Missing title & disk errors - Supernatural Season 1
DannyBoy999
#1 Post by DannyBoy999 » Fri Apr 15, 2011 3:36 pm
Getting the following error on Supernatural Season 1, disk 3:
MakeMKV v1.6.7 win(x86-release) started
Debug logging enabled, log will be saved as C:\Users\Dan/MakeMKV_log.txt
DEBUG: Code 101019395 at ,nmBea*mk2Xu"MW[:x:29395678
DEBUG: Code 101019395 at ,nmBea*mk2Xu"MW[:x:121262049
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'DVD+R-DL LITE-ON DVDRW LH-20A1H LL0A' at offset '1048576'
Title #0 was added (23 cell(s), 2:03:19)
Title #1 was added (8 cell(s), 0:41:02)
Title #2 was added (8 cell(s), 0:41:25)
Title #3 was added (7 cell(s), 0:40:52)
Title #4 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
For some reason every disk shows an extra title which when ripped is all the episodes added together. But in this case its only showing 3 of the 4 episodes (plus those 3 episodes added together as title 0). There are 4 episodes on this disk so I should be seeing an extra 40 minute title.
Re: Missing title & disk errors - Supernatural Season 1
#2 Post by mike admin » Sat Apr 16, 2011 9:45 am
Please send IFO files per http://www.makemkv.com/faq/item/8 . MakeMKV displays each DVD title as separate title in selection, which means that your DVD is authored this way - each episode as a title and all episodes combined together.
