When v1.6.7 starts and initially tries to read the disk/DVD Drive I get the message Fatal error occurred, program will now exit
The program then quits, this happens every time, can someone help?
v1.6.7 Fatal error occurred, program will now exit
- Contact:
Re: v1.6.7 Fatal error occurred, program will now exit
It's a bug and the cause is unknown. Please submit the crash dump per instructions at http://www.makemkv.com/onlinehelp/dump.html
OK will do later when I am home with the machine
I have the file however its 19.2 MB zipped, is this normal? If s where should I send it?
- Contact:
support@makemkv.comDoubleSpeed wrote:I have the file however its 19.2 MB zipped, is this normal? If s where should I send it?
- Contact:
