RPU. It can be applied as a remedy to a player or tv showing playback issues when offered video holding both HDR10+ and RPU.
As for your mkv, other than bitrate striking me as low, the videodata does look correct for single layer Dolby Vision. Unfamiliar with Plex and your equipment, I wouldn't know why DV isn't working. Hopefully other members can tell you.
Cr4z33
Post
by Cr4z33 » Wed Oct 26, 2022 11:08 am
ArArdin wrote: ↑Wed Oct 26, 2022 10:50 am
RESET_9999's quote was about...
Thanks for your thoroughfull explanation!
I've already tried watching the MKV also with Kodi, but it keeps being played into HDR.
I will wait then for posts of other members.
ArArdin
Post
by ArArdin » Wed Oct 26, 2022 11:59 am
As a general thought, did you already have Dolby Vision working on your equipment? Meaning, are the firmwares (AVR?) up-to-date and - if applicable - is DV enabled in every device settings?
Cr4z33
Post
by Cr4z33 » Wed Oct 26, 2022 1:07 pm
ArArdin wrote: ↑Wed Oct 26, 2022 11:59 am
Yeah sure just noticing this issue with some MKVs.
comorla45
Post
by comorla45 » Thu Oct 27, 2022 12:35 pm
Hello. Does anyone know why the file on left did not trigger DV on LG B1 despite being Profile 8? Only HDR10 was triggered.
After I run DolbyVision script Workflow 1 (and provided 2x the same input file for HDR10 and DV input file) the processed file on right did trigger DV playback.
ragico
Post
by ragico » Thu Oct 27, 2022 7:39 pm
in my opinion this forum had 3 great contributors:
1 -@Yusesope
2 -@Quietvoid
3 _@RESET_9999
Yusesope we dont know what happened to him. He is Italian like me but I cant trace him in Italy.
Quietvoid does not like to write too much in the forum.
And then RESET_9999 who is carrying the forum forward and almost in solitude.
ArArdin
Post
by ArArdin » Fri Oct 28, 2022 1:38 am
comorla45 wrote: ↑Thu Oct 27, 2022 12:35 pm
Maybe different containers?
speeddemon
Post
by speeddemon » Fri Oct 28, 2022 4:24 am
Does anyone know if Google TV devices support Profile 8.1?
Specifically, do Sony TVs with Google TV support DoVi Profile 8.1 in an MKV container?
I've tried playing it back via Plex, and it triggers DoVi, but I'm not sure how to tell whether it's just triggering DoVi like Plex on Apple TV or if it's actually passing along DoVi metadata.
Gatorman
Post
by Gatorman » Fri Oct 28, 2022 4:34 am
speeddemon wrote: ↑Fri Oct 28, 2022 4:24 am
Checkout this link, and go to the "DoVi Playback Devices" tab.
https://docs.google.com/spreadsheets/d/ ... =427220017
speeddemon
Post
by speeddemon » Fri Oct 28, 2022 5:45 am
Gatorman wrote:speeddemon wrote: ↑Fri Oct 28, 2022 4:24 am
Thanks for sharing but that unfortunately doesn’t mention Sony TVs. I’d be more than happy to test if someone could explain how.
darrrkmanxxx
Post
by darrrkmanxxx » Fri Oct 28, 2022 10:43 am
Gatorman wrote: ↑Fri Oct 28, 2022 4:34 am
I have Philips 65oled934 2019. It has an LG Panel, but I can perfectly playback P8 and P5 MKV. The compatibility corresponds with Chromecast with GTV, Fire Stick TV, Zidoo Z9X -ish.
How I can find out if EL is being dropped with P7?
ArArdin
Post
by ArArdin » Fri Oct 28, 2022 11:17 am
speeddemon wrote: ↑Fri Oct 28, 2022 5:45 am
Often the best way to check is visually.
I don't know Plex but maybe it has settings to disable/enable Dolby Vision. In which case you can directly compare the two. If not, or when having other doubts, a safe bet with Profile 8.1 is to create a copy of the file where you strip RPU and compare to that.
ArArdin
Post
by ArArdin » Fri Oct 28, 2022 11:47 am
darrrkmanxxx wrote: ↑Fri Oct 28, 2022 10:43 am
This can raise some confusion.
P7 EL carries RPU and DV playback always requires RPU. What you probably mean is, whether the additional video data FEL holds will be processed or not. From RESET_9999's device list, of the three players you mentioned CC+GTV is the only that does process FEL. But it has to be in STDL. Can't vouch for it though.
As I have a Z9X I know for sure it doesn't decode FEL. Like most non-UHDBD DV players.
darrrkmanxxx
Post
by darrrkmanxxx » Fri Oct 28, 2022 12:21 pm
ArArdin wrote: ↑Fri Oct 28, 2022 11:47 am
Then it would be probably the same for me, no FEL decode. Still wondering why LG TV can't playback dv in mkv. I guess not much people have philips tvs.
Still, how can I find out if the fel is processed or not?
