MD-8107-U3 ARCHGON LibreDrive/Flash
darkjak444
Post by darkjak444 »
I can't get makemkv to read the 4k disc. I've tried to flash the optical drive but it just produces that error. I looked on here and YT for some help but nothing seemed to work. How do I get makemkv to read the 4k disc? Thanks.
Re: MD-8107-U3 ARCHGON LibreDrive/Flash
Use the newer flasher. Most likely "enc" has to be checked to flash it. Look here:
viewtopic.php?f=16&t=22896
darkjak444 wrote: Fri Oct 21, 2022 6:17 pm I can't get makemkv to read the 4k disc. I've tried to flash the optical drive but it just produces that error. I looked on here and YT for some help but nothing seemed to work. How do I get makemkv to read the 4k disc? Thanks.
Your 1.02 firmware is encrypted. Either check enc or use the latest version of SDFtool Flasher which will automatically apply the encrypted flag.
Also, I recommend you use either BU40N 1.00 or 1.03-MK firmware. Don't use 1.04-MK as it's junk.
