legosoff
#7531 Post by legosoff » Mon Oct 03, 2022 11:48 am
RESET_9999 wrote: Mon Oct 03, 2022 11:17 am
legosoff wrote: Mon Oct 03, 2022 10:04 am Hi, RESET_9999! I wanted you to do 7/4/2, 7/4/3, 7/4/4 and 7/4/5 command mode save y and n. I need to save RPU.
these workflows convert/inject without extracting the rpu so I won't do that since it would make the already long process much longer.
You can use 2-2 to extract the rpu of any file.
Yes, I already had a 2/2 he green screen. 7/4/2 RPU excellent screen.
#7532 Post by RESET_9999 » Mon Oct 03, 2022 12:02 pm
legosoff wrote: Mon Oct 03, 2022 11:48 am Yes, I already had a 2/2 he green screen.
what? 2-2 is an extractor/reader mode...
legosoff
#7533 Post by legosoff » Mon Oct 03, 2022 1:31 pm
RESET_9999 wrote: Mon Oct 03, 2022 12:02 pm
Yes 2-2 green screen. Okay, I checked again after I'll let you know.
duder
#7534 Post by duder » Mon Oct 03, 2022 1:44 pm
There is a rip mkv video file with following specs: dvhe.08.06, BL+RPU, 3 840*1 600, 23.976 FPS
After muxing it with tsMuxer or with RESET_9999’s DoVi Scripts (infinite gratitude)) 800m2 gives grey bars and 1080p60 signal.
Panasonic tv internal player stretches the image vertically removing black bars and lengthen object on the screen.
Checked with m2ts or mp4 containers.
Is there a way to solve this issues?
#7535 Post by RESET_9999 » Mon Oct 03, 2022 2:10 pm
legosoff wrote: Mon Oct 03, 2022 1:31 pm Yes 2-2 green screen. Okay, I checked again after I'll let you know.
I'm talking about 2-2... not 7-2-2 or whatever mp4muxer workflow you tried....
please stop with that. you seem confused about what DV profile your input files are.
#7536 Post by RESET_9999 » Mon Oct 03, 2022 2:11 pm
duder wrote: Mon Oct 03, 2022 1:44 pm There is a rip mkv video file with following specs: dvhe.08.06, BL+RPU, 3 840*1 600, 23.976 FPS
Cropped video(black bars were not encoded in the video).
On the x800m2, there is no solution and it sounds like your TV cant play cropped content properly as well.
datman
#7537 Post by datman » Mon Oct 03, 2022 5:25 pm
I recently bought a sony 77a80j set and now I can get DV. I see none of my MKV files will display in DV, I guess I now recall that limitation at the time was no concern. Buried in this thread are there simplified steps to make new backups or is this still very much a bit complicated.
Something else I discovered what I thought was caused by an update to my Oppo 203 player a few years ago. My MKV Dolby Atmos backups no longer displayed Atmos only multichannel+ dolby. The DTSX remain normal. As far as I can tell the sound is the same. So figuring out DV and playing the original discs both issues go away.
Gatorman
#7538 Post by Gatorman » Mon Oct 03, 2022 6:46 pm
While using Resolve to generate DV metadata, do I only need to "Detect Scene Cuts" for variable aspect ratio files, or for cropped files as well?
#7539 Post by RESET_9999 » Mon Oct 03, 2022 6:57 pm
Gatorman wrote: Mon Oct 03, 2022 6:46 pm While using Resolve to generate DV metadata, do I only need to "Detect Scene Cuts" for variable aspect ratio files, or for cropped files as well?
you always need to detect scene cuts, otherwise, your metadata wont be dynamic.
you always need to set the proper blanking too.
#7540 Post by RESET_9999 » Mon Oct 03, 2022 6:59 pm
datman wrote: Mon Oct 03, 2022 5:25 pm I recently bought a sony 77a80j set and now I can get DV. I see none of my MKV files will display in DV, I guess I now recall that limitation at the time was no concern. Buried in this thread are there simplified steps to make new backups or is this still very much a bit complicated.
https://github.com/justdan96/tsMuxer/releases
Gatorman
#7541 Post by Gatorman » Mon Oct 03, 2022 7:13 pm
RESET_9999 wrote: Mon Oct 03, 2022 6:57 pm
Ah, I see. Changing the timeline resolution from 3840x2160 to 3840x1600, to match the original file, isn't enough?
#7542 Post by RESET_9999 » Mon Oct 03, 2022 7:20 pm
Gatorman wrote: Mon Oct 03, 2022 7:13 pm Ah, I see. Changing the timeline resolution from 3840x2160 to 3840x1600, to match the original file, isn't enough?
yes, you can do that as well.
Make sure you leave the blanking to 0 in that case.
johnjon94
#7543 Post by johnjon94 » Tue Oct 04, 2022 3:37 pm
RESET_9999 wrote: Mon Oct 03, 2022 7:20 pm
Hey just a heads up, I would recommend using mp4box for muxing rather than mp4muxer for the mp4 workflows. Its much faster and doesn't take hours to render, and you can add all of the necessary tracks in one mux rather than multiple.
For example
mp4box.exe -add "%BL%:hdr=none:dv-profile=8.1:xps_inband" -add "audio" -add "subtitle" -brand mp42isom -ab dby1 -no-iod -enable 1 "output.mp4"
hdr=none prevents HDR10 from being displayed twice in the mediainfo, dv-profile=8.1 sets the profile, and :xps_inband is required if the file is dvhe.
#7544 Post by RESET_9999 » Tue Oct 04, 2022 4:29 pm
johnjon94 wrote: Tue Oct 04, 2022 3:37 pm
yes, I know and that's how the apple iOS mp4 workflows are made.
But... Can the very old mp4box we have to use for older TV (EG my C8) do that though? I never tried.
Unless you're saying that using the latest mp4box works on older LG TVs?
johnjon94
#7545 Post by johnjon94 » Tue Oct 04, 2022 4:38 pm
RESET_9999 wrote: Tue Oct 04, 2022 4:29 pm
I haven't tested the older mp4box just yet, what is the reason for using the older versions?
Also I noticed that in your script, if there are multiple subtitles in the input file it seems to only include the first subtitle rather than all of them. (mode 7-1-5)
