ancient
Post by ancient »
Thanks for the confirmation Billy, appreciated.
Out of curiosity...if I had selected the option, would that have broken the drive? or wouldn't it have made any difference?
ancient wrote: Wed Oct 05, 2022 7:54 pm Thanks for the confirmation Billy, appreciated.
Nah wouldn't have hurt it you would just have a different bootloader makes 0 different
ancient
Post by ancient »
Thank you my friend, appreciated.
Seraphic-
Post by Seraphic- »
Was able to secure a BDR-212UBK to replace a much older BDR-2209 purchased several years ago.
Was there any reason to keep the BDR-2209 or just put up for sale?
Both drives come up full supported LibreDrives, but the 212-UBK supports UHD while the 2209 does not.
https://www.pioneerelectronics.com/PUSA ... BDR-212UBK
https://www.pioneerelectronics.com/PUSA ... s/BDR-2209
Seraphic- wrote: Sun Oct 16, 2022 4:25 am Hello,
Keep it a pioneer flash tool is coming and that drive maybe supported to make read UHD
Seraphic-
Post by Seraphic- »
Billycar11 wrote: Sun Oct 16, 2022 10:19 pm
A simple firmware update can really make it read unsupported discs like UHD?
Also, somewhat off-topic, but do libredrives allow the drive to also read Blu-Ray discs from game consoles like PS 3/4/5 for example?
Seraphic- wrote: Mon Oct 17, 2022 3:41 am
yeah thats what we been doing to the LGs the whole time.
i know the BU40N can copy ps3 games not sure about 4 and 5 the other lg flashed drives i assume can to.
but its not because of libredrive it is its own thing.
Seraphic-
Post by Seraphic- »
Billycar11 wrote: Mon Oct 17, 2022 5:24 am
Neat, that is interesting.
Put the same PS5 game into both of these Pioneer but just acted like nothing was inserted and came up empty in MKV.
AvengerInfinite
Post by AvengerInfinite »
I selected 4 models which are available in my country.
the LG - BU40N.ARAA10B or LG BH16NS55 or LG WH16NS40 or WP50NB40 (external)
which one will be the easiest one to flash for UHD ripping and burning (BRXL mainly) ? which one is the more efficient / reliable ?
thanks in advance and thanks for this good guide :)
AvengerInfinite wrote: Mon Oct 17, 2022 4:04 pm Hi,
Go for the BU40N or the BH16NS55. NS40 might be with old chip that is not compatible and the WP50NB40 might be tricky to flash. The sellers in this forum say the BU40N is the most reliable and best for 3-layer discs.
AvengerInfinite
Coopervid wrote: Mon Oct 17, 2022 5:08 pm
so let's try the BU40N :) thanks for your quick answer
Mr_Orange
Post by Mr_Orange »
I have a BH16NS55 flashed to WH16NS60 and have had no problems at all.
Mr_Orange wrote: Mon Oct 17, 2022 8:56 pm
Me, too. But I had also a drive that died. Now I have 2 LG BH16NS5 flashed to BH16NS60 1.02 and WH16NS60 1.03.
AvengerInfinite
so the BU40N will arrive and I need a case :) which one do you recommend ? I saw the list but there are not available (or not at a normal price) in my country. (FR)
thank you for your advice in advance
AvengerInfinite wrote: Tue Oct 18, 2022 4:36 pm Hi,
You can order in Germany:
https://www.amazon.de/Vantec-3-0-Slim-O ... r=8-1&th=1
If flashing in the enclosure is not important for you you can also try this:
https://www.amazon.de/techPulse120-exte ... C91&sr=8-3
ou plus chere en France:
https://www.amazon.fr/techPulse120-Bo%C ... 75&sr=8-17
