kazuma
reset_9999
what is the solution for untouched blurays for series? like game of thrones? will 4-1-1 work in this situation? there are 3 episodes per bluray. what is the best solution for this?
yes, the renaming is to deal with special characters and mkvmerge but indeed I forgot about the path.
Will correct in the next version but the code should be:
rename %input% 1%fileext%& set input="%filepath%1%fileext%"
%mkvmerge_path% --output ^"%TEMP%chunk.mkv^" --compression 0:none ^"^(^" ^"%input%^" ^"^)^" --split parts:00:00:00-00:01:00
%mkvextract_path% "%TEMP%chunk.mkv" tracks 0:"%TEMP%el.chunk.hevc"
set DV="%TEMP%el.chunk.hevc"
rename %input% "%filename%%fileext%"
Yes I guess you can do it with 4-1-1 one episode at a time.kazuma wrote: Wed Oct 19, 2022 7:46 pm reset_9999
FrostByte
Excellent. Thanks again.RESET_9999 wrote: Wed Oct 19, 2022 7:50 pmyes, the renaming is to deal with special characters and mkvmerge but indeed I forgot about the path.
rename %input% 1%fileext%& set input="%filepath%1%fileext%" %mkvmerge_path% --output ^"%TEMP%chunk.mkv^" --compression 0:none ^"^(^" ^"%input%^" ^"^)^" --split parts:00:00:00-00:01:00 %mkvextract_path% "%TEMP%chunk.mkv" tracks 0:"%TEMP%el.chunk.hevc" set DV="%TEMP%el.chunk.hevc" rename %input% "%filename%%fileext%"
kazuma
how? there are 3 episodes on one bdmv file. i must select the 3 longest mpls files each by each i think?RESET_9999 wrote: Wed Oct 19, 2022 7:52 pmYes I guess you can do it with 4-1-1 one episode at a time.kazuma wrote: Wed Oct 19, 2022 7:46 pm reset_9999
yes i think sokazuma wrote: Wed Oct 19, 2022 10:07 pm i must select the 3 longest mpls files each by each i think?
Mrmorrison
Good evening.
I just signed up to this forum just to thank Reset_9999 (and everyone else who contributed) for making available to everyone the great work that has been done to get Dolby Vision on various devices.
Thank you very much from a happy owner (now even more
) of x800m2.
kazuma
what is the advantage of the sony x800 compared with my lg c9 internal player? can it play mkv dolby vision? i know there is a tabel on reset_9999 signature, but i was curious. i can buy a sony x800 for a good price. i'm not using pyshical discs. but is there a advantage-bump for dolby vision playback?
Gatorman
All of my recent DaVinci Resolve generated RPUs have a min_pq value of 0. This includes variable aspect ratio files as well as cropped files. Am I doing something wrong?
you're welcomeMrmorrison wrote: Thu Oct 20, 2022 2:19 pm Good evening.
FEL files always work and are 100% stable.
Did you plot L1 ? because if you just look at a random frame with the dovi_tool it can be hard to find one.Gatorman wrote: Thu Oct 20, 2022 10:06 pm All of my recent DaVinci Resolve generated RPUs have a min_pq value of 0. This includes variable aspect ratio files as well as cropped files. Am I doing something wrong?
If you did your blanking(or timeline resolution) correctly it should not be always 0
you can also check in resolve:
left = blanking
Gatorman
Bug in Workflow 1-1?
when your two inputs have the same filename it causes conflict. just rename 1
EDIT: fixed in 1.6.3
Gatorman
I can see the values changing within Resolve.RESET_9999 wrote: Thu Oct 20, 2022 10:15 pmDid you plot L1 ? because if you just look at a random frame with the dovi_tool it can be hard to find one.Gatorman wrote: Thu Oct 20, 2022 10:06 pm All of my recent DaVinci Resolve generated RPUs have a min_pq value of 0. This includes variable aspect ratio files as well as cropped files. Am I doing something wrong?
I'm still working on getting the script to run correctly.
kazuma
reset_9999 deserves his own topic with his revolutunary tool. it's sad for newcomers to start in this topic that is already outdated.
yes, it's not easy to install, I struggled myself.
you have to install python and a couple of modules.
https://www.python.org/downloads/
you can install a module(ijson in that case) by typing this in a cmd window
pip install ijson
