Fatal error in 1.6.6/1.6.7 when opening blu-ray drive
Locked
#1 Post by mike admin » Fri Apr 15, 2011 9:50 am
A change was introduced in MakeMKV v 1.6.6 that could cause a program crash ("Fatal error occurred") on Windows with certain BD-ROM drives. If you experience this error please do the following.
- Download update ZIP file attached to this post
- Launch Windows explorer and navigate to folder where MakeMKV is installed
- Ensure that MakeMKV is not running
- Delete two files from that folder - libdriveio.dll and libdriveio64.dll
- Copy two files from attached archive in place of deleted ones.
If this update fixes the error for you, please reply in this thread with the following information:
- Manufacturer and model of your BD-ROM drive
- Is it external or internal drive
- If external, the model of USB enclosure
If this update didn't fix the error, please submit the dump per instructions at http://www.makemkv.com/onlinehelp/dump.html
dig2112
Re: Fatal error in 1.6.6/1.6.7 when opening blu-ray drive
#2 Post by dig2112 » Fri Apr 15, 2011 1:08 pm
This update corrected the problem for me. Here is my drive info:
Drive Model: Polaroid BD162
Drive Type: External USB 2.0
Thank you.
losttourist
#3 Post by losttourist » Fri Apr 15, 2011 7:52 pm
This worked, thanks:
External Drive: Plextor BD-ROM PX-B120U
WCVanHorne
#4 Post by WCVanHorne » Sat Apr 16, 2011 12:26 am
Had this problem in 1.6.6 and 1.6.7.
Haven't finished extracting a BluRay yet but it has made it past the disc analysis stage where it was crashing before and seems to be trucking OK on extraction; however it seems slower than normal or gears down occasionally (perhaps some extra debugging code in the temporary patch?).
Drive: Liteon iHOS104 WL0B
Type: External
Enclosure: NexStar DX NST-530SU (Using eSATA interface)
dhstraayer
#5 Post by dhstraayer » Sat Apr 16, 2011 12:48 am
As reported by v1.6.7
Manufacturer: ATAPI
Product: iHOS104
Revision: WL0D
S/N: 3775504065 306021501642
Type: internal SATA
Brand: ?Can't remember. Maybe one of the big Korean companies
Works now, fixed the bug.
jbunsarnett
#6 Post by jbunsarnett » Sat Apr 16, 2011 7:15 am
Fixed it for me!
I have an internal ATAPI BD O DH4O3S ATA
Thanks for all the hard work you have put into MAKEMKV.
frankhald
#7 Post by frankhald » Tue Apr 19, 2011 9:25 pm
Makemkv worked fine for me until I installed Visual Studio 2010 Professional. Had VS2005 installed before and Makemkv workedfine.. Your updates made Makemkv work again. Thanks guys .
My bluray is an external USB drive: Plextor PX-B120U
krell
#8 Post by krell » Wed Apr 20, 2011 6:28 am
Fixed my error as well.
LITE-ON Black 4X BD-ROM 8X DVD-ROM 32X CD-ROM SATA Internal 4X Blu-ray Reader Model iHOS104-06 - OEM
http://www.newegg.com/Product/Product.a ... 6827106325
imbasti
#9 Post by imbasti » Wed Apr 20, 2011 11:10 am
Batman the Movie didn't work before but does work now. Thank you!
Plextor PX-B120U USB2.0
Dikampi
#10 Post by Dikampi » Wed Apr 20, 2011 2:35 pm
Worked.
Atapi iHOS104 ATA Device WL0D Serial ATA SATA 150
Thanks :D
res0nshn
#11 Post by res0nshn » Sat Apr 23, 2011 1:47 am
:D thank you for all your help it worked for too Asus drw-24b1lt drive.
jcain
#12 Post by jcain » Sun Apr 24, 2011 7:59 pm
Fixed my issue BD-ROM ATAPI iHOS104 WLOD (Lite-on internal) Speed tanked a little after this patch.
Thanks. Wish I saw this thread sooner!
#13 Post by mike admin » Mon Apr 25, 2011 9:30 am
1.6.8 is available for download with this problem fixed.
Locked
