i've seen this, is that the only thing it effects (mediainfo redaout)? is playback effected at all on anything?
So as expected, it doesnt trigger DV on LG C8. So I kept the old mp4muxer workflow for older LG TV owners but now the main mode(single track) can do both "fake P5" and HEV1 P8.
I didn't add more subtitles/audio support because it requires more work but I will.
here's a beta version if you want to test:
https://drive.google.com/file/d/1xh4esC ... sp=sharing
When you select option 1, it brings you to the DV Fixer option instead of the correct muxing option, I had to select option 4.RESET_9999 wrote: ↑Wed Oct 05, 2022 12:12 amSo as expected, it doesnt trigger DV on LG C8. So I kept the old mp4muxer workflow for older LG TV owners but now the main mode(single track) can do both "fake P5" and HEV1 P8.
Is it possible to make a setting to mux from MKV P8 to MP4 P8? It looks like only the P5 muxing options are setRESET_9999 wrote: ↑Wed Oct 05, 2022 1:04 amoups, there was an error in my menu order.
https://drive.google.com/file/d/102G6_Z ... sp=sharing
yes, I forgot to remove the "P5" in the menu title. It can do P7/P8 input and the output will always be P8 (or fake p5 for apple)
Understood! Thanks for the clarification, I'm giving it a test now. I also own an Apple TV and can test if the fake P5 works. Is there a specific player that its been said to work on like Infuse?RESET_9999 wrote: ↑Wed Oct 05, 2022 1:08 amyes, I forgot to remove the "P5" in the menu title. It can do P7/P8 input and the output will always be P8 (or fake p5 for apple)
you have to use PLEX IIRC. infuse removed support for fake p5 i think.
I'm noticing that the 7.1 EC3 audio is stuttering. EC3 Atmos and ffmpeg EC3 5.1 are fine.
TS and mkv have no issue with 7.1 EC3 tracks
A few things I noticed that need to be set with mp4box -RESET_9999 wrote: ↑Wed Oct 05, 2022 1:14 amyou have to use PLEX IIRC. infuse removed support for fake p5 i think.
When adding the video input you need to add hdr=none to make sure the static metadata from the HDR10 base file is not changed.
viewtopic.php?p=124635#p124635
When using dv profile to 8 (or whatever profile the file is that you're muxing into MP4) you need to include dv-profile=8.1 (I'm not sure how this would affect the "fake" P5 though).
The flag xps_inband needs to be set if the source file is dvhe rather than dvh1 (also not sure how this would affect the "fake" P5).
The settings -for-test cleans up the MP4 file by removing the "Encoded Date" "Tagged Date" and "Writing Application" information for each track.
So the full command would be like this
mp4box -for-test -add "input.hevc:hdr=none:dv-profile=8.1:xps_inband"
I can't tell the difference between quality from my eyes. So I just don't bother to change it.
Hi, I'm curious about what does `-ab dby1 -no-iod -enable 1` mean?johnjon94 wrote: ↑Tue Oct 04, 2022 3:37 pmCode: Select all
mp4box.exe -add "%BL%:hdr=none:dv-profile=8.1:xps_inband" -add "audio" -add "subtitle" -brand mp42isom -ab dby1 -no-iod -enable 1 "output.mp4"
Will they affect final quality of the image?
Could you please explain a little bit more of this, thanks!
Apple's native player or any player that "passthrough" that file to Apple's player core. Avoid using INFUSE.
I play them in "FILE" App directly SMB from my PC.
The command is: https://github.com/gpac/gpac/issues/199 ... 1262491409
MP4Box -add source_dvhe.mp4:dopt:xps_inband=no -new source_dvh1.mp4
https://github.com/gpac/gpac/issues/199 ... 1263426298
The fake P5 doesn't seem to be working properly. It set a very odd FPS resulting in this crazy lengthRESET_9999 wrote: ↑Wed Oct 05, 2022 1:14 amyou have to use PLEX IIRC. infuse removed support for fake p5 i think.
I know, and all of this is in the script.
when apple is used, it's not used...
The only thing i didnt add is " -brand mp42isom -ab dby1 -no-iod -enable 1 " because i didnt want to mess up apple since i did all the test with @ragico with it.
I always been using it on the old mp4muxer workflows though
These are the general Dolby Vision parameters that are required when authoring a DV-compliant MP4 file. If you look at that link you posted to github, you'll see the comment under the person is using those same settings. I don't believe it has any effect on the quality but rather ensuring its a proper DV MP4 file.Hi, I'm curious about what does `-ab dby1 -no-iod -enable 1` mean?
maybe an appleTV web-dl ? i know the old mp4muxer also had issue muxing those file because they dont have FPS bistream information.
with the sample files i used, there is no problem:
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible / SMPTE ST 2086
Codec ID : dvh1
Duration : 2 min 1 s
Bit rate : 12.1 Mb/s
Maximum bit rate : 30.8 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.061
Stream size : 176 MiB (85%)
Title : hevc@GPAC2.1-DEV-rev321-gc68d8a53-master
Encoded date : UTC 2022-10-05 01:59:51
Tagged date : UTC 2022-10-05 01:59:52
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
mdhd_Duration : 121830
Codec configuration box : hvcC+dvcC
Thats interesting, it is an Apple TV file, but the fps was corrected at the bitstream level so it shouldn't be pulling an incorrect fps. I'll try with a different fileRESET_9999 wrote: ↑Wed Oct 05, 2022 2:00 ammaybe an appleTV web-dl ? i know the old mp4muxer also had issue muxing those file because they dont have FPS bistream information.
Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5.1@High HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible / SMPTE ST 2086 Codec ID : dvh1 Duration : 2 min 1 s Bit rate : 12.1 Mb/s Maximum bit rate : 30.8 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Compression mode : Lossy Bits/(Pixel*Frame) : 0.061 Stream size : 176 MiB (85%) Title : hevc@GPAC2.1-DEV-rev321-gc68d8a53-master Encoded date : UTC 2022-10-05 01:59:51 Tagged date : UTC 2022-10-05 01:59:52 Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2 mdhd_Duration : 121830 Codec configuration box : hvcC+dvcC
