I don't know, never happened to me, which workflow?
I don't recognize it in the picture(post full log instead).
FYI you never have to answer "n" . you can always just skip by pressing enter which is the same of answering "n"
Very stable and without the hassle of other builds.
4-2-2 or my lg oled c9.RESET_9999 wrote: ↑Sat Oct 15, 2022 1:54 pmI don't know, never happened to me, which workflow?
I cannot reproduce!
Then i'll do that from now on. What is the combination for my lg c9 with your newest tool?RESET_9999 wrote: ↑Sat Oct 15, 2022 2:39 pmI cannot reproduce!
your picture doesnt really make sense because it shows ffmpeg. There is no ffmpeg code in the script there.
Anyway, the best practice is always to work with an untouched bluray disc and not some random torrent mkv remux(there's a reason why FGT is banned on most trackers).
For a bluray disc input:
i have a thousand of mpls file's in the bluray folder. which one i have to select?RESET_9999 wrote: ↑Sat Oct 15, 2022 2:45 pmFor a bluray disc input:
4-1-1 for DDP audio encoding
or
4-1-2 (no audio encoding)
i know, i dit it before. but there is no 0000.mpls in the original bluray folder of the movie. i can't find how to mux in you're tutorial? of i am not seeing?RESET_9999 wrote: ↑Sat Oct 15, 2022 6:20 pmcheck in the tutorial folder, you have examples of everything you can do with the script
"Bluray Disc (BDMV) to Profile 8 DDP (TV-Shield-Zidoo-Firestick).gif"
thanks that was more clearly. can i use the tool for 2 or more movies at the same time?RESET_9999 wrote: ↑Sat Oct 15, 2022 6:44 pmyou drop the bd folder and it will list all the playlists. Then just choose the one with the longest duration.
