Fatal Error v1.6.7
shanghai'd
Fatal Error v1.6.7
Post by shanghai'd » Sat Apr 16, 2011 12:20 am
I am converting Video_TS to MKV for TV series DVDs. I am having a fatal error each time MakeMKV completes one VOB and moves to the next episode VOB.
I am running OSX 10.6.7/2.16 Core 2 Duo
Debug log started at Sat Apr 16 00:16:31 2011 , written by MakeMKV v1.6.7 darwin(x86-release)
001005:0000 MakeMKV v1.6.7 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/Jim/MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL MATSHITA DVD-R UJ-85J FCQ5" opened in DASPI v1.2 mode.
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command 46020..00140 to device 'DASPI:IODASPIService:6002f25a471f3ff1:'
001003:0020 DEBUG: Code 0 at 39c]U=R!S2$5#W}<:213137183
002014:0000 Optical drive "BD-ROM WD Virtual CD 1110 2003" opened in DASPI v1.2 mode.
003002:0000 Calculated BUP offset for VTS #3 does not match one in IFO header.
003028:0000 Title #0 was added (1 cell(s), 0:24:29)
003028:0000 Title #1 was added (1 cell(s), 0:24:31)
003028:0000 Title #2 was added (1 cell(s), 0:24:31)
003028:0000 Title #3 was added (1 cell(s), 0:24:30)
003028:0000 Title #4 was added (1 cell(s), 0:24:36)
003028:0000 Title #5 was added (1 cell(s), 0:24:29)
003028:0000 Title #6 was added (1 cell(s), 0:24:31)
003028:0000 Title #7 was added (2 cell(s), 0:24:30)
003028:0000 Title #8 was added (1 cell(s), 0:24:32)
003028:0000 Title #9 was added (1 cell(s), 0:24:31)
003028:0000 Title #10 was added (1 cell(s), 0:23:38)
003028:0000 Title #11 was added (1 cell(s), 0:23:39)
003028:0000 Title #12 was added (1 cell(s), 0:23:39)
003028:0000 Title #13 was added (1 cell(s), 0:23:40)
003028:0000 Title #14 was added (1 cell(s), 0:23:39)
003025:0000 Title #15 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 451 at juYU9MTz%&gl#zv4$bp[Y:121264257
001003:0020 DEBUG: Code 233 at J5HnDqcbsizfVLBHz7jiP4CK:0
Application exited at Sat Apr 16 00:18:07 2011
Earlier posts have indicated 1.6.5 is more stable. I downloaded and installed, but it would not initialize due to a need for an activation code - any help out there for this?
Re: Fatal Error v1.6.7
Post by mike admin » Sat Apr 16, 2011 10:03 am
shanghai'd wrote:Earlier posts have indicated 1.6.5 is more stable. I downloaded and installed, but it would not initialize due to a need for an activation code - any help out there for this?
Your error is different so 1.6.5 won't help. You can get a current beta code from http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053 . Do you get a problem report dialog when MakeMKV crashes?
shanghai'd
Post by shanghai'd » Sat Apr 16, 2011 10:19 am
I do not get an error code, just the dialog box when it crashes. I have tried to encode files one by one, but when I move to the next file, it also crashes. At present, I am encoding one file, closing MakeMKV, reopening, rescanning, then encoding - very painful.
Is there a dump file beyond my earlier post that would help in debug?
Post by mike admin » Sun Apr 17, 2011 8:07 am
shanghai'd wrote:Is there a dump file beyond my earlier post that would help in debug?
Yes. Please submit full core dump per instructions at http://www.makemkv.com/onlinehelp/dump.html
shanghai'd
Post by shanghai'd » Mon Apr 18, 2011 12:06 pm
Mike,
Sent core dump file via e-mail, as I could not attach to the post
Piercey
Post by Piercey » Mon Apr 25, 2011 3:43 am
Has there been any progress with this error?
Post by mike admin » Mon Apr 25, 2011 10:01 am
Please try version 1.6.8
