WH16NS60 No Disc Error
Re: WH16NS60 No Disc Error
if it reads DVD and CD, the red laser works. If it does NOT read BD or UHD, the blue(ish) laser is not functioning, which means the drive is bad.
H4rd3n
Hey there.
I also buyed the WH16NS60, flashing the patched 1.3 worked fine, but the drive reads like crap, only one UHD movie out of 6 was read flawless, one wasn't even recognized.
Do you still have the original firmware? Since my drive is new, I think, it's just faulty, but I didn't think about backing up the firmware, before flashing the patched one. I don't want to send it back with the patched firmware, or is that something to not care about? The original flasher from LG only tells me, that version 1.3 it higher is already installed and does nothing.
they dont care if you send it back with different firmware they dont check 99% of the timeH4rd3n wrote: Mon Oct 24, 2022 7:27 am Hey there.
if you want to put it back to stock just use the official lg updater
H4rd3n
Thank you for your reply.
Well, the LG updater doesn't do anything, as I said. Amazon most likely will destroy it anyways. Fun thing: It was sent from the US to Germany and now I have to send it back to the US, Amazon paying
they dont destroy it they sell it as opened box many people have bought the defective ones i returned i have seen some of the defective ones serial numbers posted on threads complaining of errors as i keep the serial numbers bad and good.H4rd3n wrote: Mon Oct 24, 2022 8:15 am Thank you for your reply.
Well, the LG updater doesn't do anything, as I said. Amazon most likely will destroy it anyways. Fun thing: It was sent from the US to Germany and now I have to send it back to the US, Amazon paying![]()
H4rd3n
Now I'm curious, how many drives are defective from the beginning? Are UHD drives that fragile? I want to get a Pioneer UHD external USB drive next, is the return rate as high as for the other drives?
for me 25% of the desktop asus and LG drives were bad.H4rd3n wrote: Mon Oct 24, 2022 8:40 am Now I'm curious, how many drives are defective from the beginning? Are UHD drives that fragile? I want to get a Pioneer UHD external USB drive next, is the return rate as high as for the other drives?
the BU40N has failure rate of 1%-2% for me and its really not the drive that fails its the cheap case usb port most of the time cant wait till they come out with a USB c version
H4rd3n
Hey, I just wanted to thank Billycar11, the LG is on its way back to the seller and I got myself a BDR-XD07TUHD, which works great, though it's loud. Maybe I try another internal LG or maybe Asus in the future for watching movies direct from disc and to have an alternative, should the Pioneer have trouble reading a disc.
And also sorry for hijacking this thread
The pioneers are way quieter than any of the lg or Asus's so they you think that's loud the others would be unbearableH4rd3n wrote: Thu Oct 27, 2022 6:50 pm Hey, I just wanted to thank Billycar11, the LG is on its way back to the seller and I got myself a BDR-XD07TUHD, which works great, though it's loud. Maybe I try another internal LG or maybe Asus in the future for watching movies direct from disc and to have an alternative, should the Pioneer have trouble reading a disc.
And also sorry for hijacking this thread![]()
H4rd3n
Well, the WH16NS60 wasn't that loud, especially inside a PC case with a front door and sound insulation, though louder than my old BDR-209EBK, which is really silent, yes. The external BDR-XD07TUHD on the other side is more like a hair dryer...
TomB19
I am running a pair of WH14NS40 drives and both have stopped detecting discs, occasionally. One has done it more than the other.
The fix has been to shut off the PC. Rebooting will not correct this issue. I shut the power off for a few seconds and everything comes back properly.
I do not believe this is a hardware error.
zittrig
I bought a WH16NS60 produced April 2023 second hand. Offerd was MK 1.02 preinstalled and fine in function.
But first after connection was the expierience that no disc format was readable. Even with flash to any native firmware or another WH16NS60 MK. This was yesterday.
Today at morning after fresh starting the computer, suddenly CD and DVD were readable and BD also. Flashed was native 1.03 (last flash yesterday).
So I've flashed to MK 1.03 and .... 4K was readable without problems.
Great ..... but I've gone to work and after, I started the computer again and flashed down to MK 1.02. Since this action, only CD, DVD and BD were readable.
No 4K. No discover in windows explorer, not in makemkv.
I tried many MK firmware without success.
Funny: With ASUS MK 3.10 a 4K was discover perfectly but ripping only with 1,2 MB/s maximum.
The laser for BD and 4K is the same, isn't it? Why there are problems with 4K?
Can I solve this?
Thanks in advance.
Can I solve this?
Thanks in advance.
Used LG/Asus drives are not recommend usually people are selling their defective ones because they got a pioneer that works way better.zittrig wrote: Thu Jul 04, 2024 7:38 pm I bought a WH16NS60 produced April 2023 second hand. Offerd was MK 1.02 preinstalled and fine in function.
Can I solve this?
Thanks in advance.
The only thing that might help is cleaning the laser by taking the drive apart
Don't clean it with one of those stupid discs with brushes on it they are not effective.
I recommend a q tip with some alcohol and then dry with another side do that 2 times and the drive may not work with 4 K way better.
If not get a pioneer with old fw check the seller section for those with old fw.
zittrig
Thanks Billycar11, but cleaning was without success. But no problem
AsaMan
I seem to also have this issue - it was centered around 4K TV Show disks at first. Most of the time it works; however, lately, more and more 4K disks read, place the title selection screen, then in about 10 seconds I receive "No Disk Error" This seems to happen from the last 2 updates, prior to that I did not have any problems with movies only TV shows. Now with the latest Beta Version Movies are suffering from the same issue.
--On this system I have 2 LG Blu-Ray, 1 LG 4K Blu-Ray and 1 Pioneer BD-07 series 4K drives.
Only the LG and it is patched with the 1.03 F/W
--Any Suggestions? (This drive has always worked find for me after more than 200 4K Disks read.)
Thanks,
Asa
Thanks,
Asa
