#7621
Post
by RESET_9999 » Sat Oct 08, 2022 8:36 pm
quietvoid wrote: ↑Sat Oct 08, 2022 8:13 pm
Though I thought the C2 internal player used to clip on that high contrast shot?
it was caused by the old firmware. Now the internal player no longer clip high contrast (clip less than the x800m2 overall as well).
so no effect at all with low contrast L1 just like before?
quietvoid
#7622
Post
by quietvoid » Sat Oct 08, 2022 8:40 pm
RESET_9999 wrote: ↑Sat Oct 08, 2022 8:36 pm
Low contrast works fine, as it always has.
#7623
Post
by RESET_9999 » Sat Oct 08, 2022 8:52 pm
thanks, only 45CAD, so cheap for what it can do. Think I'm going to buy one and hope LPCM 7.1 works (or even better truehd mat)
ragico
#7624
Post
by ragico » Sat Oct 08, 2022 10:14 pm
@quietvoid
Please can you share your latest kodi build?
Thank you
#7628
Post
by RESET_9999 » Sun Oct 09, 2022 2:29 pm
kazuma wrote: ↑Sun Oct 09, 2022 2:06 pm
reset_9999 i'm getting this error with the lord of the rings mkv file. with 4-2-2. what is the reason?
https://ibb.co/JzMzrb4
yes the new 7.1 EC3 audio encoder does that and you can ignore it. see:
viewtopic.php?p=127616#p127616
Beware that the new version of the script auto-mux to TS. And it will also keep the lossless audio as track #1 so dont forget to switch to the audio track #2 on plex or the native lg player otherwise you"ll get HDR10 because plex will have to convert the audio on the fly and plex apparently cant do it without breaking DV. I hope one day, PLEX will add DV support for when it does "direct stream" instead of "direct play". This way, we wouldn't have to convert lossless audio to EC3 7.1 since plex can do it on the fly.
If you don't like the new auto-muxing behavior, it can be turned off by editing the bat file.
![Image](https://i.ibb.co/FKK6F5Y/Capture.png)
pianoaccurate
#7629
Post
by pianoaccurate » Mon Oct 10, 2022 8:11 pm
Have a quick question I haven't been able to find a good answer to. I have ripped my Dolby Vision discs to my NAS. To watch them, I'm currently just using plex on a shield. But the red push issue is annoying, and no FEL support. Also, I have an atmos system
It sounds like either an Oppo clone or an X800m2 is the way to go. Is one better than the other? Also, what is the reason everyone uses the Sony instead of the Panasonic UB820? Is it not able to play files from wifi/usb?
Gatorman
#7630
Post
by Gatorman » Wed Oct 12, 2022 3:13 am
I would like to generate DV metadata, with DaVinci Resolve, for files I've already used madVR on. Is it necessary to remove DV from the files before creating a prores (MOV) file?
More reasons to collect physical media. 2019 Shield TV Pro.
Gatorman
#7631
Post
by Gatorman » Wed Oct 12, 2022 3:20 am
pianoaccurate wrote: ↑Mon Oct 10, 2022 8:11 pm
Check out the signature in the post above yours. Look at the "DoVi Playback Devices" tab.
pianoaccurate
#7632
Post
by pianoaccurate » Wed Oct 12, 2022 4:22 am
Thanks Gatorman, that spreadsheet is why I figured the sony x800m2 was the way to go. But there is no mention of UB820, and it's been difficult to find much discussion about it. Is this just because it's more expensive so fewer people bother to go that route, or is there something negative to it and it should be avoided?
#7633
Post
by Manixx2020beyound » Wed Oct 12, 2022 9:53 am
Gatorman wrote: ↑Wed Oct 12, 2022 3:13 am
No
Resolve will discard.
#7634
Post
by RESET_9999 » Wed Oct 12, 2022 12:55 pm
Manixx2020beyound wrote: ↑Wed Oct 12, 2022 9:53 am
No
actually, it's the dovi_tool that will discard the old rpu when you'll inject the new one. The RPU gets removed when you convert to prores so Resolve wont even know the original had metadata(it wouldnt matter if it had metadata anyway).
pianoaccurate wrote: ↑Wed Oct 12, 2022 4:22 am
From what i can read about the UB820, it has poor file playback compatibility.
Gatorman
#7635
Post
by Gatorman » Thu Oct 13, 2022 2:48 am
I've used EAE to encode 5.1 audio tracks (DTS XLL to EC3). Is there a way to set the bit rate?
