LibreDrive for Pioneer drives
AlamosIT
Post by AlamosIT »
Blackened2687 wrote: Sun Oct 16, 2022 9:38 pm
AlamosIT wrote: Sun Oct 16, 2022 6:10 pm Hello! I use LibreDrive and MKV with my Hitachi-LG BH16NS55 on my desktop PC and it works like a charm (thank you!).
I've noticed only now that also the BD drive on my old laptop could have LibreDrive as well. How can I make it work?
(I know that this drive will never be able to read UHD Blu-Ray)
In order for it to work it will be necessary for Mike to add your drive to the LibreDrive database.
By the way, there is a WIP project for crossflashing non-UHD to so-called "UHD-friendly" drives, and your drive's hardware should be capable to work with BDR-UD04 firmware. I will need a memory dump from your drive to add its support, please check your PM for further instructions. Thanks in advance!
I've successfully dumped the firmware from my drive as your instruction said, but I can't directly reply to your PM because I joined the forum only yesterday and is said I'm not authorised yet.
Here there are the files: https://we.tl/t-2tKFtK2BJa
Blackened2687
Post by Blackened2687 »
AlamosIT wrote: Mon Oct 17, 2022 8:00 am Here there are the files
Thank you very much! Everything is OK, I will write you a message when I'm done. :D
AlamosIT
Post by AlamosIT »
Blackened2687 wrote: Mon Oct 17, 2022 8:51 am Thank you very much! Everything is OK, I will write you a message when I'm done. :D
Thank you! <3
techguymaxc
Post by techguymaxc »
I have a BDR-212V that isn't reading 4k discs, status is "No disc inserted". The drive info window indicates LibreDrive is enabled for the drive. Standard blu-rays read fine, have tried multiple UHD discs. Internet access for MakeMKV is enabled.
I switched to this drive from a flashed WH16NS40 because it was having issues reading triple layer discs and I heard the Pioneer drives handled these discs better.
Here is the info from the drive:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.00
Serial number:
Firmware date: 2020-08-07
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8F00
Firmware version: 1.00/ID06
Edit: I am reading now that I needed to purchase a drive with a "U" in the model. Wish I had known that before. Guess I'll just revert to the LG drive and return the Pioneer.
techguymaxc
That's great news! Unfortunately for me, I've already initiated the return of the BDR-212V and ordered a BDR-X13UBK :lol:
Kurtz
Post by Kurtz »
Hello, please add support for this drive when possible.
Product: BD-RW BDR-XD08U
Revision: 1.00
Serial number: *****
Firmware date: 2022-04-03
Highest AACS version: 76
Drive platform: Pioneer RS9331
Firmware version: ID05
For searchability, the product name is BDR-XD08UMB-S.
Also, how do I know if my sdf file has been updated? I looked in my \.MakeMKV folder and there's a _private_data.tar file and some other files, but no sdf.bin. Is that normal?
Thanks.
Kurtz wrote: Sun Oct 30, 2022 11:06 pm Hello, please add support for this drive when possible.
Revision: 1.00
Thanks.
Your drive and firmware is on the list of supported drives. Click "Settings" "General" and mark the checkbox "Enable Internet access". Then if you insert a Disc you should see in the status window that Makemkv updates it's informations. Does the drive work now with LIbredrive?
Kurtz
Post by Kurtz »
Coopervid wrote: Mon Oct 31, 2022 9:19 am
Revision: 1.00
Thanks.
"Enable Internet access" was already checked. I just inserted a disc and then attempted to open it in MakeMKV. The drive information still looks the same as above, ie, it doesn't have LibreDrive enabled.
You should write a PM to mike admin. He can remotely dump your firmware to his server and then add support. It is most likely a different version of 1.00 that is already supported.
Djluis18
Post by Djluis18 »
Hey Please add support for the following drive when possible.
OS device name: F:
Product: BD-RW BDR-TD04A
Revision: 1.00
Serial number: KFDL022768WL
Firmware date: 2011-04-18
Highest AACS version: 30
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS1040
Firmware version: ID73
Djluis18 wrote: Mon Oct 31, 2022 10:41 pm Hey Please add support for the following drive when possible.
OS device name: F:
Revision: 1.00
Just so you know, even if LibreDrive becomes enabled for this model, being so old, it will never read UHD discs.
Djluis18
Post by Djluis18 »
MartyMcNuts wrote: Mon Oct 31, 2022 10:49 pm
I know but I already have it with me and I don't need UHD for the moment.
Djluis18 wrote: Mon Oct 31, 2022 11:04 pm
Also, just so you know, it took 2 years for any Pioneer drives to become libredrive enabled, so the fact that your drive's status is: "Possible but very unlikely to happen" would most likely mean several years (if ever) before libredrive is enabled.
Just saying, don't wait for it. If you want libredrive compatibility anytime soon, get yourself a new drive.
techguymaxc
Got my new BDR-X13UBK drive and it isn't reading 4k discs. It was my understanding that Pioneer drives containing "U" in the model number all have UHD reading capability, but I have tried several discs and none read, same as the last Pioneer drive that didn't have a "U". When I open MakeMKV with a disc already in the drive nothing happens. When I put a new disc in, MakeMKV sees a disc has been inserted and attempts to read, then gives up after a minute and says "No disc inserted".
Here's the status window info:
Product: BD-RW BDR-X13
Revision: 1.01
Serial number:
Firmware date: 2022-02-18
Drive platform: Pioneer RS9400
Firmware version: ID56
