The quality of the MKV differs from the original
sfuma
#1 Post by sfuma » Wed Oct 26, 2022 6:23 am
After converting Blu-ray to MKV, the image is different. The colors become more saturated with a hint of red.
Re: The quality of the MKV differs from the original
#2 Post by Billycar11 » Wed Oct 26, 2022 1:28 pm
Nah it's the playback device or your tv settings
sfuma
#3 Post by sfuma » Wed Oct 26, 2022 1:51 pm
I am comparing the M2TS source file with the MKV on the computer.
#4 Post by Billycar11 » Wed Oct 26, 2022 6:32 pm
sfuma wrote: Wed Oct 26, 2022 1:51 pm I am comparing the M2TS source file with the MKV on the computer.
Ok it's the playback software then what are you using
sfuma
#5 Post by sfuma » Wed Oct 26, 2022 7:36 pm
I use mpv media player, PotPlayer.
#6 Post by Billycar11 » Thu Oct 27, 2022 8:58 am
are these UHD rips?
if so it maybe the players are trying to use the Dolby vision enhancement layer
sfuma
#7 Post by sfuma » Thu Oct 27, 2022 10:25 am
On all rips: HD and UHD.
#8 Post by Billycar11 » Thu Oct 27, 2022 10:41 am
sfuma wrote: Thu Oct 27, 2022 10:25 am On all rips: HD and UHD.
Check if your movies are Dolby vision titles that would be the reason the players may or may not be showing it correctly the m2ts would not show it just default back to standard hdr10 so that's why they look different.
You maybe able to have the players ignore Dolby vision data
sfuma
#9 Post by sfuma » Thu Oct 27, 2022 10:48 am
I tried to make rips using DVDFab and mkvtoolnix . None of them made exact copies. tsMuxeR more or less copes with this task, but it does not make MKV.
ryley
#10 Post by ryley » Thu Oct 27, 2022 3:11 pm
Because there is no re-encoding or quality loss in remuxing a Blu-ray to MKV, it sounds like your playback software may be handling Matroska files differently from M2TS. As a test, why don't you try to have tsMuxer remux your MKV into an M2TS. It would be interesting if this (re-remuxed) M2TS file plays differently from your source. If you'd like to frame-by-frame comparisons, I find Avidemux to be helpful.
sfuma
#11 Post by sfuma » Thu Oct 27, 2022 3:59 pm
Why would I do stupid things. I'm sorry you don't see the difference between original and rip.
ryley
#12 Post by ryley » Thu Oct 27, 2022 4:22 pm
I explained the utility of testing a repackaged file was to determine if something may have gone wrong with the M2TS to MKV step.
Believe me, I'm much more sorry that you don't understand precisely why there is no quality difference between the files.
Oh no, I think the forum quoting system is having the same red problem. Please solve this after you crack the 'remuxing is re-encoding' conspiracy
