Default selection rules issue
spl147
Post by spl147 »
MakeMKV 1.16.7
-sel:all is not being honored
my rules:
-sel:all,+sel:(forced*eng),+sel:(lossless*eng),-sel:(core*eng),-sel:mvcvideo
Chetwood
Re: Default selection rules issue
Post by Chetwood »
Works for me on Win10.
spl147
Post by spl147 »
Chetwood wrote: Sat Mar 12, 2022 7:21 am Works for me on Win10.
not working on linux
spl147
Post by spl147 »
Not working for me on win11 either. Is my syntax correct?
Chetwood
Post by Chetwood »
Looks like it.
bmillham
Post by bmillham »
spl147 wrote: Thu Mar 17, 2022 10:57 pm
This is what I have on my Linux Mint. Works fine:
-sel:all,+sel:(favlang|nolang|single),-sel:(havemulti),-sel:mvcvideo,=100:all,-10:favlang
spl147
Post by spl147 »
@mike admin,
Has this been looked into?
spl147
Post by spl147 »
OK, im gonna try this again:
my default selection rules are:
the result is:
as you can see the selections within a track are correct but all the tracks are still selected, im trying to start with NO titles selected
spl147
Post by spl147 »
Mike Admin?
GalaKstiv
Post by GalaKstiv »
spl147 wrote: Mon Oct 24, 2022 1:31 pmas you can see the selections within a track are correct but all the tracks are still selected, im trying to start with NO titles selected
If all the selected titles contains at least one track that is eligible to the rule (for example it contains a track of any type ~video, audio, sub~ in english, it makes sense that all these titles are selected.
As far as I know, there is no rules to unselect titles.
spl147
Post by spl147 »
Mike?
bmillham
Post by bmillham »
Why do you keep bumping this. -sel:all works on linux. It's probably something in your selection rules causing your problem. Did you try the rules I posted two years ago?
spl147
Post by spl147 »
bmillham wrote: Mon May 13, 2024 9:43 pm Why do you keep bumping this. -sel:all works on linux. It's probably something in your selection rules causing your problem. Did you try the rules I posted two years ago?
Well if it worked i wouldn’t keep bumping it now would i?
-sel:all should do just that unselect EVERYTHING, but it does not
bmillham
Post by bmillham »
Maybe I'm mis-understanding the documents, but -sel:all says that it unselects all tracks. And it does just that.
It does not say that it unselects all titles
spl147
Post by spl147 »
bmillham wrote:Maybe I'm mis-understanding the documents, but -sel:all says that it unselects all tracks. And it does just that.
It used to is my issue!
