Error trying to parse an iso file
irrelevant
Post by irrelevant »
I have a disc that Makemkv had difficulty reading (it would parse the contents, and I could select the titles, but it dies reading data from the DVD). So I ripped the DVD to my HD using k3b, and now I want to convert that to an mkv using MakeMkv (because it has a really good title detection algroithm)
But when I load the ISO, it starts parsing the chapters, then gets to the very end and fails before showing my the title list:
Signature is invalid in IFO file
CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-7 were removed from title start
Cells 43-44 were removed from title end
Title #2 (2:18:00) was skipped due to navigation error
Title #3 (2:18:00) was skipped due to navigation error
Title #4 (2:18:00) was skipped due to navigation error
Title #5 (2:18:00) was skipped due to navigation error
Title #6 (2:18:00) was skipped due to navigation error
Title #7 (2:18:00) was skipped due to navigation error
Title #8 (2:18:00) was skipped due to navigation error
Title #9 (2:18:00) was skipped due to navigation error
Title #10 (2:18:00) was skipped due to navigation error
Title #11 (2:18:00) was skipped due to navigation error
Title #17 (2:18:00) was skipped due to navigation error
Title #18 (2:18:00) was skipped due to navigation error
Title #19 (2:18:00) was skipped due to navigation error
Title #20 (2:18:00) was skipped due to navigation error
Title #21 (2:18:00) was skipped due to navigation error
Title #22 (2:18:00) was skipped due to navigation error
Title #23 (2:18:00) was skipped due to navigation error
Title #24 (2:18:00) was skipped due to navigation error
Title #32 (2:18:00) was skipped due to navigation error
Title #33 (2:18:00) was skipped due to navigation error
Title #34 (2:18:00) was skipped due to navigation error
Title #35 (2:18:00) was skipped due to navigation error
Title #36 (2:18:00) was skipped due to navigation error
Title #37 (2:18:00) was skipped due to navigation error
Title #38 has length of 2 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #39 has length of 1 seconds which is less than minimum title length of 300 seconds and was therefore skipped
Title #40 in broken titleset was skipped
Title #41 in broken titleset was skipped
Title #42 in broken titleset was skipped
Title #43 in broken titleset was skipped
Title #44 in broken titleset was skipped
Title #45 in broken titleset was skipped
Title #46 in broken titleset was skipped
Title #47 in broken titleset was skipped
Title #48 in broken titleset was skipped
Title #49 in broken titleset was skipped
Title #50 in broken titleset was skipped
Title #51 in broken titleset was skipped
Title #52 in broken titleset was skipped
Title #53 in broken titleset was skipped
Title #54 in broken titleset was skipped
Title #55 in broken titleset was skipped
Title #56 in broken titleset was skipped
Title #57 in broken titleset was skipped
Title #58 in broken titleset was skipped
Title #59 in broken titleset was skipped
Title #60 in broken titleset was skipped
Title #61 in broken titleset was skipped
Title #62 in broken titleset was skipped
Title #63 in broken titleset was skipped
Title #64 in broken titleset was skipped
Title #65 in broken titleset was skipped
Title #66 in broken titleset was skipped
Title #67 in broken titleset was skipped
Title #68 in broken titleset was skipped
Title #69 in broken titleset was skipped
Title #70 in broken titleset was skipped
Title #71 in broken titleset was skipped
Title #72 in broken titleset was skipped
Title #73 in broken titleset was skipped
Title #74 in broken titleset was skipped
Title #75 in broken titleset was skipped
Title #76 in broken titleset was skipped
Title #77 in broken titleset was skipped
Title #78 in broken titleset was skipped
Title #79 in broken titleset was skipped
Title #80 in broken titleset was skipped
Title #81 in broken titleset was skipped
Title #82 in broken titleset was skipped
Title #83 in broken titleset was skipped
Title #84 in broken titleset was skipped
Title #85 in broken titleset was skipped
Title #86 in broken titleset was skipped
Title #87 in broken titleset was skipped
Title #88 in broken titleset was skipped
Title #89 in broken titleset was skipped
Title #90 in broken titleset was skipped
Title #91 in broken titleset was skipped
Title #92 in broken titleset was skipped
Title #93 in broken titleset was skipped
Title #94 in broken titleset was skipped
Title #95 in broken titleset was skipped
Title #96 in broken titleset was skipped
Title #98 in broken titleset was skipped
Re: Error trying to parse an iso file
Post by mike admin »
Please copy all IFO and BUP files from the disc into a folder. Then mount your ISO and copy all IFO and BUP files from there to another folder. Compress both folders and send to support@makemkv.com with a full debug log ( the one that was saved to file ) as it contains additional information.
