BU40N firmware flash
georgesgiralt
Post by georgesgiralt » Mon Oct 10, 2022 9:59 am
Hello !
I own a BU40N which came with "A103" firmware.
As I could not back up the firmware present on the drive (I got a 70kb tar file instead of the expected 2Mb binary) , I suspected the HL-DT-ST firmware was encoded.
In order to turn LibreDrive on, I flashed it with the 1.03 firmware using this command (Ubuntu Linux) :
makemkvcon f -d /dev/sr0 -f sdf.bin rawflash main enc -i  HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
This ran fine ! :
Informations lecteur
Nom du lecteur SE : /dev/sr0
Fabricant : HL-DT-ST
Produit : BD-RE BU40N
Révision : 1.03
Numéro de série : KZFH4SG5211
Date micrologiciel : 2118-10-24 19:34
Marqueurs d'encryptage bus : 17
Version AACS la plus haute : 68
Firmware version: 1.03
But as I own another BU40N which has a more lax firmware (dump_full_HL-DT-ST_BD-RE_BU40N_A100_211701021159_XXXXXXXX.bin ) I tried to put it on this drive and got errors. Even with or without the "enc" option in the command line.
So my question is :
Is it possible to put this firmware on this drive ? (both drive looks exactly the same except the serial number and date of manufacture)
if yes, what did I do wrong ?
Many thanks in advance for your help.
Have a nice and bright day !
Re: BU40N firmware flash
Post by Billycar11 » Mon Oct 10, 2022 10:12 am
No enc
georgesgiralt
Post by georgesgiralt » Mon Oct 10, 2022 10:31 am
Did it but no joy :
# makemkvcon f -d /dev/sr0 -f sdf.bin rawflash main -i dump_full_HL-DT-ST_BD-RE_BU40N_A100_211701021159_XXXXXXXXX.bin
Reading input file dump_full_HL-DT-ST_BD-RE_BU40N_A100_211701021159_XXXXXXXXX.bin
Current Drive ID: HL-DT-ST_BD-RE_BU40N_1.03_211810241934_XXXXXXXXXXX
yes
  98% .................................................
Write DRAM NG 05/24/00
Command produced error code 0x8f052400
And after a poweroff and power on (the drive is in a laptop)
I got :
nformations lecteur
Révision : 1.03
Numéro de série : XXXXXXXXXXX
So, am I dumb ? or did I miss an important step ?
Post by Billycar11 » Mon Oct 10, 2022 3:09 pm
Did it but no joy :
yes
I got :
nformations lecteur
Révision : 1.03
Follow the guide man why did you change the firmware you were trying to flash
