#7636
Post
by RESET_9999 » Sat Oct 15, 2022 1:54 pm
kazuma wrote: ↑Sat Oct 15, 2022 12:35 pm
I don't know, never happened to me, which workflow?
I don't recognize it in the picture(post full log instead).
FYI you never have to answer "n" . you can always just skip by pressing enter which is the same of answering "n"
ragico
#7637
Post
by ragico » Sat Oct 15, 2022 2:00 pm
userr wrote: ↑Sat Oct 15, 2022 1:28 pm
ragico wrote: ↑Sun Oct 09, 2022 10:14 am
Thank you. Very kind.
Im interested, what is special with this kodi build? thanks
Very stable and without the hassle of other builds.
kazuma
#7638
Post
by kazuma » Sat Oct 15, 2022 2:28 pm
RESET_9999 wrote: ↑Sat Oct 15, 2022 1:54 pm
4-2-2 or my lg oled c9.
mediainfo of the movie: Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
must i try a another combination perphaps?
#7639
Post
by RESET_9999 » Sat Oct 15, 2022 2:39 pm
kazuma wrote: ↑Sat Oct 15, 2022 2:28 pm
I cannot reproduce!
your picture doesnt really make sense because it shows ffmpeg. There is no ffmpeg code in the script there.
Anyway, the best practice is
always to work with an untouched bluray disc and not some random torrent mkv remux(there's a reason why FGT is banned on most trackers).
kazuma
#7640
Post
by kazuma » Sat Oct 15, 2022 2:42 pm
RESET_9999 wrote: ↑Sat Oct 15, 2022 2:39 pm
I cannot reproduce!
Then i'll do that from now on. What is the combination for my lg c9 with your newest tool?
#7641
Post
by RESET_9999 » Sat Oct 15, 2022 2:45 pm
kazuma wrote: ↑Sat Oct 15, 2022 2:42 pm
For a bluray disc input:
4-1-1 for DDP audio encoding
or
4-1-2 (no audio encoding)
userr
#7642
Post
by userr » Sat Oct 15, 2022 3:21 pm
ragico wrote: ↑Sat Oct 15, 2022 2:00 pm
also DV capability i guess? with mkv etc
ragico
#7643
Post
by ragico » Sat Oct 15, 2022 4:01 pm
userr wrote: ↑Sat Oct 15, 2022 3:21 pm
Yes for Dolby Vision profile 5 and 8 and 7 Mel. Not for profile 7 Fel.
kazuma
#7644
Post
by kazuma » Sat Oct 15, 2022 5:57 pm
RESET_9999 wrote: ↑Sat Oct 15, 2022 2:45 pm
or
i have a thousand of mpls file's in the bluray folder. which one i have to select?
or must i mux the bluray folder first with tsmuxer? what are the steps?
#7645
Post
by RESET_9999 » Sat Oct 15, 2022 6:20 pm
check in the tutorial folder, you have examples of everything you can do with the script
"Bluray Disc (BDMV) to Profile 8 DDP (TV-Shield-Zidoo-Firestick).gif"
kazuma
#7646
Post
by kazuma » Sat Oct 15, 2022 6:37 pm
RESET_9999 wrote: ↑Sat Oct 15, 2022 6:20 pm
i know, i dit it before. but there is no 0000.mpls in the original bluray folder of the movie. i can't find how to mux in you're tutorial? of i am not seeing?
#7647
Post
by RESET_9999 » Sat Oct 15, 2022 6:44 pm
you drop the bd folder and it will list all the playlists. Then just choose the one with the longest duration.
kazuma
#7648
Post
by kazuma » Sat Oct 15, 2022 9:14 pm
RESET_9999 wrote: ↑Sat Oct 15, 2022 6:44 pm
thanks that was more clearly. can i use the tool for 2 or more movies at the same time?
sw5163
#7649
Post
by sw5163 » Sun Oct 16, 2022 12:48 am
sw5163 wrote: ↑Fri Oct 07, 2022 12:50 am
There are not really a lot of Bluray IMAX DV.
I hope Top Gun 2 will come out as IMAX DV.
Looks like Top Gun 2 is FEL IMAX.
Donpoku
#7650
Post
by Donpoku » Sun Oct 16, 2022 2:00 am
Hi, just seen my friend z9x, are all Dolby vision contents are in 'bt2020' ie 'Dolby Vision BT2020' is the info bar on his lg oled c6 tv?
But the thing is I read on here a while back thanks to @RESET_9999 detailed player experiences that this gives wrong colors?
My MINIX U22 XJ-Max (Amlogic device) never has the BT2020 flag on DV contents and the colours are more deeper but more accurate in my eyes compared to the more brighter but mellowy colors on the z9x.
So to any Z9X owners, can this bt2020 on dv contents be removed?
Thank you.
