#7576 Post by RESET_9999 » Wed Oct 05, 2022 2:46 am
johnjon94 wrote: Wed Oct 05, 2022 2:19 am
try this: https://drive.google.com/file/d/1rhF3Od ... sp=sharing
only support 23.976/24/25 fps for now.. will add more in the official 1.6.1
johnjon94
#7577 Post by johnjon94 » Wed Oct 05, 2022 2:58 am
RESET_9999 wrote: Wed Oct 05, 2022 2:46 am
This version seems to work great at detecting the correct FPS. I can see right now that its displaying the correct 24000/1001 when importing the HEVC file. However for the subtitles it isn't setting any language for them, and the first subtitle which is forced isn't displaying the Forced tag.
Text #1
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 1 h 28 min
Bit rate                                 : 0 b/s
Frame rate                               : 0.004 FPS
Stream size                              : 269 Bytes (0%)
Text #2
Format                                   : Timed Text
Codec ID                                 : tx3g
Duration                                 : 1 h 51 min
Bit rate                                 : 117 b/s
Frame rate                               : 0.812 FPS
Stream size                              : 95.7 KiB (0%)
One thing I'd recommend adding in the official version is to include chapter files if they exist in the MKV file. Just as easy as adding any other track with
-add chapters.txt
#7578 Post by RESET_9999 » Wed Oct 05, 2022 3:03 am
yes I know. it is on my todo list since @sw5163 told me about it..
I just dont care much about the mp4 workflows because i dont use them. TS container is much better than mp4.
johnjon94
#7579 Post by johnjon94 » Wed Oct 05, 2022 3:24 am
RESET_9999 wrote: Wed Oct 05, 2022 3:03 am
I can't seem to get the fake P5 to play on Apple TV through Plex or directly. Doesn't seem to play on my computer either, just a black screen. I'm curious if there's just a small codec misconfiguration.
Video
Format profile                           : Main 10@L5@High
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible / SMPTE ST 2086
Codec ID                                 : dvh1
Source duration                          : 1 h 52 min
Bit rate                                 : 24.3 Mb/s
Maximum bit rate                         : 46.6 Mb/s
Width                                    : 3 832 pixels
Height                                   : 1 574 pixels
Display aspect ratio                     : 2.40:1
Original frame rate                      : 0.729 FPS
Standard                                 : NTSC
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.168
Stream size                              : 19.0 GiB (97%)
Source stream size                       : 19.0 GiB (97%)
Title                                    : ?@GPAC2.1-DEV-rev321-gc68d8a53-master
Encoded date                             : UTC 2022-10-05 02:52:44
Tagged date                              : UTC 2022-10-05 02:54:42
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 1190 cd/m2
Maximum Frame-Average Light Level        : 412 cd/m2
mdhd_Duration                            : 6721756
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : ec-3
Duration                                 : 1 h 52 min
Bit rate                                 : 768 kb/s
Maximum bit rate                         : 811 kb/s
Stream size                              : 615 MiB (3%)
Title                                    : ec3@GPAC2.1-DEV-rev321-gc68d8a53-master
Encoded date                             : UTC 2022-10-05 02:54:39
Complexity index                         : 16
Number of dynamic objects                : 15
Text #1
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 0 b/s
Title                                    : forced.srt@GPAC2.1-DEV-rev321-gc68d8a53-master
Encoded date                             : UTC 2022-10-05 02:54:42
Text #2
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 117 b/s
Title                                    : srt@GPAC2.1-DEV-rev321-gc68d8a53-master
#7580 Post by RESET_9999 » Wed Oct 05, 2022 3:38 am
idk, i dont have any apple device... @ragico did all the testing when I did the apple workflows.
the only difference is the latest mp4box...
the cmd is the same i showed you before.
"%mp4box2_path%" -add %BL%%mbox% -add %audio% -add %subtitles_path% -tmp %TEMP% "%output_path%%filename%_DoVi.sub.DD.mp4"
#7581 Post by RESET_9999 » Wed Oct 05, 2022 3:43 am
are you sure its not your source again?
did you fix the fps bitstream with ffmpeg on that file? because i noticed that it cause some playback issue on my TV
johnjon94
#7582 Post by johnjon94 » Wed Oct 05, 2022 4:01 am
RESET_9999 wrote: Wed Oct 05, 2022 3:43 am are you sure its not your source again?
Yeah I used bitstream filters with ffmpeg to fix the fps. These files play with no issue on my television normally and with any other player I've tried them on.
johnjon94
#7583 Post by johnjon94 » Wed Oct 05, 2022 6:23 am
I've figured out the issue, its the demuxer that you're using. This is also why the framerate wasn't being pulled correctly, and I noticed for ATVP files that it wasn't demuxing with the accurate aspect ratio.
eac3to:
 Track Importing HEVC - Width 3832 Height 1574
ffmpeg/tsmuxer:
Track Importing HEVC - Width 3838 Height 1606
After demuxing with ffmpeg instead of eac3to then running the mp4box command the resulting file played with no issue and retained the aspect ratio and framerate. (And confirmed that Plex for Apple TV is triggering Dolby Vision and Atmos as well as the internal Plex app for LG C2)
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU / SMPTE ST 2086, HDR10 compatible
Codec ID                                 : dvh1
Bit rate                                 : 24.2 Mb/s
Width                                    : 3 838 pixels
Height                                   : 1 606 pixels
Bits/(Pixel*Frame)                       : 0.164
mdhd_Duration                            : 6721424
Audio
Format                                   : E-AC-3 JOC
Codec ID                                 : ec-3
Bit rate                                 : 768 kb/s
Text
Format                                   : Timed Text
Codec ID                                 : tx3g
Bit rate                                 : 117 b/s
Title                                    : SDH
sw5163
#7584 Post by sw5163 » Wed Oct 05, 2022 6:51 am
johnjon94 wrote: Wed Oct 05, 2022 3:24 am I can't seem to get the fake P5 to play on Apple TV through Plex or directly. Doesn't seem to play on my computer either, just a black screen. I'm curious if there's just a small codec misconfiguration.
Some demo files:
https://drive.google.com/drive/folders/ ... Ps8NfU53Ee
Some audio test files:
https://drive.google.com/drive/folders/ ... F22-4q1qTe
#7585 Post by RESET_9999 » Wed Oct 05, 2022 11:05 am
johnjon94 wrote: Wed Oct 05, 2022 6:23 am I've figured out the issue, its the demuxer that you're using. This is also why the framerate wasn't being pulled correctly, and I noticed for ATVP files that it wasn't demuxing with the accurate aspect ratio.
well to be fair the issue is Apple's stupidity with their crappy encodes.
Anyway, I guess you'll have to do those over-cropped webdl manually because EAC3to is my number 1 demuxer since its the only one that allow me to demux all the tracks without knowing the streams ID.
can you input a resolution with mp4box?
ragico
#7586 Post by ragico » Wed Oct 05, 2022 12:49 pm
sw5163 wrote: Wed Oct 05, 2022 1:35 am Apple's native player or any player that "passthrough" that file to Apple's player core. Avoid using INFUSE.
I play them in "FILE" App directly SMB from my PC.
Pls can you explain where to find the "File" app?
It does not exist in the appstore.
Thank you
sw5163
#7587 Post by sw5163 » Wed Oct 05, 2022 3:34 pm
ragico wrote: Wed Oct 05, 2022 12:49 pm Pls can you explain where to find the "File" app?
Thank you
It's on the iOS appstore, the apple's official file manage app, im not sure if it's on ATV's store.
https://support.apple.com/en-us/HT206481
It's very hard to use and not recommended. Plex plays DV fine.
FE File Explorer is an alternate 3rd party file mangage app also plays DV.
Edit: FE File Explorer only plays DV on iOS, not ATV. See below discussion.
Or you can do what Manixx2020beyound did, if you have itunes or mac.
Manixx2020beyound wrote: Mon Jun 27, 2022 8:39 pm And u can upload that to your apple tv library
If anyone know how to import video through network directly into the "TV" app (the black background with white TV on it) on windows without having to use itunes, please let me know, very much appreciate!
ragico
#7588 Post by ragico » Wed Oct 05, 2022 3:46 pm
sw5163 wrote: Wed Oct 05, 2022 3:34 pm FE File Explorer is an alternate 3rd party file mangage app also plays DV.
Not on my ATV. It plays in sdr.
Only FileBrowseTV plays in DV
sw5163
#7589 Post by sw5163 » Wed Oct 05, 2022 4:07 pm
ragico wrote: Wed Oct 05, 2022 3:46 pm
Maybe app on ATV is a little different from iOS.
I think there is a "hardware decode+" option in the FE File Explorer, it guarantees DV passthrough.
If it's only "hardware decode" or "software decode", it's not using the Apple's player core.
The attachment IMG_1771.PNG is no longer available
It's strange ATV doesn't have an official file management app though.
ragico
#7590 Post by ragico » Wed Oct 05, 2022 4:30 pm
sw5163 wrote: Wed Oct 05, 2022 4:07 pm Maybe app on ATV is a little different from iOS.
I think there is a "hardware decode+" option in the FE File Explorer, it guarantees DV passtrough
Unfortunately there is not the option "hardware decode+" nor any decode option in the ATV version.
