Hellboy 2: The Golden Army UHD
demon
Post by demon »
Attempted backup, but received "Backup failed" error. Disc was just released today, so I'm sure it needs to be added to the hashed keys table. Emailed the dump to the appropriate address.
stuckinkodiagain
Re: Hellboy 2: The Golden Army UHD
Post by stuckinkodiagain »
Same here. I've also submitted the dump file to svq@makemkv.com, just for safety.
Thanks to the developers!
demon
Post by demon »
New hashed keys downloaded, and backup is under way. Thanks mike!
MagnumXL
Post by MagnumXL »
I got a "volume key is unknown for this disc - can't be decrypted" error just now in 2022. Is there a new version that doesn't work for some discs?
I've submitted the key for it.
Post by d00zah »
MagnumXL wrote: Wed Sep 14, 2022 4:41 am I got a "volume key is unknown for this disc - can't be decrypted" error just now in 2022. Is there a new version that doesn't work for some discs?
From the UHD FAQ:
I see a movie discussed in the forum, but MakeMKV won't open my disc.
There are multiple versions of UHDs for each movie (countries, retailers, rentals) and there may be multiple keys for even the same version, so it's possible that your particular disc isn't decrypted yet. Submit the dump file!
MagnumXL
Post by MagnumXL »
If you look above, I had already said I submitted it. It was working within 2 days.
Post by d00zah »
MagnumXL wrote: Mon Oct 10, 2022 10:23 pm If you look above, I had already said I submitted it. It was working within 2 days.
Response was to the question:
MagnumXL wrote: Wed Sep 14, 2022 4:41 am Is there a new version that doesn't work for some discs?
There is seldom a single version/key.
