Gatorman
#7681 Post by Gatorman » Sat Oct 22, 2022 6:44 pm
RESET_9999 wrote: Sat Oct 22, 2022 6:29 pm
Gatorman wrote: Fri Oct 21, 2022 11:08 pm I'm still working on getting the script to run correctly.
yes, it's not easy to install, I struggled myself.
you have to install python and a couple of modules.
https://www.python.org/downloads/
you can install a module(ijson in that case) by typing this in a cmd window
pip install ijson
Got it! Thanks for your help.
Gatorman
#7682 Post by Gatorman » Sat Oct 22, 2022 6:53 pm
@Reset_9999
Would it be possible to have a video.mkv.measurements file as an input file?
#7683 Post by RESET_9999 » Sat Oct 22, 2022 6:58 pm
6-2-2 can do that.
Gatorman
#7684 Post by Gatorman » Sat Oct 22, 2022 8:04 pm
RESET_9999 wrote: Sat Oct 22, 2022 6:58 pm 6-2-2 can do that.
This workflow allows an already generated .measurements file? It's asking me for a video file. I'll have to get back to my workstation to get the error.
#7685 Post by RESET_9999 » Sat Oct 22, 2022 8:21 pm
ha yes, I introduced a bug for that in the latest versions. you can try the older versions as 1.5.8, and it should work.
will fix next time
kazuma
#7686 Post by kazuma » Sun Oct 23, 2022 10:00 am
reset_9999
the muxing time of shooter and the godfather untouched bluray is very short, and the end TS file is only between 13GB and 17GB. what is the reason for this? (4-1-1)
i've selected the longest mpls file. i'm sure of that.
#7687 Post by RESET_9999 » Sun Oct 23, 2022 1:29 pm
kazuma wrote: Sun Oct 23, 2022 10:00 am i've selected the longest mpls file. i'm sure of that.
I doubt that because I just tried Shooter BD and there are two 20min small playlists and the main movie one.
I took the right one and got a normal 44gb TS.
So either you're out of HDD space on your output path or you selected the wrong playlist.
Gatorman
#7688 Post by Gatorman » Sun Oct 23, 2022 2:24 pm
Does this comparison look typical? HDR10 Resolve generated DV.
https://slow.pics/c/fVBUu802
#7689 Post by RESET_9999 » Sun Oct 23, 2022 2:53 pm
yes, as you can see madvr min_pq is always 0 which makes avg_PQ inaccurate.
Resolve's scene cut detection is also substantially better than madvr. With madVR, there will be (sometimes) one shot very bright and the next one(within the same scene) darker. I never had this issue with Resolve.
kazuma
#7690 Post by kazuma » Sun Oct 23, 2022 8:40 pm
reset_9999
i did it again with shooter. now with screenshots:
https://ibb.co/q1ZL44M
https://ibb.co/6HKkGnk
https://ibb.co/gv1pB4k
#7691 Post by Manixx2020beyound » Sun Oct 23, 2022 9:36 pm
RESET_9999 wrote: Sun Oct 23, 2022 2:53 pm yes, as you can see madvr min_pq is always 0 which makes avg_PQ inaccurate.
I’ve come to the conclusion that if we re analyze a movie that’s already graded scene by scene technically we are producing a diff graded result as well.(bc color decisions are being decided by present graded elements)
& that’s why they are diff types of analysis modes some of us have only experienced 1type of analysis mode.
#7692 Post by RESET_9999 » Sun Oct 23, 2022 9:42 pm
100% non-sense.
L1 metadata generation is just pixels brightness measurement(this is what the dovi L1 plot is). When you set your resolve project correctly you don't touch the original grade. it's like working with the master.
You could export it to 422 and then re-encode it to x265 and it would still be the same grade(unless you start playing with the colors and brightness).
saba30
#7693 Post by saba30 » Mon Oct 24, 2022 8:37 am
Little bug in DoVi_Scripts_1.6.4
7-2-4
Audio file not included, because audio file name set incorrect
14587- Line
:skip.dts
"%eac3to_path%" "%TEMP%THD.mkv" 1: "%TEMP%audio.ac3"
if NOT ["%errorlevel%"]==["0"] pause
:no.dts.encodingg
set audio=%TEMP%audio.ac3
::--------------------------------------------------------------------------------------------MP4.muxing----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
echo muxing into a MP4 profile 8 DoVi file. Be patient, it can take a while. 40min^+ on slow HDD!
"%mp4muxer_path%" --dv-profile %dv.profile% --input-file %BL% --input-file %audio% %comp% %ID% --output-file "%TEMP%DoVi.au.mp4"
::--------------------------------------------------------------------------------------------SUBS----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
if exist "%TEMP%en.forced.srt" if not exist "%TEMP%en.srt" set subtitles_path="%TEMP%en.forced.srt"& goto :er
if not exist "%TEMP%en.srt" if not exist "%TEMP%en.forced.srt" goto :skip.sub
if exist "%TEMP%en.forced.srt" if exist "%TEMP%en.srt" goto :2.sub
#7694 Post by RESET_9999 » Mon Oct 24, 2022 2:14 pm
saba30 wrote: Mon Oct 24, 2022 8:37 am Little bug in DoVi_Scripts_1.6.4
7-2-4
yes I see my mistake...
In next version, I wont use eac3to.exe to demux anymore so that should fix it.
#7695 Post by Manixx2020beyound » Mon Oct 24, 2022 3:34 pm
RESET_9999 wrote: Sun Oct 23, 2022 9:42 pm 100% non-sense.
The meta data results are close but never identical facts.
To get identical, a 12bit true master is necessary,
Also that’s like saying the 8.1 dv/hdr resolve produces is NOT an official 8.1?
Our experience with 8.1 only came about with xml/rpu (quietvoid)
