Auto-rip is only getting a partial rip
70tas
Post by 70tas »
Feu de Follet is a DVD I'm having trouble with. Makemkv rips a small portion and terminates without error. Can someone help? I have attached the disc.txt and tree.txt as read in the forum.
Thanks in advance...
Forgot to paste what the GUI sees:
Title information
Comment: D1
Source title ID: 04
Duration: 0:02:07
Chapters count: 2
Segment count: 1
Segment map: 1-2
File name: Feu Follet-D1_t00.mkv
DSDVD0348-tree.txt
(3.71 KiB) Downloaded 480 times
DSDVD0348-disc.txt
(1.92 KiB) Downloaded 473 times
Re: Auto-rip is only getting a partial rip
Are you saying the disk contains more than 5 titles?
Only one exceeds your minimum of 120 seconds.
Ezatoka
Post by Ezatoka »
Try to select another DVD opening mode to see, if that changes anything: viewtopic.php?f=7&t=28541
70tas
Post by 70tas »
Yes, it is only processing one. If you look at the attached .txt files, there are more segments than MakeMKV is processing. I have also tried going through the opening settings, they do not appear to make any difference.
I'm not accustomed to reading the non-log files generated by the component programs, but you're dealing with a disk that contains 5 titles. One was skipped because of errors, three skipped because they were shorter than 120 seconds, and one that was over 120 seconds.
What are you expecting from this disk? There should be a file named makemkv_log.txt that explains this more in human terms.
70tas
Post by 70tas »
Here is how I am interpreting, and I am probably wrong:
VTS_01_0.VOB is the DVD play menu
VTS_01_1.VOB is length 1,048,574KB
VTS_01_2.VOB is length 1,048,547KB
VTS_01_3.VOB is length 1,048,547KB
Debug mode shows:
Debug log started at Mon Oct 24 22:20:07 2022 , written by MakeMKV v1.17.2 win(x64-release)
001005:0000 MakeMKV v1.17.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\70tas/MakeMKV_log.txt
No SDF v090: NECVMWar_VMware_SATA_CD00_1.00_30666360_1012642L311
No auto SDF v090: NECVMWar_VMware_SATA_CD00_1.00_30666360_1012642L311
DEBUG: Code 0 at FP)57'8krEc6"9E\K:121264349
DEBUG: Code 0 at 5iB7,;15sKs-6#4;:121268535
DEBUG: Code 3 at `6CF;l<+`$x9]D6No(y!wmrg:29395310
SDF id v090: NECVMWar_VMware_SATA_CD00_1.00_30666360_1012642L311
DEBUG: Code 0 at NTBO8Wa6>f5=6lTqD:121263199
DEBUG: Code 5 at NTBO8Wa6>f5=6lTqD:121263199
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
003012:0000 Subpicture stream count is 8 in VTS 1
003016:0000 Title #1 was skipped
Title skip vts=1 pgcn=1
003025:0000 Title #2 has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #4 was added (2 cell(s), 0:02:07)
003025:0000 Title #5 has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
VTS_01_4.VOB is length 632,940KB
I can play each of the above in VLC
The rest of the .vob files are small warning segments.
The directory shows:
Volume in drive D is DSDVD0348
Volume Serial Number is 95D4-F4D0
Directory of D:\
01/02/2007 07:58 AM <DIR> VIDEO_TS
01/02/2007 07:58 AM <DIR> AUDIO_TS
0 File(s) 0 bytes
Directory of D:\VIDEO_TS
01/02/2007 07:58 AM <DIR> .
01/02/2007 08:12 AM <DIR> ..
01/02/2007 07:57 AM 14,336 VIDEO_TS.IFO
01/02/2007 07:57 AM 14,336 VIDEO_TS.BUP
01/02/2007 07:57 AM 83,968 VTS_01_0.IFO
01/02/2007 07:40 AM 80,928,768 VTS_01_0.VOB
01/02/2007 07:54 AM 1,073,739,776 VTS_01_1.VOB
01/02/2007 07:55 AM 1,073,739,776 VTS_01_2.VOB
01/02/2007 07:57 AM 1,073,739,776 VTS_01_3.VOB
01/02/2007 07:57 AM 648,130,560 VTS_01_4.VOB
01/02/2007 07:57 AM 83,968 VTS_01_0.BUP
01/02/2007 07:57 AM 18,432 VTS_02_0.IFO
01/02/2007 07:57 AM 155,648 VTS_02_0.VOB
01/02/2007 07:57 AM 17,049,600 VTS_02_1.VOB
01/02/2007 07:57 AM 18,432 VTS_02_0.BUP
01/02/2007 07:57 AM 18,432 VTS_03_0.IFO
01/02/2007 07:57 AM 155,648 VTS_03_0.VOB
01/02/2007 07:57 AM 89,550,848 VTS_03_1.VOB
01/02/2007 07:57 AM 18,432 VTS_03_0.BUP
01/02/2007 07:57 AM 18,432 VTS_04_0.IFO
01/02/2007 07:57 AM 155,648 VTS_04_0.VOB
01/02/2007 07:57 AM 101,031,936 VTS_04_1.VOB
01/02/2007 07:57 AM 18,432 VTS_04_0.BUP
01/02/2007 07:57 AM 12,288 VTS_05_0.IFO
01/02/2007 07:57 AM 24,576 VTS_05_1.VOB
01/02/2007 07:57 AM 12,288 VTS_05_0.BUP
24 File(s) 4,158,734,336 bytes
Directory of D:\AUDIO_TS
0 File(s) 0 bytes
Total Files Listed:
6 Dir(s) 0 bytes free
I'm not sure why it is skipping the main parts of the movie, but again, I am a noobie.
Thank you
Tas
Ezatoka
Post by Ezatoka »
What happens, if you open the DVD manually? (There should be a checkbox for "Open DVD manually") Is track 1 listed with correct length there? What happens, when you enter 1 and click on OK on manual opening mode?
70tas
Post by 70tas »
I get the list, and I select 1: 1/1;
Makemkv responds with:
Open DVD manually : "1: 1/1"
Not sure why; I am backing up the DVD to an ISO now, and I'll try open that way. But VLC plays the title without errors.
