johnjon94
Post by johnjon94 »
RESET_9999 wrote:
Mon Oct 03, 2022 7:20 pm
Gatorman wrote:
Mon Oct 03, 2022 7:13 pm
Ah, I see. Changing the timeline resolution from 3840x2160 to 3840x1600, to match the original file, isn't enough?
yes, you can do that as well.
Make sure you leave the blanking to 0 in that case.
Hey just a heads up, I would recommend using mp4box for muxing rather than mp4muxer for the mp4 workflows. Its much faster and doesn't take hours to render, and you can add all of the necessary tracks in one mux rather than multiple.
For example
mp4box.exe -add "%BL%:hdr=none:dv-profile=8.1:xps_inband" -add "audio" -add "subtitle" -brand mp42isom -ab dby1 -no-iod -enable 1 "output.mp4"
hdr=none prevents HDR10 from being displayed twice in the mediainfo, dv-profile=8.1 sets the profile, and :xps_inband is required if the file is dvhe.
johnjon94 wrote:
Tue Oct 04, 2022 3:37 pm
yes, I know and that's how the apple iOS mp4 workflows are made.
But... Can the very old mp4box we have to use for older TV (EG my C8) do that though? I never tried.
Unless you're saying that using the latest mp4box works on older LG TVs?
johnjon94
Post by johnjon94 »
RESET_9999 wrote:
Tue Oct 04, 2022 4:29 pm
I haven't tested the older mp4box just yet, what is the reason for using the older versions?
Also I noticed that in your script, if there are multiple subtitles in the input file it seems to only include the first subtitle rather than all of them. (mode 7-1-5)
johnjon94 wrote:
Tue Oct 04, 2022 4:38 pm
Only the very first version of the mp4muxer works on older LG TVs. And the newer mp4box doesnt work with that old mp4muxer version because of the missing BL compatibility id.
yes, it prioritizes subtitles with FORCED flag. So if your input doesnt have a forced flag, it will only takes the first subtitle
the first workflow is more flexible, you can manually input 1 video and 2 audio/2 subs
johnjon94
Post by johnjon94 »
RESET_9999 wrote:
Tue Oct 04, 2022 4:57 pm
Is it possible to adjust the first workflow to use mp4box rather than mp4muxer and add more than just 2 subtitles?
johnjon94 wrote:
Tue Oct 04, 2022 5:42 pm
Yes, I'm currently implementing MKV and TS muxing for all the workflows that convert audio so I think I'll add mp4 muxing with mp4box as well.
May I know why you want more than two subtitles? forced and complete is not enough?
johnjon94
Post by johnjon94 »
RESET_9999 wrote:
Tue Oct 04, 2022 5:59 pm
mp4box muxing rather than mp4muxer has a drastic change on the time it takes to complete the mux, so that would be great. (minutes vs hours)
For subtitles, I like to include all of the subtitles for every language that it available in my MP4 files. So if I have an MKV file with 20+ subtitles, I include those with the MP4 as well. I also include chapters when they are available, which can also be added using mp4box.
johnjon94 wrote:
Tue Oct 04, 2022 6:06 pm
which playback device are you using?
johnjon94
Post by johnjon94 »
RESET_9999 wrote:
Tue Oct 04, 2022 7:06 pm
LG C2 OLED as well as an NVIDIA Shield
staknhalo
Post by staknhalo »
i've seen this, is that the only thing it effects (mediainfo redaout)? is playback effected at all on anything?
johnjon94 wrote:
Tue Oct 04, 2022 7:29 pm
So as expected, it doesnt trigger DV on LG C8. So I kept the old mp4muxer workflow for older LG TV owners but now the main mode(single track) can do both "fake P5" and HEV1 P8.
I didn't add more subtitles/audio support because it requires more work but I will.
here's a beta version if you want to test:
https://drive.google.com/file/d/1xh4esC ... sp=sharing
johnjon94
Post by johnjon94 »
RESET_9999 wrote:
Wed Oct 05, 2022 12:12 am
When you select option 1, it brings you to the DV Fixer option instead of the correct muxing option, I had to select option 4. Image
oups, there was an error in my menu order.
https://drive.google.com/file/d/102G6_Z ... sp=sharing
johnjon94
Post by johnjon94 »
RESET_9999 wrote:
Wed Oct 05, 2022 1:04 am
Is it possible to make a setting to mux from MKV P8 to MP4 P8? It looks like only the P5 muxing options are set
yes, I forgot to remove the "P5" in the menu title. It can do P7/P8 input and the output will always be P8 (or fake p5 for apple)
