LibreDrive for Pioneer drives
FrankInUtah
#301 Post by FrankInUtah » Sat Aug 20, 2022 6:05 pm
TeddyRaspin wrote: Fri Jul 29, 2022 3:52 pm Update it to 1.02 firmware version.
I'd also like to thank you TeddyRaspin. I have a pair of the same drives (Pioneer BDR-212U 1.00), and the update to 1.02 did the trick :-)
T0biasCZe
#302 Post by T0biasCZe » Wed Aug 24, 2022 2:48 pm
Hi i have Pioneer BDR-209EDK with original firmware RS8600 and it should be supported, but when i insert UHD movie, it says No disc inserted. Does the firmware need patching?
#303 Post by Woodstock » Wed Aug 24, 2022 4:13 pm
No, the drive needs replaced with something that is UHD-compatible. According to the firmware, your drive was made back during the transition period to UHD capability, and it is from before that.
It is unlikely that it has the capability to read UHD disks, and does not report that in the status. It has OTHER capabilities though.
T0biasCZe
#304 Post by T0biasCZe » Thu Aug 25, 2022 5:39 am
i though since it can read BDXL disks it could also read uhd movies...
What are the "other capabilities"?
#305 Post by Billycar11 » Thu Aug 25, 2022 5:42 am
T0biasCZe wrote: Thu Aug 25, 2022 5:39 am i though since it can read BDXL disks it could also read uhd movies...
getting around aacs revokes that's all
bultom
#306 Post by bultom » Tue Sep 06, 2022 1:45 am
Great !
Since my last come my BRXL won't accept Libredrive , and i had really poor chance to see it myself on day
But today i downloaded last version of MakeMK and my UHD Drive
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.01
Is supported without flashing rom :O
Drive platform: RS8F01
Firmware version: 1.01/ID43
top images 2019
Great work :P
Southrop
#307 Post by Southrop » Tue Sep 27, 2022 9:24 am
I have a BDR-XD07 drive which is listed in the SDF.bin, but I still get told that LibreDrive is not yet enabled for my device. Is this because the revision number is 1.01 which doesn't appear in the SDF.bin?
Product: BD-RW BDR-XD07
Revision: 1.01
Serial number: [snip]
Firmware date: 2018-12-03
Highest AACS version: 78
Drive platform: Pioneer RS8D30
Firmware version: ID36
Disc Information
Label: BDROM
Timestamp: 2022-08-29 17:18:11
Protection: AACS v78
Data capacity: 43.46 Gb
Disc type: BD-ROM
Number of layers: 2
#308 Post by Coopervid » Tue Sep 27, 2022 10:35 am
Yes. You will have to update your firmware. To do so you need to download the newer firmware from the Pioneer web site.
Please be aware that your drive doesn't support UHD discs.
Drudenhaus
#309 Post by Drudenhaus » Fri Sep 30, 2022 5:27 am
Would it be possible to add support for the BDR-XD08 ? Here's mine (doesn't detect the disc):
OS device name: /dev/sr1
Product: BD-RW BDR-XD08
Revision: 1.00
Serial number: xyz
Firmware date: 2022-04-03
Highest AACS version: 65
Drive platform: Pioneer RS9330
Firmware version: GENE
Debug log:
Debug log started at Fri Sep 30 04:59:49 2022 , written by MakeMKV v1.17.1 linux(x64-release)
001005:0000 MakeMKV v1.17.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file:///some/dir/path/MakeMKV_log.txt
Network access is ENABLED, CURL version 7.84.0/(NSS/3.83) OpenSSL/1.1.1q/1.47.0 (x86_64-pc-linux-gnu) , proxy server not set.
001003:0020 DEBUG: Code 0 at ^aoCY_?pF2N[RTPtazEj{e:29393631
No  SDF v08f: PIONEER_BD-RW___BDR-XD08_1.00_BFDL000188UC
SDF id v08f: PIONEER_BD-RW___BDR-XD08_1.00_BFDL000188UC
No  SDF v08f: HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_K1287IF2138
SDF id v08f: HL-DT-ST_BDDVDRW_GGC-H20L_1.03_20080515123456_K1287IF2138
sdftool
user@hostname ~ $ sdftool -l
Found 2 drives(s)
00: dev_21:5, /dev/sr1, /dev/sr1
01: dev_21:3, /dev/sr0, /dev/sr0
user@hostname ~ $ sdftool --info -d /dev/sr1
SDF.bin version: 0x008D
Drive Tool SDF present
Drive Specific SDF not present
Identification SDF present
8000:LibreDrive Information
8013:Status
8001:Drive platform
:Pioneer RS9330
8003:Firmware version
:GENE
pioneer:SAT :9330:GENE:RAL :PIONEER :BD-RW   BDR-XD081.00: 22/04/03  :-
AlamosIT
#310 Post by AlamosIT » Sun Oct 16, 2022 6:10 pm
Hello! I use LibreDrive and MKV with my Hitachi-LG BH16NS55 on my desktop PC and it works like a charm (thank you!).
I've noticed only now that also the BD drive on my old laptop could have LibreDrive as well. How can I make it work?
(I know that this drive will never be able to read UHD Blu-Ray)
Blackened2687
#311 Post by Blackened2687 » Sun Oct 16, 2022 9:38 pm
AlamosIT wrote: Sun Oct 16, 2022 6:10 pm Hello! I use LibreDrive and MKV with my Hitachi-LG BH16NS55 on my desktop PC and it works like a charm (thank you!).
In order for it to work it will be necessary for Mike to add your drive to the LibreDrive database.
By the way, there is a WIP project for crossflashing non-UHD to so-called "UHD-friendly" drives, and your drive's hardware should be capable to work with BDR-UD04 firmware. I will need a memory dump from your drive to add its support, please check your PM for further instructions. Thanks in advance!
Drudenhaus
#312 Post by Drudenhaus » Mon Oct 17, 2022 5:01 am
Blackened2687 wrote: Sun Oct 16, 2022 9:38 pm
Could you shoot me the info on how to take and submit a memory dump from my BDR-XD08 as well?
Blackened2687
#313 Post by Blackened2687 » Mon Oct 17, 2022 6:27 am
Drudenhaus wrote: Mon Oct 17, 2022 5:01 am Could you shoot me the info on how to take and submit a memory dump from my BDR-XD08 as well?
Which exact model do you have? Right now I need a dump from BDR-XD08BK/SV/GL, marketed for Japan.
Drudenhaus
#314 Post by Drudenhaus » Mon Oct 17, 2022 6:45 am
Blackened2687 wrote: Mon Oct 17, 2022 6:27 am
BDR-XD08
https://www.pioneerelectronics.com/PUSA ... /BDR-XD08B
None of the device IDs match the one you mentioned. Debug and sdftool output are a couple posts up.
Blackened2687
#315 Post by Blackened2687 » Mon Oct 17, 2022 6:53 am
Drudenhaus wrote: Mon Oct 17, 2022 6:45 am BDR-XD08
Thanks, I already have the dump from this version (GENERAL kernel type). Wait for Mike to add its support to LibreDrive.
