MisterXDTV
#7606 Post by MisterXDTV » Sat Oct 08, 2022 9:36 am
RESET_9999 wrote:
Sat Sep 03, 2022 1:33 am
now that the DV bug with cinema mode configuration is fixed on my C2, I can resume testing the internal player VS my x800m2.
With this new firmware, now L1 High contrast no longer clip(Internal & shield). Internal player looks perfect to me but I think I see a better L1 response on the x800m2 since the C2 update. Still quite different though.
Hi everyone,
I tried to keep up with this thread and I apologize if this was already asked:
Was the LG C2 bug L1/L2 metadata bug reported here in July with the UHD Blu-ray players (X700-X800M2) fixed by a later LG firmware upgrade?
Is there any other issue with Dolby Vision playback with LG C2 using these players as of now?
#7607 Post by RESET_9999 » Sat Oct 08, 2022 1:24 pm
legosoff wrote:
Sat Oct 08, 2022 6:28 am
I understand you. Any TrueHD, DTS-HD and EAC3 JOC on AAC. But if you can mp4 lossless audio, think of something format? TrueHD+ac3 will it work with device supports at all?
you can mux lossless audio (and 7.1 aac) with 7-1-1 but you have to demux your mkv files first.
legosoff
#7608 Post by legosoff » Sat Oct 08, 2022 2:19 pm
Well, thank you.
Gatorman
#7609 Post by Gatorman » Sat Oct 08, 2022 4:58 pm
When creating DV 8.1 from DV 5 and HDR10 files, is it necessary to match MaxCLL and MaxFALL values from the HDR10 version?
More reasons to collect physical media. Ugoos AM6B+.
DruZod
#7610 Post by DruZod » Sat Oct 08, 2022 5:04 pm
Hello all, from all my research on this topic, this massive thread seems to be referenced one way or another. Apologies if what I'm about to ask has been asked before, I have tried to search this thread and other places before posting.
I have an LG C6 (2016 Model) OLED TV, latest firmware, I do not have any other external players so I use the internal player via a USB HDD for all my files. I have managed to get a couple of Profile 5 DV files to play in DV this way (no green tint, actually plays). Using MediaInfo on the files, one is dvhe and the other is hev1. And from what I can tell, the frame rate has to be 23.976 fps (I have a 24fps file that refuses to play at all). Obviously they are also MP4.
I want to try and get Profile 8 DV videos to work as the backward compatibility with HDR10 is very useful, however, no matter what I try, I can not get a Profile 8 DV file to play in DV (It either falls back to HDR or just refuses to play).
My question is, does anyone know how to get a Profile 8 DV file to play in DV on the internal player of an LG C6 (or any 2016 OLED model)? Another mini question is would anyone know how to change the frame rate on my 24fps file to 23.976 fps without re-encoding?
Thank you
agneva
#7611 Post by agneva » Sat Oct 08, 2022 5:18 pm
is it possible to remux a mkv with DV in mp4 DV Profil 5** (for LG TV) ?
Format : HEVC
Format-Profil : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec-ID : V_MPEGH/ISO/HEVC
provided there is no EL, just RPU.
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec-ID : dvhe
Codec-ID/Info : High Efficiency Video Coding with Dolby Vision
quietvoid
#7612 Post by quietvoid » Sat Oct 08, 2022 7:22 pm
Quick update about the FireTV Stick 4K Max (2021).
It now seems to support CMv4.0 metadata. I just got an update to FireOS 7.6.0.3 (PS7603/3110).
Hopefully it was planned, since Amazon's new shows seem to use CMv4.0.
#7613 Post by RESET_9999 » Sat Oct 08, 2022 7:39 pm
Nice...
1- does L1 now behaves like the Shield and C2 internal apps? (low contrast L1 has no effect on the x800m2)
https://www.youtube.com/watch?v=TJtwu1bwlug
2- Does it still have grey letterbox for cropped DV content?
3- Can it send LPCM 7.1 audio? (turns out the C2 can't passthrough LPCM 7.1 with the internal apps)
quietvoid
#7614 Post by quietvoid » Sat Oct 08, 2022 8:13 pm
Nice...
L1 is the same as before, it still has grey letterbox bars.
I don't know about the audio.
Though I thought the C2 internal player used to clip on that high contrast shot?
Now the C2 is just slightly brighter all the time, but it behaves the same as the Fire stick.
#7615 Post by RESET_9999 » Sat Oct 08, 2022 8:36 pm
it was caused by the old firmware. Now the internal player no longer clip high contrast (clip less than the x800m2 overall as well).
so no effect at all with low contrast L1 just like before?
quietvoid
#7616 Post by quietvoid » Sat Oct 08, 2022 8:40 pm
Low contrast works fine, as it always has.
#7617 Post by RESET_9999 » Sat Oct 08, 2022 8:52 pm
thanks, only 45CAD, so cheap for what it can do. Think I'm going to buy one and hope LPCM 7.1 works (or even better truehd mat)
ragico
#7618 Post by ragico » Sat Oct 08, 2022 10:14 pm
@quietvoid
Please can you share your latest kodi build?
Thank you
quietvoid
#7619 Post by quietvoid » Sun Oct 09, 2022 2:36 am
@quietvoid
Thank you
https://mega.nz/file/dd9ywRTT#rjmXux78H ... fN3DERxd_0
ragico
#7620 Post by ragico » Sun Oct 09, 2022 10:14 am
@quietvoid
Thank you
Thank you. Very kind.
