kazuma wrote: Sat Oct 15, 2022 2:28 pm 4-2-2 or my lg oled c9.
I cannot reproduce!
your picture doesnt really make sense because it shows ffmpeg. There is no ffmpeg code in the script there.
Anyway, the best practice is always to work with an untouched bluray disc and not some random torrent mkv remux(there's a reason why FGT is banned on most trackers).
kazuma
Post by kazuma »
RESET_9999 wrote: Sat Oct 15, 2022 2:39 pm
I cannot reproduce!
Then i'll do that from now on. What is the combination for my lg c9 with your newest tool?
kazuma wrote: Sat Oct 15, 2022 2:42 pm Then i'll do that from now on. What is the combination for my lg c9 with your newest tool?
For a bluray disc input:
4-1-1 for DDP audio encoding
or
4-1-2 (no audio encoding)
userr
Post by userr »
ragico wrote: Sat Oct 15, 2022 2:00 pm
userr wrote: Sat Oct 15, 2022 1:28 pm
ragico wrote: Sun Oct 09, 2022 10:14 am
Thank you. Very kind.
Im interested, what is special with this kodi build? thanks
Very stable and without the hassle of other builds.
also DV capability i guess? with mkv etc
ragico
Post by ragico »
userr wrote: Sat Oct 15, 2022 3:21 pm also DV capability i guess? with mkv etc
Yes for Dolby Vision profile 5 and 8 and 7 Mel. Not for profile 7 Fel.
kazuma
Post by kazuma »
RESET_9999 wrote: Sat Oct 15, 2022 2:45 pm
or
i have a thousand of mpls file's in the bluray folder. which one i have to select?
or must i mux the bluray folder first with tsmuxer? what are the steps?
check in the tutorial folder, you have examples of everything you can do with the script
"Bluray Disc (BDMV) to Profile 8 DDP (TV-Shield-Zidoo-Firestick).gif"
kazuma
Post by kazuma »
RESET_9999 wrote: Sat Oct 15, 2022 6:20 pm check in the tutorial folder, you have examples of everything you can do with the script
i know, i dit it before. but there is no 0000.mpls in the original bluray folder of the movie. i can't find how to mux in you're tutorial? of i am not seeing?
you drop the bd folder and it will list all the playlists. Then just choose the one with the longest duration.
kazuma
Post by kazuma »
RESET_9999 wrote: Sat Oct 15, 2022 6:44 pm you drop the bd folder and it will list all the playlists. Then just choose the one with the longest duration.
thanks that was more clearly. can i use the tool for 2 or more movies at the same time?
sw5163
Post by sw5163 »
sw5163 wrote: Fri Oct 07, 2022 12:50 am There are not really a lot of Bluray IMAX DV.
I hope Top Gun 2 will come out as IMAX DV.
Looks like Top Gun 2 is FEL IMAX.
Donpoku
Post by Donpoku »
Hi, just seen my friend z9x, are all Dolby vision contents are in 'bt2020' ie 'Dolby Vision BT2020' is the info bar on his lg oled c6 tv?
But the thing is I read on here a while back thanks to @RESET_9999 detailed player experiences that this gives wrong colors?
My MINIX U22 XJ-Max (Amlogic device) never has the BT2020 flag on DV contents and the colours are more deeper but more accurate in my eyes compared to the more brighter but mellowy colors on the z9x.
So to any Z9X owners, can this bt2020 on dv contents be removed?
Thank you.
kazuma
Post by kazuma »
the scripts is done after i did 4-1-1 with untouched bluray and selected the longest mpls file.
i think i must mux the hevc file to TS with tsmuxer? but the hevc videofile doesn't have a audofile?
https://ibb.co/vPx9Mz4
https://ibb.co/3BNKYWd
the new script mux to TS. Unless you edited the bat file, you shouldn't have an hevc file or an audio file in your output folder. Just a TS file ready to be watched.
your image doesnt work. "502 Bad Gateway"
EDIT, now your image works and I see whats confusing.
You input BD in your dovi_script folder. The ts file (with DDP) is in there, it's just renamed "DoVi_scripts_P8.ts" because the script will rename the file according to the first folder in your path.
the old way used the playlist name but I was tired of always having to rename my files so I changed the behavior according to my setup.
So my input BD folders are always in the root of my drive ( D:\) so my files have proper output names. Now i realize how it can be confusing for people that have the BD on a different path(will look into a new way).
and as i said before this whole new TS muxing(not the renaming) behavior can be disabled to use the old one by editing the bat file and set "MUX.To.TS"=NO
kazuma wrote: Sun Oct 16, 2022 9:40 am
kazuma
Post by kazuma »
RESET_9999 wrote: Sun Oct 16, 2022 12:40 pm the new script mux to TS. Unless you edited the bat file, you shouldn't have an hevc file or an audio file in your output folder. Just a TS file ready to be watched.
what do i have to do now exactly? can you explain me specifically please?
