You deserve a break indeed, thank you very much, true Jedi of DV world.RESET_9999 wrote: ↑Mon Oct 24, 2022 10:52 pmyes, your post really confused me![]()
But it's all good, needed a break anyway. Anyone can still PM me if you have suggestions, bug or questions about my script.
thank you to all for the help and great discussions over the past years.
i'm curious. is reset_9999 the first person in the world that 'cracked' DV? are there more people with this kind of tools on the internet?
darrrkmanxxx
Hey Guys, just wanted to check in and see if I miss something here.
I have a philips 65 oled 934 2019 with dv capability. I'm able to playback P5 and P8 mkv through Plex perfectly fine.
However I was also able to playback P7 through Plex til version 8.12.2.22756. Going higher version stops P7 support.
I understand that if I playback P7 files through plex or vimu player the EL will be left out anyway, right?
So my goal is now to mux everything to P8.
My question would be if there's any other downside of using P8 rather than P7 apart from having EL which I can't playback anyway?
Thnaks
Thnaks
Can anyone help me?Cr4z33 wrote: ↑Tue Oct 25, 2022 8:59 amSo I've used this method for a while remuxing ENG MKVs with Italian audio tracks, but since when I am getting mixed HDR/DV MKVs I always end up by being able to watch them in HDR only (at least this happens in Plex).RESET_9999 wrote: ↑Sun Mar 21, 2021 7:11 pm
it is a single layer profile 5 dolby vision from streaming services and it's very different from the dual layer dolby vision you find on bluray discs.
you can add external audio by doing this:
MKV:
1-remux the mp4 with mkvtoolnix (add external audio/subs).
2- import the mkv into the latest makemkv and create a new DV mkv..
TS:
use nightly tsmuxer. (you might have to demux the mp4 first)
MP4:
use mp4box to add external audio.![]()
What do I have to do to force a "DV only" remuxing and/or get rid also of the HDR informations?
It is my understanding that there are two DoVi tools out now that *might* do the HDR removing job?
The video track of my MKV has this specs:
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 53 min
Bit rate : 8 109 kb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.041
Stream size : 6.42 GiB (85%)
Language : Italian
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2Nvidia Shield TV Pro -> DENON AVR-X2200W -> LG OLED65GX6
RESET_9999's quote was about adding audio/subs to dual layer Dolby Vision. As your mkv video data concerns single layer Dolby Vision (BL+RPU), I partly miss out on the connection here.
What makes HDR video is that it's encoded that way. And which you can't just remove with a remux. "Removing" HDR would require tone remapping and reencoding.
Not sure, but possibly you're confusing with HDR10+ metadata, which can be carried by HDR video. Also, HDR10+ can be carried together with RPU. They are both dynamic metadata. A "DV only remux" as I understand it, is stripping HDR10+ from video that also carries RPU. It can be applied as a remedy to a player or tv showing playback issues when offered video holding both HDR10+ and RPU.
As for your mkv, other than bitrate striking me as low, the videodata does look correct for single layer Dolby Vision. Unfamiliar with Plex and your equipment, I wouldn't know why DV isn't working. Hopefully other members can tell you.
Thanks for your thoroughfull explanation!
I've already tried watching the MKV also with Kodi, but it keeps being played into HDR.
I will wait then for posts of other members.
As a general thought, did you already have Dolby Vision working on your equipment? Meaning, are the firmwares (AVR?) up-to-date and - if applicable - is DV enabled in every device settings?
Yeah sure just noticing this issue with some MKVs.
Hello. Does anyone know why the file on left did not trigger DV on LG B1 despite being Profile 8? Only HDR10 was triggered.
After I run DolbyVision script Workflow 1 (and provided 2x the same input file for HDR10 and DV input file) the processed file on right did trigger DV playback.
in my opinion this forum had 3 great contributors:
1 -@Yusesope
2 -@Quietvoid
3 _@RESET_9999
Yusesope we dont know what happened to him. He is Italian like me but I cant trace him in Italy.
Quietvoid does not like to write too much in the forum.
And then RESET_9999 who is carrying the forum forward and almost in solitude.
1 -@Yusesope
2 -@Quietvoid
3 _@RESET_9999
speeddemon
Does anyone know if Google TV devices support Profile 8.1?
Specifically, do Sony TVs with Google TV support DoVi Profile 8.1 in an MKV container?
I've tried playing it back via Plex, and it triggers DoVi, but I'm not sure how to tell whether it's just triggering DoVi like Plex on Apple TV or if it's actually passing along DoVi metadata.
Checkout this link, and go to the "DoVi Playback Devices" tab.speeddemon wrote: ↑Fri Oct 28, 2022 4:24 amDoes anyone know if Google TV devices support Profile 8.1?
https://docs.google.com/spreadsheets/d/ ... =427220017
More reasons to collect physical media. Ugoos AM6B+.
