Makemkv - Virus ?
joejoe78
Makemkv - Virus ?
Post by joejoe78 » Sat Oct 15, 2022 11:57 am
Hi guys and girls, I would like to try out Makemkv for some bluray rips to my home media centre. I kinda ran it though https://www.virustotal.com/gui/file/eaf ... 9bbe92dfba and gota hit. Should i be worried or just a false positive?
(Exploit.Zip.Heuristic-java.csrvpr)
Re: Makemkv - Virus ?
Post by Woodstock » Sat Oct 15, 2022 4:26 pm
This occurs occasionally. This particular antivirus program isn't one I've heard of, but there are dozens of new ones over the years.
I would suggest you choose the antivirus programs you trust, and submit the file to them to check. Most of the reputable companies have an address for that.
While I doubt that the report is true, I also treat such reports as serious, and causes for checking.
joejoe78
Post by joejoe78 » Sun Oct 16, 2022 8:19 am
Cool well I'll do a bit of testing if anything pops up will let you know.
