DVD Won't Rip In Linux Distros But Will in Windows 10
seperis
Post by seperis » Sun Oct 23, 2022 1:37 am
MakeMKV: 1.17.1 (Windows) and 1.17.2 (Windows, Mint, Solus)
Linux OS: Linux Mint Cinnamon and Solus Budgie
Windows OS: Windows 10
Drives: HL-DT-ST_BE-RE__WH16NS60, HL-DT-ST_BE-RE__WH16NS40
DVD: Scooby Doo/Scooby Doo 2: Monsters Unleashed
On opening MKV, it will start to read the disks and never stops. I clocked 25 minutes on Mint and about 15 on Solus before I gave up. No matter how many times I stop progress or even if I remove the disk and leave it empty or put in another tested disk, it keeps keeping on until I either restart entirely or unplug the drive. I attached all config and the latest log file for each OS; the settings are almost identical except Windows has the Java path explicitly in the configuration. No other disk I have has ever done this, even the really terrible ones. I verified both drives are seemingly fine with other disks, just this one.
It could be a mounting problem, but I can't quite see how; at least one earlier log just showed endless debugs, which is why I first assumed it was a disk problem until Windows opened it immediately with no drama. If more info is needed, I can try again and see what comes up in logs.
MAKEMKV_Data.zip
Zip file with settings for Linux Mint, Solus, and Windows; log files of latest attempts on each OS.
(272.96 KiB) Downloaded 509 times
