Brave
birdman
Brave
#1 Post by birdman » Sat Apr 18, 2015 6:19 am
Hello, I am having a go with backing up Brave from BluRay. When first opening the disc, I am presented with 3 different files, one of which is labeled (Primary Title). I have tried a couple different approaches (change title length, mix and match titles) and the result is always the same: Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '6459555840'
Here is full log:
Debug log started at Sat Apr 18 02:35:15 2015 , written by MakeMKV v1.9.2 darwin(x86-release)
001005:0000 MakeMKV v1.9.2 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/jonathan/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE MATSHITA BD-MLT UJ267AM 1.00d" opened in OS access mode.
001003:0020 DEBUG: Code 3758097095 at RL73P_bQNi$-|%=l\=3,/c5qL:29395540
002010:0000 Optical drive "BD-ROM WD Virtual CD 1110 1030" opened in OS access mode.
002015:0000 It's highly recommended to install DASPI kernel extension to improve performance.
005054:0000 Evaluation version, evaluation period expired 3 day(s) ago
005051:0404 Evaluation period has expired. Please purchase an activation key if you've found this application useful. You may still use all functionality for a few days.
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
DCE=3S1JZriC9yjks3y+lKlAdwAMImIxsJ6Anqg/ozf0G8FA7cMlfECs2Uyg8ak1HJxMscfO2wQ3AhnwJoW/fpmRab/ktymF2Nb51f0d/kZhhQLTZTwDbl/fGiCATysxbfHHdOEtItGdblE8bB5HckJvDYCI61d/8nAtIg==
DCE=e/odaacZPQWqR1tDBopXLzktsKX+hkGUvb0LddV9YteADZgIYgEyP1rEPpJSSXlDlmnyQl78rzosyix4QtxAlSPoyCf4qpDavETGdiWqhkMkQgkwo6RQOR8Z6p0MR7tqrrwazMjJl+4/TtEYtAlNBGFAAWQHpE8GsA==
DISCID=DD0217385E8A7AA2BE5525BFECFD43FD76977F68
003307:0000 File 00203.mpls was added as title #0
003307:0000 File 00204.mpls was added as title #1
003307:0000 File 00205.mpls was added as title #2
003307:0000 File 00206.mpls was added as title #3
003307:0000 File 00207.mpls was added as title #4
003307:0000 File 00209.mpls was added as title #5
003307:0000 File 00210.mpls was added as title #6
003307:0000 File 00211.mpls was added as title #7
003307:0000 File 00212.mpls was added as title #8
003307:0000 File 00213.mpls was added as title #9
003307:0000 File 00214.mpls was added as title #10
003025:0000 Title #00215.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00020.mpls was added as title #11
003025:0000 Title #00070.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00073.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00800.mpls was added as title #12
003307:0000 File 00216.mpls was added as title #13
003307:0000 File 00801.mpls was added as title #14
003307:0000 File 00802.mpls was added as title #15
003307:0000 File 00200.mpls was added as title #16
003307:0000 File 00201.mpls was added as title #17
003307:0000 File 00202.mpls was added as title #18
003309:0000 Title 00907.mpls is equal to title 00200.mpls and was skipped
003309:0000 Title 00932.mpls is equal to title 00800.mpls and was skipped
003025:0000 Title #00011.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00528.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00300.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00501.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00506.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00508.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00509.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00510.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00872.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00873.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00874.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00887.m2ts was added as title #19
003025:0000 Title #00952.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00953.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00954.m2ts was added as title #20
003025:0000 Title #00955.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00956.m2ts was added as title #21
003307:0000 File 00957.m2ts was added as title #22
003025:0000 Title #00959.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00958.m2ts was added as title #23
003025:0000 Title #00960.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00961.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00962.m2ts was added as title #24
003025:0000 Title #00964.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00965.m2ts has length of 58 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00966.m2ts was added as title #25
003025:0000 Title #00968.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00969.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00970.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00971.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00972.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00973.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00974.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00975.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00976.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00977.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00978.m2ts has length of 86 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00979.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00980.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00981.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00982.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00983.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00984.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00985.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00986.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00987.m2ts was added as title #26
003025:0000 Title #00988.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00989.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00990.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00991.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at yLMkQ6cI3nbTgSyV+lf6cW+7:0
005015:0000 Saving 1 titles into directory /Volumes/Seagate Bac/#movies/dvd using profile 'FLAC' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/flac.mmcp.xml'
FFENC009: option compression_level=5
FFDEC001: [truehd @ 0x24a78200] Warning: not compiled with thread support, using thread emulation
FFDEC005: [truehd @ 0x1094600] Warning: not compiled with thread support, using thread emulation
FFENC009: [flac @ 0x24a94000] Warning: not compiled with thread support, using thread emulation
FFENC009: [flac @ 0x24a94000] compression: 5
FFENC009: [flac @ 0x24a94000] lpc type: Levinson-Durbin recursion with Welch window
FFENC009: [flac @ 0x24a94000] prediction order: 1, 8
FFENC009: [flac @ 0x24a94000] order method: estimate
FFENC009: [flac @ 0x24a94000] partition order: 0, 8
FFENC009: [flac @ 0x24a94000] block size: 4608
FFENC009: [flac @ 0x24a94000] lpc precision: 15
FFDEC002: [truehd @ 0x189ea00] Warning: not compiled with thread support, using thread emulation
AV sync issues in /Volumes/Seagate Bac/#movies/dvd/Brave_t12.mkv
AV sync in 2,3,4,5 at 0:00:44.586 (21.791ms) : encountered overlapping frame, audio skew is +21.791ms
FFDEC003: [truehd @ 0x23ff0600] Warning: not compiled with thread support, using thread emulation
AV sync in 2,3,4,5 at 0:01:12.864 (9.75ms) : encountered overlapping frame, audio skew is +31.541ms
THDSF: [truehd @ 0x37a02600] Warning: not compiled with thread support, using thread emulation
THDSF: [truehd @ 0x37a02600] End of stream indicated.
FFDEC003: [truehd @ 0x23ff0600] End of stream indicated.
FFDEC004: [truehd @ 0x37a78400] Warning: not compiled with thread support, using thread emulation
AV sync in 2,3,4,5 at 0:04:15.338 (22.041ms) : encountered overlapping frame, audio skew is +53.583ms
AV sync in 2,3,4,5 at 0:04:15.392 (32ms) : 1 frame(s) dropped to reduce audio skew to +21.583ms
AV sync in 2,3,4,5 at 0:05:13.354 (31.708ms) : encountered overlapping frame, audio skew is +53.291ms
AV sync in 2,3,4,5 at 0:05:13.408 (32ms) : 1 frame(s) dropped to reduce audio skew to +21.291ms
001003:0020 DEBUG: Code 1073741829 at hopu6)9{tj@#vF{r:29393953
001003:0020 DEBUG: Code 100864256 at ikARR#/Z_`zw`4;P:29401451
002003:0000 Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '6459555840'
001003:0020 DEBUG: Code 0 at [Xg5'Ffpbtv@o_JbhLK3:121263038
001003:0020 DEBUG: Code 0 at [_JHS864$#Fm-VEU['lz:121262302
001003:0020 DEBUG: Code 0 at [Xg5'Ffpbtv@o_JbhLK3:213130559
001003:0020 DEBUG: Code 3154080 at [Xg5'Ffpbtv@o_JbhLK3:29393286
001003:0020 DEBUG: Code 20 at (iN|&R+5/,WstO,D:213131571
001003:0020 DEBUG: Code 0 at (iN|&R+5/,WstO,D:121264924
001003:0020 DEBUG: Code 0 at [Xg5'Ffpbtv@o_JbhLK3:29393286
001003:0020 DEBUG: Code 0 at eotr304/*9dBvz}*:>Vn:121263337
001003:0020 DEBUG: Code 0 at 1L@;+W\,B1)LUiG!v[\og:29398967
005003:0000 Failed to save title 12 to file /Volumes/Seagate Bac/#movies/dvd/Brave_t12.mkv
005004:0080 0 titles saved, 1 failed
Re: Brave
#2 Post by Woodstock » Sun Apr 19, 2015 2:44 am
Your drive says it can't read part of the disk. First attempt to remedy is cleaning the disk - finger prints can cause this, as can scratches.
birdman
Re: Brave
#3 Post by birdman » Sun Apr 19, 2015 11:28 pm
This is a bad disc!
Upon closer inspection after a thorough cleaning, I can see there are imperfections in the disc itself. There are strange lines at various angles, curves etc located all over the disc. Thought it had something to do with the screen print, but no. You can see it within the disc material.
pwalker
Re: Brave
#4 Post by pwalker » Thu Jul 30, 2015 11:23 pm
I'm having the same problem but my disc is clean and the movie plays fine from the disc.
Saving 1 titles into directory E:/Video
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12426276864'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12426866688'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12427130880'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12441483264'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12445022208'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12457801728'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12498499584'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12751534080'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12752910336'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12753432576'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12764706816'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12768620544'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00956.m2ts' at offset '12772638720'
Failed to save title 12 to file E:/Video/Brave_t12.mkv
Re: Brave
#5 Post by Woodstock » Fri Jul 31, 2015 1:53 am
And yet, your BD drive says different - it can't read parts of the disk. Player software will IGNORE errors, but ripping software is trying to give you an exact copy
It may be that the "plays fine" portion of it is not what you're ripping as title 12. If I remember correctly, there are 3 copies of the movie on that disk, with English, Spanish, and French title sequences. If the errors are in the title sequencies, you might find one that rips just fine.
pwalker
Re: Brave
#6 Post by pwalker » Fri Jul 31, 2015 3:56 am
I was able to rip that title with DVDFab...
However, I went back and ripped a different version title (you're right, there are 3) and it worked. Thanks for the fast response and good advice.
zhinjio
Re: Brave
#7 Post by zhinjio » Sat Oct 15, 2022 9:19 pm
I had significant issues with this Bluray, across three different physical discs.
I was finally able to get it to rip off track 200 (800mpls) with only a single audio file and single subtitle selected. Lots of errors still, but it appears to have been able to work around them. This disc definitely gets the :sadface: from me. I've not encountered this level of difficulty, especially across multiple discs, from any other title. And thats with... what, over 700 movie rips at this point.
Logfile attached in case that helps anyone.
Cheers,
- ZJ
MakeMKV_log.txt
(1.38 MiB) Downloaded 285 times
