I have been looking for a list of UHD movies that have Cinavia. I know that if I process to MKV the file will not be affected the same with MK4. Both will not pass DV or display Atmos/TrueHD correctly.
So far out of my movies Jason Bourne is the only one. It would be nice to know so I can not waste time ripping to folders and just keep the MKV backup.
Also I have the correct setting in Anydvd and rip using CloneBD. The folders work perfectly with the exception of Cinavia discs like Jason Bourne.
UHD discs with Cinavia
Re: UHD discs with Cinavia
It won't be an issue if you watch in a player that does not use Cinavia. So basically, don't use a Sony player and you should be fine!datman wrote: Mon Oct 10, 2022 2:45 pm I have been looking for a list of UHD movies that have Cinavia. I know that if I process to MKV the file will not be affected the same with MK4. Both will not pass DV or display Atmos/TrueHD correctly.
