FEATURE REQUEST: Select multiple lines and edit property for all selected
Radiocomms237
#1 Post by Radiocomms237 » Tue Apr 05, 2022 8:19 am
Could we have the capability to select multiple lines (or tracks) using SHIFT+click for multiple sequential lines or CTRL+click for multiple non-sequential lines, the same as you can in Windows Explorer, and then edit the property (such as "Name", "Language", "Order weight", etc.) for all selected lines at once?
It would also be handy to select multiple lines and check/uncheck all the selected tracks as well.
Radiocomms237
Re: Select multiple lines and edit property for all selected
#2 Post by Radiocomms237 » Sat Apr 09, 2022 12:38 am
I wanted to clarify that last request...
We would select/highlight all the appropriate tracks and then use the right-click menu to "Toggle Item", "Select All" or "Unselect All"
Obviously if you tried to uncheck a track using a checkbox then all the selections/highlights would disappear.
Radiocomms237
#3 Post by Radiocomms237 » Mon Jul 18, 2022 1:49 am
I know I've asked this many times before but, do the developers of MakeMKV even read these forums or should I be emailing somebody directly with feature requests?
This feature has been the most basic function of Windows Explorer since before I can remember, and would make setup so much quicker (IE select ALL the necessary tracks and change a value ONCE instead of having to change every singe track individually).
Radiocomms237
#4 Post by Radiocomms237 » Thu Sep 22, 2022 7:55 am
I wanted to bump this one again because I feel this feature would make setup so much easier.
If we could select, say, all the video tracks (using CTRL+click) and then name them, set the language, and set the default of all the selected tracks at once it would save a ton of setup time.
It would also save a heap of time while setting all the order weights if we could select a whole block of subtitle tracks and change the weight of them all in one click.
Pretty please, with sugar on top?
cinome
Re: FEATURE REQUEST: Select multiple lines and edit property for all selected
#5 Post by cinome » Wed Oct 05, 2022 10:21 am
I would like to see this too, especially under Linux.
There I cannot un-/tick the checkboxes with the space key, which disables the very fast "arrow down, space, repeat"-technique. ;)
I have to point and click with the mouse. This is tiring if a disk has support for 10 languages with 2 subtitles each and then maybe 4 extras. Nearly a hundred clicks for one disk.
cinome
#6 Post by cinome » Wed Oct 05, 2022 12:23 pm
An improvement to workflow and a workaround:
Instead of easily selecting the languages manually, I am now using the expert options to define the profile to deselect all but english and german.
Since I always want the original language plus the german language for visitors, this only works for english movies. For other languages I still have to select manually.
-sel:all,+sel:(favlang|nolang|ger),-sel:mvcvideo,=100:all,-10:favlang
Aditionally I set the minimum title length way up to 20 Minutes. That leads to many missed extras, but reduces clicking.
