Eggman
Re: SDFtool Flasher
Post by Eggman » Tue Sep 06, 2022 1:08 pm
That's actually very helpful.
SomeUsername
Re: SDFtool Flasher
Post by SomeUsername » Thu Sep 15, 2022 6:13 am
Tool doesn't work for me with a newly bought BU40N Revision: 1.04
Installed the latest MakeMKV version, selected drive and image HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Click start an nothing happens :?
FringeEvent
Re: SDFtool Flasher
Post by FringeEvent » Fri Sep 16, 2022 11:17 pm
Real big thanks! I was a bit hesitant about doing this, but it was literally about 5 minutes of checking things out, 2 downloads, and 2 clicks. Now all is good! Thanks again!
Holler
Re: SDFtool Flasher
Post by Holler » Mon Sep 26, 2022 5:32 pm
Hello, i have a HITACHI-LG BH16NS55 and it works realy fine for a long time. Now it seems the LG ODD Auto Firmware Updater has updatet the optical Drive to a BH16NS40 what is wrong of course. Now i can not flash it to a other Firmware and the SDFtool Flasher (the old Version and 1.3.4 ) shows no Drive to select to flash it again but under "Device Manager" he shows the wrong BH16NS40. What can i do?
Re: SDFtool Flasher
Post by Coopervid » Tue Sep 27, 2022 11:48 am
Holler wrote: Mon Sep 26, 2022 5:32 pm Hello, i have a HITACHI-LG BH16NS55 and it works realy fine for a long time. Now it seems the LG ODD Auto Firmware Updater has updatet the optical Drive to a BH16NS40 what is wrong of course. Now i can not flash it to a other Firmware and the SDFtool Flasher (the old Version and 1.3.4 ) shows no Drive to select to flash it again but under "Device Manager" he shows the wrong BH16NS40. What can i do?
See here. Scroll down to "Troubleshooting".
viewtopic.php?f=16&t=19634
Xeth84
Re: SDFtool Flasher
Post by Xeth84 » Mon Oct 03, 2022 3:48 pm
I just got a BP60NB10 and flashed with ease the 1.02mk firmware with the SDFtool. Makemkv says that the drive is patched and can read all the formats. It ripped an 3D Blu-ray perfectly. I have tried to rip 3 separate UHD discs to have them all fail at just over 20GB. I have been looking around the forum for answers. I saw one post that says if it's an NB12 drive or downgrade the firmware to 1.00mk. Done, and it still failed. It is plugged into USB 3.0 ports on the motherboard, and I am running makemkv as an administrator... failed. What am I missing?
Re: SDFtool Flasher
Post by Coopervid » Mon Oct 03, 2022 6:39 pm
Please post your Makemkv info.
As a first use another USB port or use an external hub with separate power supply as your drive could lack power from that USB port.
Xeth84
Re: SDFtool Flasher
Post by Xeth84 » Mon Oct 03, 2022 8:34 pm
Coopervid wrote: Mon Oct 03, 2022 6:39 pm Please post your Makemkv info.
OS device name: G:
Product: BD -RE BP60NB 10
Revision: 1.02
Firmware date: 2120-05-07 09:35
Highest AACS version: 76
Drive platform: MT 1959
Firmware version: 1.02
This is the error after ripping around 20 GB on 3 separate UHD Discs:
Error "Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00070.m2ts' at offset '7636383744'
Error 'OS error - STATUS DEVICE DATA ERROR' occurred while reading "Device \CdRom0' at offset '7636383744'
I have tried different USB ports, and for a second attempt on the 3rd disc, I made tried USB 3.0 ports on the motherboard.
Re: SDFtool Flasher
Post by Coopervid » Mon Oct 03, 2022 9:12 pm
First clean your disc as good as possible with liquid soap and warm water. Then try again.
Xeth84
Re: SDFtool Flasher
Post by Xeth84 » Tue Oct 04, 2022 2:08 pm
Coopervid wrote: Mon Oct 03, 2022 9:12 pm First clean your disc as good as possible with liquid soap and warm water. Then try again.
Wow! I really had to clean the discs. I thought I had kept my discs nice, but the littlest thing made it fail. It is very sensitive. I got it to work with a scrub down.
ancient
Re: SDFtool Flasher
Post by ancient » Wed Oct 05, 2022 6:48 pm
Hi Marty
Just a heads up.... the tool view is also deformed on a 1080p screen, so had to change the dpi option.
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Oct 05, 2022 11:42 pm
ancient wrote: Wed Oct 05, 2022 6:48 pm Hi Marty
That's a first!!
dg1218
Re: SDFtool Flasher
Post by dg1218 » Fri Oct 14, 2022 2:01 am
I've followed the instructions and haven't be able to change the firmware on my LG BP50NB40 NB52 Blu-ray writer.
Below is the device info if that helps. Thanks in advance for any help
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM2121V95240
Firmware version: 1.03
Re: SDFtool Flasher
Post by Coopervid » Fri Oct 14, 2022 10:18 am
dg1218 wrote: Fri Oct 14, 2022 2:01 am I've followed the instructions and haven't be able to change the firmware on my LG BP50NB40 NB52 Blu-ray writer.
Revision: 1.03
Did you read that and follow it?
BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
NB52 to > BP50NB40-NB50-1.03MK with enc > BP50NB40-NB50-1.03MK with bootloader/full flash > BP60NB10 1.00_HBD
dg1218
Re: SDFtool Flasher
Post by dg1218 » Fri Oct 14, 2022 12:40 pm
I've tried this one first using the new SDFtool Flasher 1.37 and using the old SDFtool Flasher
Then I tried both ways
Each time the flasher says complete no errors, but the firmware version makemkv show never changes. I've also been running the SDFtool Flasher as admin. The drive still reads blueray disk as normal. I've tried about 4 Uhd bluerays with no luck. I got the MK bin files from this link at the beginning of this post. Not really sure what I'm doing incorrectly
