Anyone got a key for THE LOST BOYS UHD?
grazstarr
Post by grazstarr »
Just got a copy of The Lost Boys 4k. Won't rip. Any way of making this happen?
MakeMKV v1.17.1 darwin(arm64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BP60NB10 1.02 SIM04M2NA3545d" opened in OS access mode.
Downloading latest SDF to /Users/grazianodimartino/Library/MakeMKV ...
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
Evaluation version, 2 day(s) out of 30 remaining
Downloading latest HK to /Users/grazianodimartino/Library/MakeMKV ...
Saved AACS dump file as /Users/grazianodimartino/Library/MakeMKV/MKB20_v76_The_Lost_Boys_7A6B.tgz
OS device name: /dev/rdisk5
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM04M2NA3545
Firmware date: 2120-05-07 09:35
Highest AACS version: 76
Firmware version: 1.02
Disc Information
Label: THE_LOST_BOYS
Timestamp: 2022-07-19 14:05:46
Protection: AACS2.0/C v76
Data capacity: 56.86 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Re: Anyone got a key for THE LOST BOYS UHD?
Make it so that your system can download the key file, and then it can hopefully decode the disk.
grazstarr
Post by grazstarr »
Thank you! Yeah worked out I was using a library wifi. Cheers!
