I can never find this
jasee3
Hi, I can never find this, (oulined in red). I am using the Windows version of MKV. It always remains grey so I cannot alter any of the files! Can anyone help please?
- mkv.jpg (6.49 KiB) Viewed 101296 times
Re: I can never find this
Removed years ago in favor of live decryption
I was wondering why I didn't remember it...
Yeah it was the stream function
Let us know what your trying to do and we can probably tell you a way to do it with the live decryption ripping
jasee3
IThanks for your replies. I'm trying to extract the 3D part of bluerays. Apparently it should be possible with MKV.
Yeah you can just click the big disc for that and make sure to select 3d under the video section
jasee3
Thanks but where is the big disc?Billycar11 wrote: Wed Oct 05, 2022 7:53 pm Yeah you can just click the big disc for that and make sure to select 3d under the video section
My first screen on loading a dic is this If I click on anything marked in red it just goes here
The second screen is the correct one
From there you uncheck 2 out of those 3 the correct one is likely the second one uncheck the others.
And then do the drop down and you should see a 3d file to enable
