Re: SDFtool Flasher
#586 Post by Coopervid » Fri Oct 14, 2022 1:11 pm
dg1218 wrote: Fri Oct 14, 2022 12:40 pm I've tried this one first using the new SDFtool Flasher 1.37 and using the old SDFtool Flasher
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK
Then I tried both ways
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD
Each time the flasher says complete no errors, but the firmware version makemkv show never changes. I've also been running the SDFtool Flasher as admin. The drive still reads blueray disk as normal. I've tried about 4 Uhd bluerays with no luck. I got the MK bin files from this link at the beginning of this post. Not really sure what I'm doing incorrectly
Found this in the thread SDFTool flasher:
UPDATE - 21/12/2021:
The latest version of the SDFtool Flasher has a checkbox option to flash the boot loader with the main firmware to the drive. This is useful for the newer BP50NB40 with SVC: NB52. It's also possible that other newer models may require this option later on. We will all work it out together as we go!!
For the moment, to flash the BP50NB40 SVC:NB52, using the latest SDFtool Flasher, follw the steps below:
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
3. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
4. Select the BP60NB10 1.00-MK firmware in the normal drop box.
5. Click START
Re: SDFtool Flasher
#587 Post by Billycar11 » Fri Oct 14, 2022 7:33 pm
Coopervid wrote: Fri Oct 14, 2022 1:11 pm
5. Click START
Fyi for everyone it works both ways just a different way of doing it
dg1218
Re: SDFtool Flasher
#588 Post by dg1218 » Fri Oct 14, 2022 11:23 pm
5. Click START
Just tried that method, same results even with the boot loader option checked.
Re: SDFtool Flasher
#589 Post by MartyMcNuts » Sat Oct 15, 2022 2:15 am
dg1218 wrote: Fri Oct 14, 2022 11:23 pm
5. Click START
Using SDFtool Flasher (v1.3.4 is the latest) perform the following.
1. Flash the drive to BP50NB40 (NB50) 1.03-MK. I SEE YOU HAVE ALREADY DONE THIS STEP!!
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK firmware in the normal drop box.
4. Click START
I have never seen this not work and I have done it hundreds of times. There is no need to use the bootloader option.
dg1218
Re: SDFtool Flasher
#590 Post by dg1218 » Sat Oct 15, 2022 3:29 am
MartyMcNuts wrote: Sat Oct 15, 2022 2:15 am
5. Click START
4. Click START
I have done all three of these steps multiple times. The firmware version has not changed. I have tried the BP60NB10 1.02-MK firmware for the last step as well as the BP60NB10 1.00-MK. After I have opened MakeMKV to confirm firmware has changed and it remains on the BP50NB40 (NB50) 1.03 firmware version. I've also tried to read about 4 UHD bluerays, none will open. I have even tried running this on two different computers with the same results. Should the version change show up under the drive info section of MakeMKV after this process is complete?
Re: SDFtool Flasher
#591 Post by MartyMcNuts » Sat Oct 15, 2022 3:38 am
dg1218 wrote: Sat Oct 15, 2022 3:29 am
4. Click START
How old is your drive? What is the manufacture date on the drive?
Re: SDFtool Flasher
#592 Post by Coopervid » Sat Oct 15, 2022 9:34 am
Please post your Makemkv info. Most importantly it has to have the MT1959 chip.
And a potential issue is the enclosure if you use it via USB. Not all support flashing.
Please provide as much information as possible. Currently it's like pulling teeth....
dg1218
Re: SDFtool Flasher
#593 Post by dg1218 » Sat Oct 15, 2022 12:48 pm
The manufacture date on the drive is April 13, 2022. This drive was just purchased a couple of weeks ago. On the enclosure it says Model: BP50NB40 SVC Code: NB52
It is a usb drive and I'm using both the usb data and extra power connection. Voltage Rating is 5V (1.8A). The Rom Ver listed on the drive is 1.03. Below is the Makemkv info. It is the MT1959 chip.
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM2121V95240
Firmware version: 1.03
Re: SDFtool Flasher
#594 Post by Coopervid » Sat Oct 15, 2022 4:55 pm
Everything looks good so far. The only variable is the enclosure. Maybe that's the issue. What model is it?
Do you have a chance to take it out and connect directly to SATA in a desktop PC?
Re: SDFtool Flasher
#595 Post by MartyMcNuts » Sat Oct 15, 2022 10:27 pm
dg1218 wrote: Sat Oct 15, 2022 12:48 pm The manufacture date on the drive is April 13, 2022. This drive was just purchased a couple of weeks ago. On the enclosure it says Model: BP50NB40 SVC Code: NB52
Revision: 1.03
When you try the process I mentioned previously, do you get any error codes? Also, when flashing, make sure there is no disc in the drive. You did flash BP50NB40 (NB50) 1.03-MK to it, didn't you?
JediFonger
Re: SDFtool Flasher
#596 Post by JediFonger » Wed Oct 19, 2022 2:40 am
OS device name: A:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Bus encryption flags: 1F
Highest AACS version: 77
^the Asus ODD flasher.exe worked.
but when i used 1.3.4 GUI of this tool, i checked encrypted and no boot loader and write but it looked like it went through 100% but nothing happened. i rebooted computer still nothing. more of a FYI.
Re: SDFtool Flasher
#597 Post by MartyMcNuts » Wed Oct 19, 2022 2:50 am
JediFonger wrote: Wed Oct 19, 2022 2:40 am Drive Information
OS device name: A:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
ASus BW-16D1HT 3.10 is not encrypted.
JediFonger
Re: SDFtool Flasher
#598 Post by JediFonger » Wed Oct 19, 2022 9:25 pm
could the tool throw that message? i didnt know that
Re: SDFtool Flasher
#599 Post by MartyMcNuts » Wed Oct 19, 2022 10:11 pm
JediFonger wrote: Wed Oct 19, 2022 9:25 pm could the tool throw that message? i didnt know that
No need as SDFtool Flasher already has that fw as not encrypted. You are the one who toggled the encrypted flag when you should have left it alone.
dreadmclaren
Re: SDFtool Flasher
#600 Post by dreadmclaren » Tue Nov 01, 2022 7:57 pm
OS device name: E:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: MD1G3BA3205
Firmware date: 2120-05-07 09:35
Firmware version: 1.02
Hello
I crossflashed my BP50NB40 and everything seemed to go smoothly, but now I can't open the drive. The light blinks after sending the 'eject' command and then stops and nothing happens. Original firmware was 1.00 went to BP50NB40-NB50-1.03MK then BP60NB10 1.02MK. Did I miss something?
