johnjon94
#7561 Post by johnjon94 » Wed Oct 05, 2022 1:11 am
RESET_9999 wrote:
Wed Oct 05, 2022 1:08 am
yes, I forgot to remove the "P5" in the menu title. It can do P7/P8 input and the output will always be P8 (or fake p5 for apple)
Understood! Thanks for the clarification, I'm giving it a test now. I also own an Apple TV and can test if the fake P5 works. Is there a specific player that its been said to work on like Infuse?
#7562 Post by RESET_9999 » Wed Oct 05, 2022 1:14 am
you have to use PLEX IIRC. infuse removed support for fake p5 i think.
I'm noticing that the 7.1 EC3 audio is stuttering. EC3 Atmos and ffmpeg EC3 5.1 are fine.
TS and mkv have no issue with 7.1 EC3 tracks
johnjon94
#7563 Post by johnjon94 » Wed Oct 05, 2022 1:30 am
A few things I noticed that need to be set with mp4box -
When adding the video input you need to add hdr=none to make sure the static metadata from the HDR10 base file is not changed.
viewtopic.php?p=124635#p124635
When using dv profile to 8 (or whatever profile the file is that you're muxing into MP4) you need to include dv-profile=8.1 (I'm not sure how this would affect the "fake" P5 though).
The flag xps_inband needs to be set if the source file is dvhe rather than dvh1 (also not sure how this would affect the "fake" P5).
The settings -for-test cleans up the MP4 file by removing the "Encoded Date" "Tagged Date" and "Writing Application" information for each track.
So the full command would be like this
mp4box -for-test -add "input.hevc:hdr=none:dv-profile=8.1:xps_inband"
sw5163
#7564 Post by sw5163 » Wed Oct 05, 2022 1:35 am
staknhalo wrote:
Tue Oct 04, 2022 9:58 pm
johnjon94 wrote:
Tue Oct 04, 2022 3:37 pm
hdr=none prevents HDR10 from being displayed twice in the mediainfo
i've seen this, is that the only thing it effects (mediainfo redaout)? is playback effected at all on anything?
I can't tell the difference between quality from my eyes. So I just don't bother to change it.
mp4box.exe -add "%BL%:hdr=none:dv-profile=8.1:xps_inband" -add "audio" -add "subtitle" -brand mp42isom -ab dby1 -no-iod -enable 1 "output.mp4"
Hi, I'm curious about what does `-ab dby1 -no-iod -enable 1` mean?
Will they affect final quality of the image?
Could you please explain a little bit more of this, thanks!
Apple's native player or any player that "passthrough" that file to Apple's player core. Avoid using INFUSE.
I play them in "FILE" App directly SMB from my PC.
sw5163 wrote:
Thu Sep 22, 2022 4:56 pm
Also do you guys know if there is an option in mp4box to convert dvhe->dvh1 when importing mp4?
Currently I'm using:
ffmpeg -i dvhe.mp4 -c copy dv.hevc
mp4box -add dv.hevc -new dvh1.mp4
But it would be nice if I could just skip the ffmpeg step.
Thanks.
The command is: https://github.com/gpac/gpac/issues/199 ... 1262491409
MP4Box -add source_dvhe.mp4:dopt:xps_inband=no -new source_dvh1.mp4
Also if anyone is interested, the latest mp4box auto detects DV Profile now, instead of tag everything as P5 dvh1.
https://github.com/gpac/gpac/issues/199 ... 1263426298
johnjon94
#7565 Post by johnjon94 » Wed Oct 05, 2022 1:49 am
The fake P5 doesn't seem to be working properly. It set a very odd FPS resulting in this crazy length
#7566 Post by RESET_9999 » Wed Oct 05, 2022 1:57 am
I know, and all of this is in the script.
when apple is used, it's not used...
The only thing i didnt add is " -brand mp42isom -ab dby1 -no-iod -enable 1 " because i didnt want to mess up apple since i did all the test with @ragico with it.
I always been using it on the old mp4muxer workflows though
johnjon94
#7567 Post by johnjon94 » Wed Oct 05, 2022 1:57 am
These are the general Dolby Vision parameters that are required when authoring a DV-compliant MP4 file. If you look at that link you posted to github, you'll see the comment under the person is using those same settings. I don't believe it has any effect on the quality but rather ensuring its a proper DV MP4 file.
#7568 Post by RESET_9999 » Wed Oct 05, 2022 2:00 am
maybe an appleTV web-dl ? i know the old mp4muxer also had issue muxing those file because they dont have FPS bistream information.
with the sample files i used, there is no problem:
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible / SMPTE ST 2086
Codec ID                                 : dvh1
Duration                                 : 2 min 1 s
Bit rate                                 : 12.1 Mb/s
Maximum bit rate                         : 30.8 Mb/s
Bits/(Pixel*Frame)                       : 0.061
Stream size                              : 176 MiB (85%)
Title                                    : hevc@GPAC2.1-DEV-rev321-gc68d8a53-master
Encoded date                             : UTC 2022-10-05 01:59:51
Tagged date                              : UTC 2022-10-05 01:59:52
mdhd_Duration                            : 121830
johnjon94
#7569 Post by johnjon94 » Wed Oct 05, 2022 2:02 am
Video
Codec ID                                 : dvh1
Thats interesting, it is an Apple TV file, but the fps was corrected at the bitstream level so it shouldn't be pulling an incorrect fps. I'll try with a different file
#7570 Post by RESET_9999 » Wed Oct 05, 2022 2:02 am
hdr=none
we tested on appletv and LPCM audio didn't work when using it IIRC so that's why you see HDR10 two times when choosing fake p5
johnjon94
#7571 Post by johnjon94 » Wed Oct 05, 2022 2:10 am
Video
Codec ID                                 : dvh1
Can you point me to the place in the code where the final mp4box settings are for the Apple TV mux with AC3? It will work if I manually set the fps with mp4box, I can't seem to figure out why its pulling the incorrect fps from the stream.
#7572 Post by RESET_9999 » Wed Oct 05, 2022 2:15 am
tell me how to set the fps with mp4box and I'll make the process automatic.
line 19287 if input is 1 video 1 lossy audio and 1 srt
"%mp4box2_path%" -add %BL%%mbox% -add %audio% -add %subtitles_path% -tmp %TEMP% "%output_path%%filename%_DoVi.sub.DD.mp4"
sw5163
#7573 Post by sw5163 » Wed Oct 05, 2022 2:19 am
hdr=none
lol, apple is hilarious
johnjon94
#7574 Post by johnjon94 » Wed Oct 05, 2022 2:19 am
It goes directly after the hevc input file like this
mp4box -add "input.hevc:fps=24000/1001"
#7575 Post by RESET_9999 » Wed Oct 05, 2022 2:23 am
thanks. next version will set a fps all the time regardless of if the input is appleTV web-dl or not
