No output file after backing up Boogie Nights Blu-Ray
robertpetry
#1 Post by robertpetry » Thu Mar 13, 2014 9:28 pm
Hello all. I have tried several times and no issues backing up the special features files to MKV but no luck on the feature film.
Here is my log. Any ideas? The disk plays fine.
I generated a test dump but it would not upload. 144MB maybe that is the issue.
Debug log started at Thu Mar 13 20:53:54 2014 , written by MakeMKV v1.8.8 darwin(x86-release)
001005:0000 MakeMKV v1.8.8 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/admin/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5690H 4AH5d" opened in OS access mode.
002010:0000 Optical drive "BD-RE ASUS SBW-06D2X-U C701d" opened in OS access mode.
005075:0000 The new version 1.8.9 is available for download at /download
DAFD=PAAAADAAAAEABDQkEGwEEAQ==
DCE=IYA1mCx+Z9FeU+uDhJ+c9FjcCfY9F8uiJjp4B1nhlvi95gcD0Eu3f4P2l7TSVIa//V9cK6llji+kYwRS9ulyDImOFMLgR2U8BaBlT+x2kXitBPvzrO7LgnYGEjZO+IiaDketYJxlABY9tx+emUzAY/4nxRSfXYbCqw==
DCE=J2XRQt+dZNRvpQQ5CImYkuxPtPPl4MhO/pFmvoXJRxBX+3NG8wi7JM/t9ANFyQRMtNxBabxNSm/1YgMJ+xpJU/Dt+lR/b+O6RRvSCT9vOZdh7S3pAY3CQEFCdp8DMbWcq/hA3URlBtXzOowEcCNjKzy4bdqH84gszQ==
DISCID=BA0D78175593B9FCF30AEC649F6041A8D3035D1C
003307:0000 File 00014.mpls was added as title #0
003307:0000 File 00018.mpls was added as title #1
003307:0000 File 00022.mpls was added as title #2
003025:0000 Title #00015.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00000.mpls was added as title #3
003025:0000 Title #00002.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00034.m2ts was added as title #4
003307:0000 File 00038.m2ts was added as title #5
003307:0000 File 00037.m2ts was added as title #6
003307:0000 File 00036.m2ts was added as title #7
003025:0000 Title #00017.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00035.m2ts was added as title #8
003025:0000 Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 9 titles into directory /Users/admin/Movies/Boogie_Nights
AV sync issues in /Users/admin/Movies/Boogie_Nights/Boogie_Nights_t01.mkv
AV sync in 1 at 0:01:00.643 (3.916ms) : short audio gap was removed, audio skew is -3.916ms
AV sync in 2 at 0:01:00.643 (28.083ms) : encountered overlapping frame, audio skew is +28.083ms
AV sync in 1 at 0:02:19.923 (19.116ms) : short audio gap was removed, audio skew is -19.116ms
AV sync in 2 at 0:02:19.923 (3528617.859s) : short audio gap was removed, audio skew is +12.883ms
AV sync in 1 at 0:09:29.518 (4.166ms) : encountered overlapping frame, audio skew is -14.95ms
AV sync in 2 at 0:09:29.518 (4.166ms) : encountered overlapping frame, audio skew is +17.05ms
AV sync in 1 at 0:11:42.685 (29.316ms) : short audio gap was removed, audio skew is -29.316ms
AV sync in 2 at 0:11:42.685 (3528617.869s) : short audio gap was removed, audio skew is +2.683ms
AV sync in 1 at 0:15:20.402 (10.5ms) : encountered overlapping frame, audio skew is -18.816ms
AV sync in 2 at 0:15:20.402 (10.5ms) : encountered overlapping frame, audio skew is +13.183ms
AV sync in 1 at 0:18:03.315 (31.25ms) : encountered overlapping frame, audio skew is +12.433ms
AV sync in 2 at 0:18:03.315 (31.25ms) : encountered overlapping frame, audio skew is +44.433ms
AV sync in 2 at 0:18:03.360 (32ms) : 1 frame(s) dropped to reduce audio skew to +12.433ms
AV sync in 1 at 0:20:09.558 (29.216ms) : encountered overlapping frame, audio skew is +41.65ms
AV sync in 1 at 0:20:09.600 (32ms) : 1 frame(s) dropped to reduce audio skew to +9.65ms
AV sync in 2 at 0:20:09.558 (3528617.862s) : short audio gap was removed, audio skew is +9.65ms
AV sync in 1,2 at 0:20:53.769 (13.166ms) : encountered overlapping frame, audio skew is +22.816ms
AV sync in 1,2 at 0:23:32.377 (15.55ms) : encountered overlapping frame, audio skew is +38.366ms
AV sync in 1,2 at 0:23:32.416 (32ms) : 1 frame(s) dropped to reduce audio skew to +6.366ms
004001:0000 Forced subtitles track #4 turned out to be empty and was removed from output file
AV sync issues in /Users/admin/Movies/Boogie_Nights/Boogie_Nights_t02.mkv
AV sync in 1 at 0:03:15.461 (5.933ms) : short audio gap was removed, audio skew is -5.933ms
AV sync in 1 at 0:06:11.571 (19.2ms) : short audio gap was removed, audio skew is -19.2ms
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
001003:0020 DEBUG: Code 1073741829 at }p5*pcbWE ZWBZQ~:29393953
001003:0020 DEBUG: Code 2 at 9mbI(g",MA`5q[K@:213137827
001003:0020 DEBUG: Code 1 at |[D~/hY9a7X gug0:213139920
002003:0000 Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '198377472'
001003:0020 DEBUG: Code 0 at &q0a[X1PI,;x[AgoJdKL:121262739
001003:0020 DEBUG: Code 0 at TTa<1lf'QE=Q!NgV[$Q\:121261888
001003:0020 DEBUG: Code 0 at &q0a[X1PI,;x[AgoJdKL:213130743
001003:0020 DEBUG: Code 96864 at &q0a[X1PI,;x[AgoJdKL:29393332
001003:0020 DEBUG: Code 0 at =2$VWo(t":l&R8X4zm^Hf:121266810
005003:0000 Failed to save title 3 to file /Users/admin/Movies/Boogie_Nights/Boogie_Nights_t03.mkv
005004:0080 8 titles saved, 1 failed
005037:0204 Copy complete. 8 titles saved, 1 failed.
001002:0000 LIBMKV_TRACE: Test dump mode on
005014:0000 Saving 1 titles into directory /Users/admin/Movies/Boogie_Nights
001003:0020 DEBUG: Code 8193 at |[D~/hY9a7X gug0:213139920
001003:0020 DEBUG: Code 65537 at |[D~/hY9a7X gug0:213139920
001003:0020 DEBUG: Code 73729 at |[D~/hY9a7X gug0:213139920
001003:0020 DEBUG: Code 2049 at |[D~/hY9a7X gug0:213139920
002003:0000 Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '185726976'
001003:0020 DEBUG: Code 90687 at &q0a[X1PI,;x[AgoJdKL:29393332
001003:0020 DEBUG: Code 0 at FHGEATD@<'ya/X[QAH:121264809
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Re: No output file after backing up Boogie Nights Blu-Ray
#2 Post by Woodstock » Thu Mar 13, 2014 10:43 pm
That's the drive saying it can't read at least one part of the disk. A dedicated BD player will have software in it that will skip over bad sectors, but ripping software is trying to get an exact copy. And, unfortunately, the main feature has a lot more opportunities to span a damaged section of disk.
Personally, I'd clean and wax the disk, and try again. You could try increasing the number of retries MakeMKV will request, also.
robertpetry
#3 Post by robertpetry » Fri Mar 14, 2014 12:51 am
Thank you! The disk looks spotless and I tired to clean it anyway. I wonder if it is an intentional bad sector?
#4 Post by Woodstock » Sat Mar 15, 2014 12:11 am
There have been instances of intentional bad sectors, but usually NOT in the feature itself. That doesn't mean it doesn't have flaws in the pressing... Which would affect hundreds or even thousands of disks in a batch.
Jman5150
#5 Post by Jman5150 » Mon Oct 24, 2022 8:23 pm
Anyone figure a fix for this? Cant rip the movie or bkup. Strange pop uos in the beginning too.
#6 Post by Woodstock » Mon Oct 24, 2022 10:38 pm
This is a 6-year old topic you're replying to, and I would guess that others have managed to read the disk fine since then.
Just what errors are you seeing?
