Stranger Things Season 4
Dal1980
Post by Dal1980 »
Hi guys
Stranger Things Season 4 DVD (4 Disc) are proving to be difficult.
I've got an issue with Disc 1 showing only 1 title when it's supposed to have 3.
They are all about an hour each but only the first one is found.
Is there anything I can do to make it find the rest of the titles?
Many thanks
Re: Stranger Things Season 4
Post by d00zah »
Starting from version 1.17.0 MakeMKV has a new DVD processing engine... & there are more than a few reports of random problems. IIRC, selecting 'CellTrim" solved the problem for others w/ problem discs. YMMV
DVD opening modes - CellWalk, CellTrim, CellFull
If that bears no fruit, try Manual Mode.
Dal1980
Post by Dal1980 »
Thanks d00zah
I cancelled which forced it over to the CellTrim method and it showed the full length (weird DVD has all 3 episodes as a single video, I think they just bookmarked the 3 hr long video as 3 chapter selections for each of the 3 episodes or something).
I don't know if this is related but I'm hitting constant issues with ripping and they all seem to stop towards the end (different times). Anything in the log that would help to identify the issue? Although the disc is clean (and new) I've given a good clean as that's about my level :P
Debug log started at Mon Oct 10 11:36:04 2022 , written by MakeMKV v1.17.1 win(x64-release)
001005:0000 MakeMKV v1.17.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\ZB/MakeMKV_log.txt
DEBUG: Code 3 at W3_5mn~z2cnbOYW#o~Zq,@E{:29395310
SDF  v08f: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLQL7Q85643
001011:0000 Using LibreDrive mode (v06.3 id=7FA2657C7667)
Launching C:\Program Files (x86)\MakeMKV\mmgplsrv64.exe
001003:0020 DEBUG: Code 98 at &TbT|!po>D[}aJ)/K9n_:213132836
001003:0020 DEBUG: Code 16777216 at &TbT|!po>D[}aJ)/K9n_:121264648
001003:0020 DEBUG: Code 0 at &TbT|!po>D[}aJ)/K9n_:121263061
001003:0020 DEBUG: Code 0 at :%_O@[t[t[W $l:29397104
003038:0000 Cells 4-4 were removed from title end
003028:0000 Title #1 was added (3 cell(s), 3:37:53)
005014:0000 Saving 1 titles into directory file://D:/Users/ZB/Videos/MovieDumpMKV/Stranger Things/Season 4/14
001003:0020 DEBUG: Code 0 at ,4D\]h+U3J>cG$yoO:213130237
001003:0020 DEBUG: Code 3221225653 at W3_5mn~z2cnbOYW#o~Zq,@E{:121262371
001003:0020 DEBUG: Code 3221225653 at 0k!ZrIR>L>fWy6+C:213130559
001003:0020 DEBUG: Code 101000192 at U5PW&tql`c>RT]\::29403291
001003:0020 DEBUG: Code 101000192 at 0k!ZrIR>L>fWy6+C:213130559
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '84879360'
001003:0020 DEBUG: Code 3221225488 at W3_5mn~z2cnbOYW#o~Zq,@E{:121262371
001003:0020 DEBUG: Code 3221225488 at 0k!ZrIR>L>fWy6+C:213130559
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '84879360'
DEBUG: Code 3221225488 at qfmN#a{sFwgf"zj2mo:29394896
001003:0020 DEBUG: Code 3221225488 at qfmN#a{sFwgf"zj2mo:213131502
DEBUG: Code 101000192 at qfmN#a{sFwgf"zj2mo:29394896
001003:0020 DEBUG: Code 101000192 at qfmN#a{sFwgf"zj2mo:213131502
001003:0020 DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):29395471
001003:0020 DEBUG: Code 0 at Z0yWfr+sM4){1wKs$ln:29393562
001003:0020 DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):213131157
001003:0020 DEBUG: Code 0 at ^Qjq;+-!?d/:>aLz.mj):121262647
001003:0020 DEBUG: Code 41445 at ^Qjq;+-!?d/:>aLz.mj):121261773
001003:0020 DEBUG: Code 0 at %Fgk##=EujkCx,];LyE:121264234
001003:0020 DEBUG: Code 0 at fRe7Tf.X>q:*CJ*_~hmr?:213137068
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
---- Failed D:/Users/ZB/Videos/MovieDumpMKV/Stranger Things/Season 4/14/title_t00.mkv
ch_0       10309809510000 0
ch_1       10310350050000 0
ch_2       10310890590000 0
ch_3       10311431130000 0
ch_4       10311971670000 0
ch_5       10312512210000 0
ch_6       10313052750000 0
ch_7       10313593290000 1
mt=0000023A105BB590 n=3
s=0 n=13 o=83515392
    0  77315 000011 10313052750000       54054000 C76317E5 000001B32D01E0340BE32380000001B5148200010000000001B8004867C000000100008FFFF8000001B58FFFF71F80000001010B7E1F68D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A34618
    0   5444 000018 10312962660000       54054000 A08110E4 00000100001FFFFBB8000001B58112279F80000001011AAC04052B000001022AE7B780CA87D26FA4BF0A18496BCF0D42E91F6DC7964E5B4CBD55800000010332E63288AA3E850F85522A47A1436368A8AF5CC6E9123D731BAA47AE794C284E3548283D70F9050B855228EA8157309324DDD0A1F5262EE4C5D4C660C9704530A8
    0   4849 000018 10313016714000       36036000 84A81FEA 00000100005FFFFBB8000001B58112271D80000001011AAC04052B0000010222E7AF01951F4934D24D352C61437A654B930A17CC7556000001032AE6328AA3E850D8C5555CCB55E850B97455735D18507A686E759F050509EF139E74285EFA143612993264D686CD2BDD70908AA017556A66190D20409BFFBEA88A4E6331CC06
    0   8333 000010 10313196894000       36036000 B315C9B8 000001000157FFFB80000001B5812FF71D8000000101126C04051B00000102126D8435F42269B54E3AE25BC09843CA61146D1E43C84D43619FBC4C4F18FBC506E51B50986ECD1351AF459545080A46FBB1D421962F2EF2F430883E1A8AF251C626AD27D08A58313C6EE40909C61029B000000103228BA7D9D501CB38449D06D4
    0   5352 000018 10313106804000       36036000 1BB32DB2 0000010000DFFFFBB8000001B58111179D80000001011A5602028AC0000001021A568384F7A73DE03C71568F4A5D142F2B1070B8DA72A2F04E92833D29E732C52792757A50E000000103235F142FA7BCF4F31427C7BA56C383F2A734D1AB8509CEF474CACC383D79D4E6B3741CE6BAAB95C384C40CABAA2850C230A5F78CC384
    0   4519 000018 10313142840000       54054000 F7722F3F 00000100011FFFFBB8000001B58121179F80000001011A5602028AC0000001021A568284F39959AB95824505652E94794E20A1459F1B68716286F2C579E943800000010322E77D142FDF79E35DDCC284F554AD8707E54E69A3568AC8E6B1D070E135D55DCE46C0FFFFF5CCAF7450C0C4697CE8CE76284F0AEEEE22813C385D75
    0   9913 000010 10313323020000       54054000 C58DF809 000001000217FFFB80000001B5813FF79F80000001011A6C04051B000001021A6D8445B03EFFFD53CEB832DE08538F91EACA6B6AB6A1146EAF5EA1B43C189909CF8DA605308C264D4222D1A37492922284513219486F250BAF069312A7542088279D10CA43301A8DD250A4AA8451BCF89D797A846138F6623C5240B7D7A4240F
    0   7364 000018 10313232930000       54054000 01C4460B 00000100019FFFFBB8000001B58111171F8000000101125602028AC0000001021256C384D60FFFFF79F9D2B0461C1F946284F5AAA82F285D14F2AA1C1E9BC314205B068F9B700BF55046142E5A7E00388452B00000010323CFDF5E7D03FFFFD730B5D60F074FFFA07EFFFAF79E15DDDD73DA6141E5FBA141649F83E7FFD539A6
    0   7589 000018 10313286984000       36036000 3A895592 0000010001DFFFFBB8000001B58121179D80000001011A5602028AC0000001021A56C384CBF303EFFFDE7E74AC39CF7A1C1F9C12284FDAB9E194AD57C50A285D3D285D054B3868B3218707EF45080AB0A5F1D00BF50A14B8D5C52CBF74AC0000010322AEE7007FFFFAAE61AB89E0E9FFF11EB994E0E98507E75CCBF75CF01FFF
    0  11754 000010 10313467164000       36036000 42987930 0000010002D7FFFB80000001B5812FF79D8000000101126C04051B00000102126D8441BE4EBA97EAB33E0EB6A10F3828224EF23D58F12137F20FBD5D7A84513475C4C4963743A4276FB51430291BECF84D08A265E0FF06E0B83E494EF422098150CC350AB3F57CC98B0C481942F888610D7EA84D8F9248EB81FFFFE59F942C18
    0   8246 000018 10313377074000       36036000 4489DFD7 00000100025FFFFBB8000001B58111171D8000000101125602028AC0000001021256EBE1D26B6AAE5620E0FDAB9E03FFFFD2B0939E1920E13DED7C38517575C07E9B68A1B14279232E8A0FF7BCF9F779F3EEF3E7DDE7CFBBCF9F74509E5CBD97272BD0A14225CC8CF5C2E1F4A0B80000010322E7B5AFF3E95373B07FFFFA1C1F
    0   8471 000018 10313413110000       54054000 A6100A1F 00000100029FFFFBB8000001B58111171F80000001011A5602028AC0000001021A56EBE1D26B6AAE56256CAC2D5B2B4735BD57281B0E1B2EF2855ADD8A0FF7BCF9F779F3EEF3E7DDE7CFBBCF9F74509E5C3766F7823AA850A55DD5681396283C7CE00000010322E7B5AF4E760FFFFF4383F3AE771F79F8BA73483FFFFC6E7683
    0  62080 000013 10313593290000       54054000 51D53039 000001B32D01E0340BE32380000001B5148200010000000001B80048804000000100008FFFF8000001B58FFFF71F80000001010B7E1F68D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A34618
s=1 n=1 o=83542016
    1    768 000001 10313084166000       34560000 17B0C162 0B77A43F142043FE2106BFF040B731C8AF75CB07CF97BE7D4A14B83E71870E96C739D526AD5A9D96F4D2242D2EDB467D85AFBC00B64B6A44400AF35AA7D7F09FC8105FCA7D002A41AA6F31E51A50FA0335C106B332815E61B4163916E32DDE5CAA18FBAF2C44AF489EFC4400803E7E000F01E0016EAA0583F03BB1154A92E2C8
s=2 n=0 o=84879360
mt=0000023A105B7F80 n=3
s=0 n=1 o=83515392
    0   6672 000018 10313503200000       54054000 F9036039 00000100001FFFFBB8000001B58111379F80000001011AAC04052B000001021AAC108509E71B9E730A171BCE937AA82F48F3C2663CABA850A0B723A0EA0DA4FEA1C0000001032AE7B5732D55732F57AE79418284F7818283C75357D520A13194C93A4D0A1B52626F5498B837AA848B0B641D8B32850C14902A22807334F2107E
s=1 n=48 o=83542016
    1    768 002001 10313118726000       34560000 702D7189 0B77438C142043FE2106BF7040C616D4E2ADF537EFA1C34CAD6DBAD5B755E05246B7CFDF397F317F96F8B01951D265F4A1AA5565BD38910BC16D8398312E6D09F8A7817DFE23AA28A368830074847959B980CC4C94C67F444CDFB7E0029B45C831E49A0363126AA8741A373B5315323E15B083843C8DD3FC9EAC1778C0EFBBEC
    1    768 002001 10313153286000       34560000 9B45FA00 0B770803142043FE2106BED040912C128557152E0ED526ACFDD51AF5DF54534A92A7E3535756A6BA654E9F164E984BDCEF9F3F7B5E94284FD2AE7CF9FA64AA4A57B78AF2D9AB6C86994AA5D4DD56ACFCB38AF5E15754A91596F51224185E0FE10A1C24008FEEE39D6471C90A3306E1CA16CFE4BDD61AB7EC3A72D60A4F17EBC0
    1    768 002001 10313187846000       34560000 9854F630 0B77E793142043FE2106BF70409257D4EABE957A562E0C565783E545D22754FABBA8D0DD3D7CB18F9121D84AB133CD70AC907CE5BD48910FBA6819DD2C5621A3C681D25173EAFEC77EA609B862BD2EA03DE860FD9699BB6609C29BB7995C0594BEA0074CF352571DABDBB0B539B0880024609480384FD60461B51681E4290CCE
    1    768 002001 10313222406000       34560000 E79E384A 0B77D88E142043FE2106BEB040B1EB5E1F74B6BE8EABAEAEAD0E01CF8BBDE6E73A9E68635C3ABDDB92CF6E398C539D78031EEBCDC46534CF61B9ACFDF39AF2C3DDB52FA610AA25DEF9EE06D5935686FAB3EA4FAD4018BE7167D08AD852F61D34CAD066AD5AB5C4B0DEBEB835F25DEA95D96F512242AAB85A35F26CF438DFDA66
    1    768 002001 10313256966000       34560000 F2C3E6B5 0B77C2B0142043FE2106BCD040CFADAB7D06F6AB8FE98E4D0D2DA61363D854F66D3AAE61EC9B0A1D17F0D1149E59F3ED546B5853C26BE834E1527B9D33A5D3402DDEC468761B3A8E2EBB9D14CEBE71821A5DF5D525A696C796F4DA3405942FB27EC3D9352F054D5A968C1FC704DD4A4A670257934FE086FC888BA0E7E7D4D25D
    1    768 002001 10313291526000       34560000 934F66F1 0B771652142043FE2106BD7040B11FD3B90E4274B4E942B71AA4E7DA774786A9F579D5A0D77D2DDF70E2467FA6C905F61ED7AD65BD28910B25BDC60F6DD744F0416F354DB62BA612392EC07C59070F40C8970706DD7AFA510B9C816BBB78D5DF9E14C04829A0156C8DC8A4DAE5FCE48EBE5740F1737776EF7824744100300E5C
    1    768 002001 10313326086000       34560000 DF55FB82 0B774041142043FE2106BD3040B21554EB5E1BE874DF52AD245D8808294049012D374E6BBE7F2C3B039CF9C4E6BC37CAAB57AD9ABE6558063E735F34F19D4ED5B0E4BB57D1DE6AC0FA00972F9F575D0A939D8F5FA5A4F95D96F4D224321081ACA8CA8A4852057340487FF0D50C6A20D5A735D819E88FDB1709DF272D9CE6B404
    1    768 002001 10313360646000       34560000 E042C23B 0B771397142043FE2106BDF040EBD8F4B976189A54A9BAB0A5F6EBFE5BA75DF90E99AA25BA352F96F50204178CE8C413B209E146DFD3114102F0BD2CD097A038BDC4F5E21BBF583746FE02DB540010E0ABCDB752F6950A677AA3F06968B2D121524C14FFE00D127EFE209411398C5458E00B044279F371FE97407DEA6D7FE149
    1    768 002001 10313395206000       34560000 5F54E21A 0B770AFE142043FE2106BED040C9A3BB835B152B8AABAF71712DC1D06F0E22A92407B09D537EA9D43495DEC29E3345684FAB439E95F52AE9733E7D5D2C27F3402FDAA2E90A35ED43206AF4CE29BDADAD5435D5A1924CA73D96F502040C85F9882E08DA5BDB02F0CF19BFF073E81D3277F56355FDBE670F612CE854839F3B893C
    1    768 002001 10313429766000       34560000 B212D92B 0B77BF70142043FE2106BEB040C4D743836BBCEAEAADD3730DF424F0A2267E385C3CCF9F4776596D77CF61BDAE53A422CBB35288F613F2B4A93E8509F3F4B312B8AA0F9ED479C4A4F9EC79DB06D28095F8CCE9A6D581069487CF6BBE2CA9D3E9B0E1915E9D4D1D8E61A5A6E95A44D4D5596F5122435EFDC1AFE34D3CD448194D
    1    768 002001 10313464326000       34560000 B18C0A9F 0B77B4D3142043FE2106BDF040D5FDC9AEC5A4FD54AE2AA4ED14D5FE60E1A0E4ED85A00D54F9ED96F4BA741AEC7BA2BB7338DC024A5401C5E829D431783BCC83E604E3061BBD40BD9EDE0F6BBC8261000ED09D2C2B14D6986A18BF5C8D7590122410708F020003DE83F66F8203A4665BD8FEF7B05B84B75D6EA937B5A98AA706
    1    768 002001 10313498886000       34560000 D7585524 0B77CBB8142043FE2106BEF040B4DF447D064D2B0F9FBF730ABBE7F0AB47883EBBF4E461BCAF71CD5D8E74214A9EB3E5549D52B6FA93EA6F613E7E969A9AF397F75F83FA6B9FA9B0AAADC5D65BD34890F15AB804382DE42FC7CBE2D3320E840766F8A00B91183D15830A575B580DE5D007224787D2A2D686D7ACE7E28600097A
    1    768 002001 10313533446000       34560000 AF58E7DF 0B775B1D142043FE2106BEB040AAEB5853222CEA4FADBFA30E7D286F6BC45442BBA76586704D0A1BCD9469537439EEB5693425A5AEBB976A5FBA9AFAB4323312DDB14FA90FB88E549904874FA28C536153DA699F534E3472A74F2C3A7CE932B54469C318FD2D784FAC2172FD2BE850D5596F502043B3CF5E36ED6EAC4FB80C42
    1    768 002001 10313568006000       34560000 ABF17154 0B77AF5F142043FE2106BCD040B0EC12A55A4D1E15152A9B212DF57A62304C3293E7E35CEC754D525CEE5F3B714DEF09CFD26B85AD73E7CF9F527E4613E5D2DD55EE0172B0B43EB4F9F25CDC1F916922D534D09FBE7CFC9596F4E2441CC416F6726EA8C10C3FFC113FBC148F900989C65AE07A0C8797482C636A3CE4A3D24AE7
    1    768 002001 10313602566000       34560000 0ABFFEF1 0B7745C2142043FE2106BDF040E5E4F5A78232BAD4CB2B7CAD2CCC71DCA70D2CDE959752DF113596F4F264280AA61940BC5BE57D3584910C4911E070EDA40DCB1EE3CD04F54F1DC80D4913FB8688A0225894C0C3273F8678040B38529EA50B0DD1EB2D58EDAF5116FB0DAFFCD134F7EFEBBDC3DEE9D78235E93A4E4135C016BB
    1    768 002001 10313637126000       34560000 3799C245 0B77F1E8142043FE2106B5D0410471DE2EF9FB049212D35695F4EA9F7CBE5947B9D5DF2622FA6F11346157AF4A36ECD5DF3E5565BD389100E29E76C3AE03D7AF64BCD1C1E9D050A237DEACC56B29C2081C4F7D47D430005CB40E046BC01DFBA3C339A918C78C6EBC6EB8FE5833B783F66D084CED19C510A80AB4FFF4F267D73B
    1    768 002001 10313671686000       34560000 967D8823 0B770A24142043FE2106BCF0408FDFC42CF64D2870D6D7D6E73EB7EE6DA658E2D5785475D27DC48B988E222A6A977D68746BAB54F9EEC7B4D1267499CBEA4AC0F90E9ED18AB63E7EFE0D6AEE5BD30810291722D7E7AE8AB1413FF18A0D6CD4AE8D6BFA2EE56B30B11B123034CFE92BB45873EF0F5ECB7B7BC068DC6A35EE89F5
    1    768 002001 10313706246000       34560000 3A7173C8 0B776974142043FE2106BED0409629AB554713DB95A14871729D24BAEC0E5CE61404AA69EB2D5642890569525E38B167EA9527533B3527CEAB3E859A14F72B16B1EADDB8561F57A796BA69F39B422DB0A437D112B9AD5EAD96F4F264045DECEF1A9B05041803A92F149B12392AF114AE229027006227409567ACA2C06FF32413
    1    768 002001 10313740806000       34560000 C7D2A8FB 0B777A52142043FE2106BFF040E60C717D73617A4FA875555ABCCC71D37F7903ED6ADED6E89C6596F4F264152D82F2E6EB87C24F95107C77BF1599211218ABFF45B5DDF6BF002DFC2D6195C6D81C0A4B296775C8263AF82150B3FF0F32777FD20004AE4C109BB1B544ADF63DE1A02CE0983347DE42F654285062782061273D20
    1    768 002001 10313775366000       34560000 0B502567 0B7709F1142043FE2106BEB0409B2C124B6B1578EAAB5E05212D756F6EA65B1A8D7A4F697122FDB3D86F92D8204743E5CFA13EA55DFA486ED3257CFD3217CA6CB899578C34EBC02160DED435D2D7873A1C17CFA4A37D5CB39B6F94D41D3512EA3B1EC2870615D4491F3DDEF9F4753AE9396F4FA742DCF9478D4C0A3F21DB3CFA
    1    768 002001 10313809926000       34560000 5ECB010C 0B77C36A142043FE2106BCD0409868DC5370BEBBAE9EC86971B434EA2C3E8853391DD9975839AAC3E7681DBE6C337EB7CF623EA36AE2A42E9F4342ED2AE552797FEEE442B49FC6B04153DB73E756B635F3FA55F2F37B4DED96F5020428C3DDBD6650BA7F9D788BFC11E786EFC631109FD42FED562D3C454EF588FBD0EDBAF24D
    1    768 002001 10313844486000       34560000 AF39506D 0B77A4D8142043FE2106BD7040B5E1DDE0FE1BED0EB7E68C9AC955496B177CA9FBA74A953E85411F9D363F6A9784EE69D539AF65BD30810F06EB710E9F7C4FD0D504DE05F17D0E620C600BED3008DBDE04FF39208274EDEC7802EBD0A9548E2C9A50126DBB31FB6809075A7F1E706FACFE8FB92416FC0187A3E1F91EE91101ED
    1    768 002001 10313879046000       34560000 05712C18 0B77255A142043FE2106BEB040AFDFAB55097EBE099FBE7B8274F7CF9F5685E5092730A35B4BC5D3976F953D6C977707CFDCD756A60DBA6E2C257EF55A57CABFB0997795F6BA3B4B5D2EBA6EA1428DADF579B1A13FACA92DC4C967BD7EEAB56854A14349B1CF47E852C2D6F69AA830D5396F4E24419FCC80B10C3758A05AC8C6
    1    768 002001 10313913606000       34560000 AE9AF0C7 0B77A67E142043FE2106BEF040AAEC1255A70E88845F9683C823F249629485AE12772A63DA775D73988E5DA228B76A74198BB6B4ED33E54E5F437B4ABBA4B340F8BEBD7AEA783DD8AABAA4D65BD348902BF93363AA770D1B12B7E211A9B4307C6BB371DCBCA26935C371DD21A2E1C77142A3E712761ECA6A5FD2FDD64E152276
    1    768 002001 10313948166000       34560000 ACC2E004 0B7754CB142043FE2106BED0409620164D6E254AC4A34849881F04CF64A4B774DA77ABC8F073212B8E936D6B78FB74A21708BB4AFA9B9AE9695B4D09F3D84AC47DF222A850AE4F7CF9552A50E0D847B215690E61B98EF9CD96F4EA54359A2F8944EF42DDC491DD918B74FEFF24C06FAD1C103B17DB96C2B0E481558BC145E751
    1    768 002001 10313982726000       34560000 CD97C3C4 0B775B17142043FE2106BCB0409C9D2749C24E6DEDABAB3F85DC180E6BBED70A6BFAAE9342D75CB357F069BF4239EA7A4F953FA3B105B84FD2BE84ADD10872724E392F99496E09851DAC3A4FDD5280A694DCB5F33E4BC075284D8BB38FB4E8E543933E735E96B72FDFA57D3AB272349F596F4DA342A57A99118D3ECCA2382249
    1    768 002001 10314017286000       34560000 1A9B92D3 0B77F65F142043FE2106B4B040B5EE257F5A4EAE2FB33EA564E6B2E922D283A1E9184FA0464D1952586A63BA745A92C1109FA5D09612A535DD4754960D7872C3B8993F491B5488CD0E7794B4D75A7EFA0BACCAD2AA7E587571C3EF208E88E97534DF3E5CFAAF454E9525A5AAC25549D5596F4F2642CFF4D71E63E209C1422174
    1    768 002001 10314051846000       34560000 ACDD607A 0B77CAAD142043FE2106B4D040C9A1AE87070D2B8A61BDE0FA156B0E61BD90963BD7EE9F467DC14D37559F5B229600C8DBE74755BB76BA6892BF4AE9EC44AC1187C6EA1770E9D418F9F3E7DD1D3A5495F584BB21BA4AF9DF96F49A3435C77BF2B430751054A84E9911B48FD53684A228E7B6A083FF4E13BEA58F7BBDEB42D87A
    1    768 002001 10314086406000       34560000 F0F349A9 0B7739A0142043FE2106BF3040CAD56DB0ADEDCA886A264C979D74B7210CE8F783E7D0DD29A5325E09ABF4BAFAD968895CD7AF5D3259095F6B4B608B9ADAD3564D393BA52FDED77D5DD2574FABD2AD4D4C4494DD2986A61596F4EA5427FAB77948F9BE85EF4E47AFC111C4B891219C911FCC15553D78D6D627735BF4FBBD848D
    1    768 002001 10314120966000       34560000 820F65E4 0B7730C8142043FE2106BF3040B0E3EDB2AA957A73EC8B8706B6FB896B2F84F95584AFD2D3552D7AEBDD7A7F9DF937446956A759FC3231A3538CFA21C84A96F46CA873A5E929744CAC6569CBD4EFA54B5437CF6C247EE92D96F50204042D4149B74736A93E1067E131245E6930C2413DE01041C3EB4006DB73B9803D730B6675
    1    768 002001 10314155526000       34560000 AD8EE918 0B7725D6142043FE2106BF3040CB12EDD111474CF52C105CF77757B3D4707D46E3EA53A9A57F33E8EFD5F489B15A1D4ADA589D5C8D77D5D53E7B0E39173210704AFA9A4913913A7E890DA7CFE7427D49FBE4CE6BA17D4A9D96F51224070582D89C6BFB7247E77C920FD06129872011065BDDE1961BC68E75A3AF8B310F76F3C5
    1    768 002001 10314190086000       34560000 7DA10B13 0B77A27A142043FE2106BEF040E4A13B25571B8F29DFA571C907357A97D354A5FA0B6992DFABD50D6A691F2F7C9D5B8B892A227B0ADBE535DF3A7CB69BE7D3D3F91BA447E8738E7F39FAA2D65BD30810614490B2CD29D723A82FF62C81DF187606DFFFB60B3810744ECA02C170811041B2770C12B3BEFE03A416DB1CADF4B5F4
    1    768 002001 10314224646000       34560000 3A6E7AE8 0B7752A3142043FE2106BD5040CBDFE8BC596D7ADC30262E2F7EC4CE94A6E05755B5881DB88F32B7FDEB9583E6B6C86F4B8FB8FDB3D8361743855D73E4CE6E596F4B264162C73A8757932084C47F43A84E9398FDD877739B3AB8CB22F64E80202525AEEFFC9FE47D18E4069D26ACD67231B6B18A61AED6D0FFEDA0123447A1E0
    1    768 002001 10314259206000       34560000 F41D53A8 0B772777142043FE2106BFF040E9B0DCAFB1FBEBF0A4D27EA6B4EFBE448136BE84B0B89586F9CD96F49A34227B8B50F41476540412E595C041D53F021282799141E3C53FB0668425C0E1B0C40588560D1817965580E954A70EED929146EEED36C4D10DE9EA600630C15DB52913DDE0EDE8BFECCF7211346E9B9BFDE082F7F78F
    1    768 002001 10314293766000       34560000 49332B20 0B774AA2142043FE2106BF5040E49D59E1614D6DF6F62E4CA63D46D48B9D7EF8B579E329BA493967FDA246B5720ED4CF69CE7B14ED322FD3A087ADF2986B92D96F4A244175E6FAF7D642E0D39CA176A24A3E7E6FA7E64F43F0AB3725D47124CDC7D93F123FEAA0F8FAAF76451A0175806E7BB7834232DE1AA52FC7E1EB722E6F
    1    768 002001 10314328326000       34560000 B394DF85 0B77C33D142043FE2106B5B040EBB1757722946B8F8B447AF976E9ABBF4BE8BD6D6261576FDD2F375ACBBE7C95ED78D19E6119C48B892861B9A15EC29D8360C3AEF9F427E92DAAAB4ADD773E5BD32850A8DB6A15FA1F89B9D940F5A14FEFCF7653110FF58EC47E8BF978B8000E7C384839AAC70008A81401B346471BC48B7C24
    1    768 002001 10314362886000       34560000 DF3AE945 0B7781FC142043FE2106BDF04123655CA58A6AC4CE895285612D04BE485F0E6E9E8D2E57AEFA0796F4D224213646F39C166177C72E089BC7D6C274BED7B9A04D56F921087F83713EDE2BDFEB1C946171D7478295750B9FECEC310EEC51A3C1E02F996D8DF000349DEB87712F8E2AC4DE1D092808003D4C61620300DE0F8C5ED7
    1    768 002001 10314397446000       34560000 4B34EA2F 0B77236B142043FE2106BCF040CAEAC3856A4ECB846D2C6785CDB7D9A2BE6091CBECE892D6B0937BDAF3DB397C9643DAEFC86B850DF3E7B612AA7CF9CD37D412F95E3E09AE73C4234EA254DE5BD389102E45F265D86A1FAFB09BE488D3C0DE42EF3CF418211800E39BE118864503F6C254F79BBBF8E01A6E0AF604140A2A956D
    1    768 002001 10314432006000       34560000 82A1B67E 0B777882142043FE2106BDD041037DDBE311D0EAD4AA11D759ED05617BD77132AAEFB8155496BE74B60A714AED35A54FD2D187E5BD20810CBE8D69EFFDA7C5796C64DFDC2CF265BBFB1E3E73930033475F6B4C80008D26F906055BF10C681C460276533C09732E6EEAE9DBBB77BD8E74A8D200D0F7BE99DC2F38AF31FD18BA8D
    1    768 002001 10314466566000       34560000 C07185E6 0B778192142043FE2106BED040AFE9AB536E4D28511EC2CDC14D84B9ABC37CFA13F4DA6B47A5ADF3B1AF6BD6A651F497AFA870AD6DF2B4B46BD77AF952A7D2C8A7EAB5D5361F2AAF1A1BDA8FA66FAF6961075BE142A50AE796F4C204397CD376D1916BFBEC0F1DE3C0F53E4A3B01E523E2D737E53DE695D83D400A6258912CEC
    1    768 002001 10314501126000       34560000 12CA502B 0B77B3C3142043FE2106BFD040BB31C07721FA5DDC112C5309FCB215F77EBD4D7AF612C286B6D5C1CE615783AE157AD0A9534D65BD368D0BA7C8C8F13B9E007E041771710D7EDD72E4F214AD81BE3FF5A23C65FD83B838F783C5B06F407A8901EE06B32CC113AE99CEDB3A0D1E327755381D85C05E6992C9310CC11E18805E18
    1    768 002001 10314535686000       34560000 9822CB02 0B775426142043FE2106BDF04098A55BEB226AED7246177B5D54B27E47D90DAA9D0FA3967EA75D96F4E2442F26B2433A9A6BE4E7A002998A5A28BD85C75120E6000180DBC89407BDD8160350CD9EE9A536BE71BB7166E6F3516DD6C22296D427A1677F7EFB9E065AE58701B43C83E520076AAE92E5570B7FAEED2B5B686692C1
    1    768 002001 10314570246000       34560000 190FC2D2 0B774524142043FE2106BD3040B221CFECBE0EC755EC948CFB76C530AB444B0DD3E7D09FBB192ABAF4D778C36212AAD0DCDBA55D54F25A089CD35283E9D19F70A361EBDB6E201772FA0F4A5475D753B12BA753A1A19CE75D96F4E2443820070304AA83B82A26F41867F6A591618C0428449DE2474C16A91262C0140361201C61
    1    768 002001 10314604806000       34560000 26D47D2F 0B77EFA1142043FE2106BCD040B65CAA55AA4F0CE9ABAA9B7486B55A98B5D04883EACAD2487CADCE69D5A13E7C973707CE62255371D3EAD0A9527CAA93DB72DD1BF2A1751C27BF7C5553D7DCE6E87C46FBF555A956AD0DF596F4CA142A29D065CD43870D284FE0A5933C77602051283661FAA4FD1F10E7CFFE5A2EBB1F87D05D
    1    768 002001 10314639366000       34560000 92F16953 0B77732C142043FE2106BD5040CA6E68A8BA1D7870B5BE5D5E03A4B4AC0E7C9763A7D469577F32AAFCADDFAEFDF3EBEA63EAE7112BD850173EA50DF267EE2BB96F4A2442BBD94EE3AC1AF927E87E0074CF1C5204A338E3D192FA227B1652E9CC92EF801DF009A5C2CFF10FCA571B039877975CE6057EFB68787DE76D76F2F530
    1    768 002001 10314673926000       34560000 1ABDE77B 0B775F09142043FE2106BEF040AFE211575A4CDE10DD42A55DD434D0A15760834EC9E586574F0CB2888A95257AFB56C7CED4D6A5213297D09F527EA61917D3BFF8AAE578CFB7707D5F3434D65BD3081007F3DAA3FF673BF46AEEE5D872BFD253B62CDEF177BA5B214D8D2BFAA71F95E022A544855B9CBFBE295F2D564FB6314C
    1    768 002001 10314708486000       34560000 2F98B1D3 0B77DC08142043FE2106BDD0409B71C3E9BE3AF5549825B035FC925777B0AE0DC73B1F398559F6D3AFDC2A808FB3DAEF6BBDA965BD30810C0DDC30CFBEF08B61118BE71C96E91C70C2FA2CBF04226F8BE4B65C0036D1290621D6D769DEB58749E3F8E553C65AF01FC3FB8638C4308988F7CE8101F784E185B874988EF0187AB8
    1    768 002001 10314743046000       34560000 D0001DBA 0B776637142043FE2106BEF040B0E4255771851E04AB437B24E5B75AA255E899A537E352DAE14D3162B49FBA7A8643E69AEB587B710B986E9EC37B6138C7F32FF9775A7A51A76F9D11F3E7565BD38910D3B14FE00ADC76A87D186192D50C105B4D7670730241FBC81BDB82EA4407EEF9050B87EE4814346CEB436F279AE841AA
s=2 n=0 o=84879360
mt=0000023A104F7BB0 n=3
s=0 n=1 o=83515392
    0   6734 000018 10313557254000       36036000 9B59BAC3 00000100005FFFFBB8000001B58112371D80000001011AAC04052B000001021AAC108509CFD7A373CE6142FBD48D9B4BF68DFB9D545874975D2FD4F00000010322AC25CCEEE097351767D9D26E6141E69967D732A9BF4284E1DD0A0F2DE55D0A1319EE4D0A175262EE4C59D5C3B4BF75A26D1B4DC9D554544418507AFAE6B4CC
s=1 n=1 o=83542016
    1    768 002001 10314777606000       34560000 3A2561F3 0B77B6BB142043FE2106BCF040B229425757169EAADF26718C25A57364584C9911184D672F7D49FA57D497A670AA40E7CF6958734DF3E7E95D3E7BA13357D397F94F771449376F2F61F3DAFE5BD3A95000CD29BD2C2FA9E8B47C2833E56EC2F2233501E8C1797C77B7D256ED6FC169BCA2EB86CFDC0257C607A3293A8830AD6D
s=2 n=0 o=84879360
005003:0000 Failed to save title 0 to file D:/Users/ZB/Videos/MovieDumpMKV/Stranger Things/Season 4/14/title_t00.mkv
Encountered 17 unclassified errors
error=0x06052400 count=11 name=Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
error=0xC0000010 count=5 name=OS error - The specified request is not a valid operation for the target device
error=0xC00000B5 count=1 name=OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired
005004:0080 0 titles saved, 1 failed
Dal1980
Post by Dal1980 »
I've been trying for days now with this disc, does anyone fancy having a crack at the issue (here's the latest log)
Debug log started at Thu Oct 20 09:38:58 2022 , written by MakeMKV v1.17.1 win(x64-release)
SDF  v090: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_KLQL7Q85643
SDF  v090: HL-DT-ST_BD-RE_BP50NB40_1.01_211711231615_SIKZ9HCP21526
DEBUG: Code 2317353419 at ){w*J;.g+g#oU!d0i:213132974
DEBUG: Code 0 at ){w*J;.g+g#oU!d0i:121264786
DEBUG: Code 1 at ){w*J;.g+g#oU!d0i:121264786
DEBUG: Code 2 at ){w*J;.g+g#oU!d0i:121264786
DEBUG: Code 3 at ){w*J;.g+g#oU!d0i:121264786
DEBUG: Code 4 at ){w*J;.g+g#oU!d0i:121264786
DEBUG: Code 5 at ){w*J;.g+g#oU!d0i:121264786
DEBUG: Code 2317353419 at ){w*J;.g+g#oU!d0i:121264648
DEBUG: Code 0 at U5PW&tql`c>RT]\::29401934
005014:0000 Saving 1 titles into directory file://D:/Users/ZB/Videos/MovieDumpMKV/Stranger Things/Season 4/15
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1275809792'
002003:0000 Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom1' at offset '1275809792'
001003:0020 DEBUG: Code 622954 at ^Qjq;+-!?d/:>aLz.mj):121261773
---- Failed D:/Users/ZB/Videos/MovieDumpMKV/Stranger Things/Season 4/15/title_t00.mkv
ch_0        9962242290000 0
ch_1        9962782830000 0
ch_2        9963323370000 0
ch_3        9963863910000 0
ch_4        9964404450000 0
ch_5        9964944990000 0
ch_6        9965485530000 0
ch_7        9966026070000 1
mt=0000015B2F63B710 n=3
s=0 n=13 o=1274812416
    0  74722 000011  9965485530000       54054000 3A9567C8 000001B32D01E03409972380000001B5148200010000000001B804FCC04000000100008FFFF8000001B58FFFF71F80000001010B7E1F68D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A34618
    0   3115 000018  9965395440000       54054000 3A596B09 00000100001FFFFBB8000001B58111179F80000001010AAC04052B000001020AAC04052B000001030AAC04052B000001040AAC04052B000001050AAC04052B000001060AAD399BFFC5DFFC5D7337FF8BBFF8BAE66FFF177FF175CCDFFE2EFFE2EB99BFFC5DFFC5D7337FF8BBFF8BAE66FFF177FF175CCDFFE2EFFE2EB99BFFC5
    0   3019 000018  9965449494000       36036000 F78EA3C0 00000100005FFFFBB8000001B58111171D80000001010AAC04052B000001020AAC04052B000001030AAC04052B000001040AAC04052B000001050AAC04052B000001060AAD399BFFC5DFFC5D7337FF8BBFF8BAE66FFF177FF175CCDFFE2EFFE2EB99BFFC5DFFC5D7337FF8BBFF8BAE66FFF177FF175CCDFFE2EFFE2EB99BFFC5
    0   3397 000010  9965629674000       36036000 93D4B5D7 000001000157FFFB80000001B5811FF71D80000001010A6C04051B000001020A6C04051B000001030A6C04051B000001040A6C04051B000001050A6C04051B000001060A6D237FF8BBFF8BA8DFFE2EFFE2EA37FF8BBFF8BA8DFFE2EFFE2EA37FF8BBFF8BA8DFFE2EFFE2EA37FF8BBFF8BA8DFFE2EFFE2EA37FF8BBFF8BA8DFFE
    0   2601 000018  9965539584000       36036000 F12F0275 0000010000DFFFFBB8000001B58111179D80000001010A5602028AC0000001020A5602028AC0000001030A5602028AC0000001040A5602028AC0000001050A5602028AC0000001060A568E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177
    0   2626 000018  9965575620000       54054000 11C374B1 00000100011FFFFBB8000001B58111179F80000001010A5602028AC0000001020A5602028AC0000001030A5602028AC0000001040A5602028AC0000001050A5602028AC0000001060A568E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177FF174E66FFF177
    0   2750 000010  9965755800000       54054000 244828B0 000001000217FFFB80000001B5811FF79F80000001010A6C04051B000001020A6C04051B000001030A6C04051B000001040A6C04051B000001050A6C04051B000001060A6C04051B000001070A6C118217E1F68D7003DFB11C57B8BF6EBBF6EF8DB9AEE85EE3BBDCE5DB2C030FCD0ED76C4B0EB2B4007BF623CA47FA4003EEF8
    0   2556 000018  9965665710000       54054000 F02ECF69 00000100019FFFFBB8000001B58111171F80000001010A5602028AC0000001020A5602028AC0000001030A5602028AC0000001040A5602028AC0000001050A5602028AC0000001060A5602028AC0000001070A5609AB6141F80F800337102B84C01D81402A05004E184D01800EC981A8FCA269089A4CDD5C313BEE6E5E368503
    0   2546 000018  9965719764000       36036000 580B2DB0 0000010001DFFFFBB8000001B58111179D80000001010A5602028AC0000001020A5602028AC0000001030A5602028AC0000001040A5602028AC0000001050A5602028AC0000001060A5602028AC0000001070A5609AB6141F80F800337102B84C01D81402A05004E184D01800EC981A8FCA269089A4CDD5C313BEE6E5E368503
    0   2262 000010  9965899944000       36036000 867E356B 0000010002D7FFFB80000001B5811FF79D80000001010A6C04051B000001020A6C04051B000001030A6C04051B000001040A6C04051B000001050A6C04051B000001060A6C04051B000001070A6C12087306600100EA0235603E000CC216032800C099B0000001080A6C12089A0E5FFF3542E048D8000001090A6C04051B0000
    0   2561 000018  9965809854000       36036000 C2C4BC42 00000100025FFFFBB8000001B58111171D80000001010A5602028AC0000001020A5602028AC0000001030A5602028AC0000001040A5602028AC0000001050A5602028AC0000001060A5602028AC0000001070A5609AB8507CC007803581BFFFE9CF01F0006ABB8407F09803B028430280270C2180C00764C0D47E5134841A4CD
    0   2579 000018  9965845890000       54054000 09AA9FF4 00000100029FFFFBB8000001B58111171F80000001010A5602028AC0000001020A5602028AC0000001030A5602028AC0000001040A5602028AC0000001050A5602028AC0000001060A5602028AC0000001070A56098507E8347FF807F5CE6003C01AC0DFFFF4382E601F05AC5ACC0AEF000D803AAAE141901FC2600EC0A10C0A
    0  81912 000013  9966026070000       54054000 69C6CC45 000001B32D01E03409972380000001B5148200010000000001B804FCC7C000000100008FFFF8000001B58FFFF71F80000001010B7E1F68D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A346186D1A3468C30DA3468D1861B468D1A30C368D1A34618
s=1 n=1 o=1274787840
    1    768 000001  9965514246000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
s=2 n=0 o=1275809792
mt=0000015B2F63B190 n=3
s=0 n=1 o=1274812416
    0  18513 004018  9965935980000       54054000 0B6E0256 00000100001FFFFBB8000001B58115479F800000010112AC04052B0000010212AC04052B0000010312AC04052B0000010412AC04052B0000010512AC04052B0000010612AC04052B0000010712AC134BF4BF49831E92043C245B076C1DC289A181A18434164C26949CE82C30B29C0F7D54809828AC0000010812AC134BF4BF09
s=1 n=40 o=1274787840
    1    768 006001  9965548806000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965583366000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965617926000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965652486000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965687046000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965721606000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965756166000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965790726000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965825286000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965859846000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965894406000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965928966000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965963526000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9965998086000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966032646000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966067206000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966101766000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966136326000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966170886000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966205446000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966240006000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966274566000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966309126000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966343686000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966378246000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966412806000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966447366000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966481926000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966516486000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966551046000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966585606000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966620166000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966654726000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966689286000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966723846000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966758406000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966792966000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966827526000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966862086000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
    1    768 006001  9966896646000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
mt=0000015B2F577BB0 n=3
    0  12940 004018  9965990034000       36036000 82BC09C1 00000100005FFFFBB8000001B58114471D80000001011AAC04052B000001021AAC04052B000001031AAC04052B000001041AAC04052B000001051AAC04052B000001061AAC04052B000001071AAC134BF4BF49863D2410F091A83961DC2834A2CA26A0B0C0D427292525003CFAA98220A2B0000001081AAC134BF4BF4BF4BF4B
    1    768 006001  9966931206000       34560000 D2547F1A 0B77B24C142043FE2106A0B041FF3ABE7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7DFFCEAF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F3E7CF9F796F882040000000078DB6DB6DB6DE3C
005003:0000 Failed to save title 0 to file D:/Users/ZB/Videos/MovieDumpMKV/Stranger Things/Season 4/15/title_t00.mkv
error=0xC0000010 count=6 name=OS error - The specified request is not a valid operation for the target device
I'm trying to work out if it's one of these reasons
1. Some advanced copy protection
2. The DVD disc has a fault (no physical damage can be seen)
- I've ruled out drive issues (kind of) as I've tried this with both a drive bought through the group and my old faithful backup drive.
Any help appreciated, thanks.
cyberdman
Post by cyberdman »
Where did you get these DVDs? They are obviously homemade and maybe they have an authoring problem. The Stranger Things Season 4 was never released on disc of any kind yet.
Dal1980
Post by Dal1980 »
Here's the place I bought them from: https://www.onbuy.com/gb/stranger-thing ... son-4-4dvd
I'm getting new discs sent out.
Netflix don't official release any Stranger Things to the UK (unless that's changes since S2). I'd be quite happy to buy direct from Netflix (Region 2) but they won't sell me any so I have to buy from where ever I can buy them from.
I have a Netflix sub now anyway but I'm all about the discs really which I'm sure everyone here is too.
Any tips on spotting homemade. It used be easy with discs having that green tint meant they were home burns (these look like normal silver). The box and the artwork maybe super easy although I'm not sure how they would have got the artwork if it's not been released... leaked I guess.
I've been in touch with them since my last msg and they are going to send me replacements anyhow, hopefully better luck with them when they arrive.
cyberdman
Post by cyberdman »
Hmm I don't know what those are, but they are not official. Netflix never released any Stranger Things discs past season 2 in the US either. Good luck.
Dal1980
Post by Dal1980 »
Oh, didn't know that, that sucks, I'm sure there's a cult market.
Thanks for the input.
ryley
Post by ryley »
Dal1980 wrote: Wed Nov 02, 2022 7:13 pm Any tips on spotting homemade. It used be easy with discs having that green tint meant they were home burns (these look like normal silver)
Check if the discs have any sort of copy protection with MakeMKV. Some legitimate 'made-on-demand' discs may lack conventional copy protection, but DVDs will generally be protected by CSS and Blu-rays by AACS.
Dal1980 wrote: Wed Nov 02, 2022 7:13 pm The box and the artwork maybe super easy although I'm not sure how they would have got the artwork if it's not been released... leaked I guess.
Whatever box and artwork came with the disc was most likely home-made or fan art. When there is no genuine product to compare against, pirates can slap together a design or repurpose an earlier official design pretty easily. There is no need for a leak. The same can be said of the DVD menus in your screenshot. In the future, I find it useful to check the barcodes (or UPC/EAN) of items to check whether they might be legitimate. The UPC and EAN in the listing you linked to do not show up on a quick Google search. But other (presumably legitimate) items on that site do have the correct UPC.
Dal1980 wrote: Wed Nov 02, 2022 7:13 pm I've been in touch with them since my last msg and they are going to send me replacements anyhow, hopefully better luck with them when they arrive.
Sorry to say, but I think your replacements will have the same issue of most likely being home-made bootlegs.
odin58
Post by odin58 »
Stranger Things Seasons 3 and 4 have not been officially released......Much like the Mandalorian and The Expanse Seasons 5 and up. I'm still waiting for these myself. These and other knockoffs are usually made on crappy dvd media. It isn't a problem with MakeMKV.
Dal1980
Post by Dal1980 »
I didn't mean to imply that I thought it was a problem with MakeMKV if that's how this came across. I was interested in how I identify where the problem was (disc, drive, the way I was ripping, or any additional methods that I could have tried).
As it happens, they sent out disc 1 and that ripped no problem first time so definitely a problem with the original disc.
I haven't had time to put all of this together but I think I might now have a complete S4 boxset to watch.
