I can never find this
Everything related to Blu-ray 3D and 3D MKV files
jasee3
Post by jasee3 » Wed Oct 05, 2022 7:42 am
Hi, I can never find this, (oulined in red). I am using the Windows version of MKV. It always remains grey so I cannot alter any of the files! Can anyone help please?
Re: I can never find this
Post by Billycar11 » Wed Oct 05, 2022 12:38 pm
Removed years ago in favor of live decryption
Post by Woodstock » Wed Oct 05, 2022 12:43 pm
I was wondering why I didn't remember it...
Post by Billycar11 » Wed Oct 05, 2022 1:38 pm
Yeah it was the stream function
Let us know what your trying to do and we can probably tell you a way to do it with the live decryption ripping
jasee3
Post by jasee3 » Wed Oct 05, 2022 6:43 pm
IThanks for your replies. I'm trying to extract the 3D part of bluerays. Apparently it should be possible with MKV.
Post by Billycar11 » Wed Oct 05, 2022 7:53 pm
Yeah you can just click the big disc for that and make sure to select 3d under the video section
jasee3
Post by jasee3 » Thu Oct 06, 2022 5:36 am
Billycar11 wrote: Wed Oct 05, 2022 7:53 pm Yeah you can just click the big disc for that and make sure to select 3d under the video section
Thanks but where is the big disc?
My first screen on loading a dic is this
If I click on anything marked in red it just goes here
Post by Billycar11 » Thu Oct 06, 2022 8:31 pm
The second screen is the correct one
From there you uncheck 2 out of those 3 the correct one is likely the second one uncheck the others.
And then do the drop down and you should see a 3d file to enable
