makemkvcon, Linux: How to remux a DVD or BD backup folder?
BD-BD-BD
Post by BD-BD-BD » Wed Oct 19, 2022 4:39 pm
I haven't found a way to remux a loose folder with the CLI build; the instructions has a related example:
Copy all titles from first disc and save as MKV files:
makemkvcon mkv disc:0 all c:\folder
I'm not copying from a disk, but a local disk backup directory. I've tried running:
makemkvcon --robot mkv /path/to/the/DVD/backup all /the/output/path
..and some variations, the process fails. I'm I only missing a prefix before '/path/to/the/DVD/backup' or is this functionality unavailable in the CLI app?
I've installed MakeMKV from Flathub — the actual command to launch the CLI version is:
flatpak run --command=makemkvcon com.makemkv.MakeMKV
EDIT: The OP has been edited for clarity, refer to the next comment for functional makemkvcon commands.
EDIT-2: Cleaned the post title.
BD-BD-BD
Re: makemkvcon: How to remux (into .mkv) a DVD backup folder?
Post by BD-BD-BD » Sun Jul 30, 2023 12:58 pm
I was missing the `file:` prefix: example commands for both DVD and BD:
makemkvcon mkv --robot file:/mnt/media/DVD-folder/VIDEO_TS.IFO all /the/output/path
makemkvcon mkv --robot file:/mnt/media/BD-folder/BDMV/index.bdmv all /the/output/path
Extracts all titles from a DVD or BD directory. See the manual for other input options:
Source specification:
iso:<FileName> - open iso image <FileName>
file:<FolderName> - open files in folder <FolderName>
disc:<DiscId> - open disc with id <DiscId> (see list Command)
dev:<DeviceName> - open disc with OS device name <DeviceName>
BD-BD-BD
Post by BD-BD-BD » Tue Mar 19, 2024 10:50 am
The syntax appears to have changed somewhat recently — now makemkvcon doesn't detect nor require the 'file:' parameter. A sample command (Linux) to rip a BD folder:
makemkvcon mkv --robot ~/Videos/discs/BD/BDMV/index.bdmv all ~/Videos/discs/remux/ | less
I tested with a DVD and BD, both decrypted to a folder (possibly using another program).
MakeMKV 1.17.6 (Flatpak)
