kazuma
Post by kazuma »
reset_9999 with the untouched bluray of sound of metal i got his error? do you know why? my D station is a extern 5TB hdd 2,5inch connected with a usb hub without power supply. is this maybe the problem that occurs?
https://ibb.co/v4YRQHf
well, the error says there is no DV on the disc...
DISC INFO:
Disc Title:     Sound.of.Metal.2019
Disc Size:      91,665,747,092 bytes
Protection:     AACS2
Extras:         Ultra HD, BD-Java
BDInfo:         0.7.5.9 (compatible layout created by DVDFab 12.0.8.7)
PLAYLIST REPORT:
Length:                 2:00:58.668 (h:m:s.ms)
Total Bitrate:          100.24 Mbps
VIDEO:
Codec                   Bitrate             Description
MPEG-H HEVC Video       87287 kbps          2160p / 23.976 fps / 16:9 / Main 10 @ Level 5.1 @ High / 4:2:0 / 10 bits / 1000nits / HDR10 / BT.2020
AUDIO:
Codec                           Language        Bitrate         Description
DTS-HD Master Audio             English         3737 kbps       5.1 / 48 kHz / 3737 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
DTS-HD Master Audio             French          3787 kbps       5.1 / 48 kHz / 3787 kbps / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
Looks like the new appleTV still wont support profile 8....
https://www.apple.com/apple-tv-4k/specs/
kazuma
Post by kazuma »
RESET_9999 wrote:
Tue Oct 18, 2022 8:13 pm
DISC INFO:
Protection:     AACS2
PLAYLIST REPORT:
VIDEO:
AUDIO:
very stupid of me your're right haha.
Donpoku
Post by Donpoku »
RESET_9999 wrote:
Tue Oct 18, 2022 11:13 am
With expensive Hd fury devices. At this point , it's better to get the Dune player instead of the Zidoo.
Well guess what? Just got the dune HD real vision 4k and same'Dolby vision Bt2020' on my lg c6 infobar(top left) on any DV file played. So maybe realtek 1619/lg oled bug.
As My oppo203/MINIX u222 doesn't have this "bt2020" on DV files, can anyone with a rtk1619(Zidoo/dune/zappiti) & an lg oled check theirs so we can report it.
Many thanks.
andyy
Post by andyy »
RESET_9999 wrote:
Tue Oct 18, 2022 8:26 pm
Bruhh I really like AppleTV as my main streaming device but they're really making it hard for people to like them. I think the few titles Hulu has in DV are Profile 8. How do you watch these with Apple TV? Lol
I was reeeaally hoping they'd fix this for this next-gen model. The fake P5 is nice when you really need it but doesn't really work as a long-term solution for me.
FrostByte
Post by FrostByte »
reset_9999 Whenever I do a quick RPU info summary (2-3) on a DV mkv the script renames the input file to "1.mkv". Is there a way to prevent it from renaming the original files? Thanks
FB
FrostByte wrote:
Wed Oct 19, 2022 9:43 am
FB
It's supposed to instantly rename it as the original when its done ??
FrostByte
Post by FrostByte »
RESET_9999 wrote:
Wed Oct 19, 2022 10:38 am
FB
That's what I was hoping :)
FrostByte
Post by FrostByte »
FB
It must be the spaces in my paths. My movies are all in folders like the example below for Emby
\Movies\The Last Witch Hunter (2015)
I just added quotes to the first part of the rename line to below and it works now.
rename "%filepath%1%fileext%" "%filename%%fileext%"
kazuma
Post by kazuma »
reset_9999
what is the solution for untouched blurays for series? like game of thrones? will 4-1-1 work in this situation? there are 3 episodes per bluray. what is the best solution for this?
FrostByte wrote:
Wed Oct 19, 2022 7:30 pm
yes, the renaming is to deal with special characters and mkvmerge but indeed I forgot about the path.
Will correct in the next version but the code should be:
rename %input% 1%fileext%& set input="%filepath%1%fileext%"
%mkvmerge_path% --output ^"%TEMP%chunk.mkv^" --compression 0:none ^"^(^" ^"%input%^" ^"^)^" --split parts:00:00:00-00:01:00
%mkvextract_path% "%TEMP%chunk.mkv" tracks 0:"%TEMP%el.chunk.hevc"
set DV="%TEMP%el.chunk.hevc"
rename %input% "%filename%%fileext%"
kazuma wrote:
Wed Oct 19, 2022 7:46 pm
reset_9999
Yes I guess you can do it with 4-1-1 one episode at a time.
FrostByte
Post by FrostByte »
RESET_9999 wrote:
Wed Oct 19, 2022 7:50 pm
Excellent. Thanks again.
kazuma
Post by kazuma »
RESET_9999 wrote:
Wed Oct 19, 2022 7:52 pm
reset_9999
how? there are 3 episodes on one bdmv file. i must select the 3 longest mpls files each by each i think?
