Handbreak States No Valid Source Found, VLC can play the MKV
psycoperl
#1 Post by psycoperl » Mon Oct 10, 2022 9:17 pm
I was encoding the Hogans Heroes Season 2 Disk 5 DVD and for a few of the titles, Handbreak indicates that "No Valid Source Found" when I select the MKV files for processing.
However, when I open the MKV in VLC it is able to play back the content. How can I fix this issue? How can I export them to a valid format for Handbreak?
Re: Handbreak States No Valid Source Found, VLC can play the MKV
#2 Post by dcoke22 » Wed Oct 12, 2022 6:48 pm
What does MediaInfo say about your .mkv files? Is there anything unusual about them?
Were your .mkv files created with MakeMKV from your Hogan's Heroes DVDs?
psycoperl
#3 Post by psycoperl » Thu Oct 13, 2022 12:14 pm
Yes the MKV was made from the DVD.
Here is what MediaInfo states:
General
Unique ID : 281330661397688393620486807081247570313 (0xD3A6508377384D67AAE09AB1F1B7F989)
Complete name : /Users/{username}/Movies/HOGANS_HEROES_S2_D5/Hogans_Heroes_S00E13_Bob Crane Radio with Richard Dawson & Chad Everett_T17.mkv
Format : Matroska
Format version : Version 2
File size : 22.5 MiB
Duration : 16 min 14 s
Overall bit rate : 194 kb/s
Encoded date : UTC 2022-10-10 20:19:59
Writing application : MakeMKV v1.17.1 darwin(x64-release)
Writing library : libmakemkv v1.17.1 (1.3.10/1.5.2) darwin(x64-release)
Video
ID in the original source medium : 224 (0xE0)
Format : MPEG Video
Format profile : Main@Main
Format settings : CustomMatrix
Format settings, BVOP : No
Format settings, Matrix : Custom
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 33 ms
Bit rate mode : Constant
Bit rate : 35.0 Mb/s
Maximum bit rate : 8 000 kb/s
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 3.375
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
Stream size : 141 KiB (1%)
Language : English
Default : No
Forced : No
Original source medium : DVD-Video
Audio
ID in the original source medium : 189 (0xBD)128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 22.3 MiB (99%)
Title : Stereo
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Text
ID in the original source medium : 189 (0xBD)32 (0x20)
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : Picture based subtitle format used on DVDs
Duration : 11 ms
Bit rate : 876 kb/s
Frame rate : 87.891 FPS
Count of elements : 1
Stream size : 1.18 KiB (0%)
Language : English
Default : Yes
Forced : No
#4 Post by dcoke22 » Thu Oct 13, 2022 2:00 pm
There are a couple things a little unusual in that output. For example, here's the video section of an episode of the TV Show Long Way Round that I happened to have handy.
General
Complete name                            : Long Way Round s01e01 Preparation.mkv
File size                                : 1.84 GiB
Duration                                 : 44 min 4 s
Overall bit rate                         : 5 968 kb/s
Movie name                               : Long Way Round s01e01 Preparation
Encoded date                             : UTC 2022-09-26 13:28:47
Writing application                      : MakeMKV v1.16.7 darwin(x64-release)
Writing library                          : libmakemkv v1.16.7 (1.3.10/1.5.2) darwin(x64-release)
Video
Format                                   : MPEG Video
Format settings                          : CustomMatrix / BVOP
Format settings, BVOP                    : Yes
Format settings, GOP                     : M=3, N=15
Format settings, picture structure       : Frame
Codec ID                                 : V_MPEG2
Bit rate                                 : 5 698 kb/s
Maximum bit rate                         : 9 800 kb/s
Width                                    : 720 pixels
Height                                   : 480 pixels
Standard                                 : NTSC
Bit depth                                : 8 bits
Scan type                                : Interlaced
Bits/(Pixel*Frame)                       : 0.550
Stream size                              : 1.75 GiB (95%)
Notice, the Duration in my example is listed as 44 min 4 s, which is how long the episode is. Yours is listed as 33 ms, which is quite short. :) There are a couple of other unusual things as well; Bit rate for instance. Perhaps most importantly, the file size is listed as only 22.5 MiB, which is probably too small for a whole episode.
I would guess there was an error while the episode was being ripped. Perhaps try ripping it again.
psycoperl
#5 Post by psycoperl » Thu Oct 13, 2022 2:22 pm
The portion was a static screen with audio playback. It was from the Special Features section which had an old radio show recording of two of the stars.
