Jurassic Park Dominion..
geogan
#1 Post by geogan » Fri Oct 14, 2022 5:29 pm
This is UK Bluray from Universal.
AWARD FOR: The most I have seen in content section and the most complicated long-winded load time to this screen I ever saw for a single disc...
What is all those SEG_MAinFeature_* files for (see screenshot attached)??
MakeMKV v1.17.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\xxxx/MakeMKV_log.txt
Using LibreDrive mode (v06.3 id=FA108BB7DA63)
Using Java runtime from C:\Program Files\Java\jre1.8.0_281\bin\java.exe
DEBUG: Code 0 at :DC&8=5W}AzWb|WS-N:213130007
DEBUG: Code 1 at O~WcM,qc5gaWcMhDP:213131548
Title #00156.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00157.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01104.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01105.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01106.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01107.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01108.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01109.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01111.mpls has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00600.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01056.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00010.mpls was added as title #0
Title #00047.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00056.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00058.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00067.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00612.mpls was added as title #1
Title #01112.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01113.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01115.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01218.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01219.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01220.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01388.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01350.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01351.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01352.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01353.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01354.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01355.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01356.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01357.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01358.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01359.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01360.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01361.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01362.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01363.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01364.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01365.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01366.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01367.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01368.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01369.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01370.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01371.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01372.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01373.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01374.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01375.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01376.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01377.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01378.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01379.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01380.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01381.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01382.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01383.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01384.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01385.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01386.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01387.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01389.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00613.mpls was added as title #2
File 00614.mpls was added as title #3
File 00615.mpls was added as title #4
Title #00616.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00617.mpls was added as title #5
File 00618.mpls was added as title #6
File 00619.mpls was added as title #7
Title #00620.mpls has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00621.mpls was added as title #8
Title #00622.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00623.mpls was added as title #9
Title #00624.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00625.mpls was added as title #10
Title #00626.mpls has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00627.mpls was added as title #11
Title #00628.mpls has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00629.mpls was added as title #12
Title #00630.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00631.mpls was added as title #13
Title #00632.mpls has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00633.mpls was added as title #14
Title #00634.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00635.mpls was added as title #15
File 00636.mpls was added as title #16
File 00637.mpls was added as title #17
File 00638.mpls was added as title #18
Title #00639.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00640.mpls was added as title #19
Title #00641.mpls has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00642.mpls has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00643.mpls has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00644.mpls has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00645.mpls has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00646.mpls was added as title #20
Title #00647.mpls has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00648.mpls has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00649.mpls was added as title #21
File 01390.mpls was added as title #22
File 01391.mpls was added as title #23
Title #01392.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01393.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01394.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01395.mpls was added as title #24
File 01396.mpls was added as title #25
File 01397.mpls was added as title #26
Title #01398.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01399.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01400.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01401.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01402.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01403.mpls was added as title #27
File 01404.mpls was added as title #28
File 01405.mpls was added as title #29
File 01406.mpls was added as title #30
File 01407.mpls was added as title #31
Title #01408.mpls has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01409.mpls was added as title #32
Title #01410.mpls has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01411.mpls has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01432.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01433.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 01434.mpls was added as title #33
File 00800.mpls was added as title #34
File 00149.mpls was added as title #35
Title #01103.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00801.mpls was added as title #36
File 01412.mpls was added as title #37
File 01413.mpls was added as title #38
File 01414.mpls was added as title #39
File 01415.mpls was added as title #40
File 01416.mpls was added as title #41
File 01417.mpls was added as title #42
File 01418.mpls was added as title #43
File 01419.mpls was added as title #44
File 01420.mpls was added as title #45
File 01421.mpls was added as title #46
File 01422.mpls was added as title #47
File 01423.mpls was added as title #48
File 01424.mpls was added as title #49
File 01425.mpls was added as title #50
File 01426.mpls was added as title #51
File 01427.mpls was added as title #52
File 01428.mpls was added as title #53
File 01429.mpls was added as title #54
File 01430.mpls was added as title #55
File 01431.mpls was added as title #56
Title #00179.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00181.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00183.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00184.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00185.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00165.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00178.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00247.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00452.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00456.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00458.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00460.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00462.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00464.m2ts has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00466.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00468.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00470.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00475.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00477.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00478.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00479.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00480.m2ts has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00481.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00483.m2ts has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00484.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00508.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00509.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Ezatoka
Re: Jurassic Park Dominion..
#2 Post by Ezatoka » Fri Oct 14, 2022 5:38 pm
geogan wrote: Fri Oct 14, 2022 5:29 pm What is all those SEG_MAinFeature_* files for (see screenshot attached)??
When you look at FPL_MainFeature and FPL_MainFeature_EXT, can you tell, if these are playlists? On the right side you would see a segment list.
My guess: FPL_MainFeature_EXT stands for Extended. Thus you have both editions on the disc, the theatrical and the extended one. The Extended part will have additional deleted or extended scenes within itself.
Thus: The segments are the main movie split into parts. For example (numbers not from your movie) the main movie uses segments 1, 2, 4, 5, 7, 8 and 10, the extended edition has segments 3, 6 and 9 added and might use segments 1, 2, 3, 4, 5, 6, 7, 8, 9 and 10. And for that, the segments need to be separately on the disc so the playlist can address them separately.
#3 Post by dcoke22 » Fri Oct 14, 2022 8:14 pm
Jurassic World: Dominion suggests that the blu-ray has both a theatrical release and an extended edition on the disc.
geogan
#4 Post by geogan » Fri Oct 14, 2022 10:56 pm
Yes the FPL_MainFeature_EXT is the extended movie playlist... its 2:40 long.
I just never saw MakeMKV list all the individual segments before like this. Maybe its new feature?
Ezatoka
#5 Post by Ezatoka » Sat Oct 15, 2022 12:23 pm
If the segments wouldn't have a playlist file, MakeMKV would have listed them below the playlists as the individual m2ts files as source. Maybe it's the first BluRay you have with having both normal and extended edition onto itself
#6 Post by dcoke22 » Sat Oct 15, 2022 2:05 pm
Yesterday I was working on a blu-ray with two versions of the movie on it. It was the first such disc I've used with 1.17.2 (or with any version of 1.17.x) and I saw the behavior the OP described. It seems like a subtle behavior change in 1.17.x vs 1.16.x.
