#7531 Post by RESET_9999 » Fri Sep 30, 2022 6:59 pm
Manixx2020beyound wrote:
Fri Sep 30, 2022 1:29 pm
When using dee to encode hevc, how can we tell if forward reshaping has taken place what are the signs in the meta/Rpu to look for??
I assume if the adaptive reshaping flag is present/true it’s included in my meta can anyone answer??
@quietvoid correct me if i'm wrong..
The metadata here will always be the same when the reshaping is static like the Resolve P5 encodes ( itunes encodes too)
 "num_pivots_minus_2": [
      7,
      0,
      0
    "pred_pivot_value": [
        0,
        23,
        36,
        150,
        256,
        256,
        228,
        62,
        8
        0,
        1023
        0,
        1023
    "nlq_method_idc": null,
    "nlq_num_pivots_minus2": null,
    "nlq_pred_pivot_value": null,
    "num_x_partitions_minus1": 0,
    "num_y_partitions_minus1": 0
  "rpu_data_mapping": {
    "mapping_idc": [
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0
        0
        0
    "mapping_param_pred_flag": [
        false,
        false,
        false,
        false,
        false,
        false,
        false,
        false
        false
        false
    "num_mapping_param_predictors": [
        0,
        0,
        0,
        0,
        0,
        0,
        0,
        0
        0
        0
    "diff_pred_part_idx_mapping_minus1": [
    "poly_order_minus1": [
        1,
        1,
        1,
        1,
        1,
        1,
        1,
        1
        0
        0
    "linear_interp_flag": [
        false
        false
    "pred_linear_interp_value_int": [
    "pred_linear_interp_value": [
    "poly_coef_int": [
          -1,
          1,
          -5
          0,
          0,
          -4
          0,
          0,
          -1
          0,
          0,
          -1
          0,
          0,
          -1
          0,
          0,
          -1
          0,
          -2,
          0
          0,
          -2,
          0
          0,
          0
          0,
          0
    "poly_coef": [
          8387646,
          1593755,
          1132588
          55607,
          7100422,
          7114140
          135032,
          4423242,
          5240903
          207340,
          3656369,
          7325448
          300892,
          3196725,
          7892448
          468805,
          2716159,
          8237833
          6272571,
          6847591,
          6739653
          5742186,
          7559493,
          6564664
          1171714,
          6227579
          1058298,
          6211389
    "mmr_order_minus1": [
    "mmr_constant_int": [
    "mmr_constant": [
    "mmr_coef_int": [
    "mmr_coef": [
Gatorman
#7532 Post by Gatorman » Fri Sep 30, 2022 8:53 pm
Is this normal when using EAE?
Screenshot (711).png (36.24 KiB) Viewed 12731 times
More reasons to collect physical media. Ugoos AM6B+.
#7533 Post by RESET_9999 » Fri Sep 30, 2022 9:06 pm
yes, I don't know why...
The EC3 file seems ok, I watched 1 or 2 movies and had no issues.
Gatorman
#7534 Post by Gatorman » Fri Sep 30, 2022 9:45 pm
RESET_9999 wrote:
Thu Sep 29, 2022 11:05 am
I'll look into adding an AAC 7.1 workflow but my only problem is that the LG TVs only support 5.1 channels with AAC tracks.
https://drive.google.com/file/d/10VPaqP ... sp=sharing
If you haven't seen it, you can use the qaac encoder from iTunes to get True Variable Bitrate AAC files.
-Cheers
legosoff
#7535 Post by legosoff » Sat Oct 01, 2022 8:39 am
-Cheers
QAAC a lot of losses, better ffmpeg aac high bitrate 7.1 channels little with losses.
Gatorman
#7536 Post by Gatorman » Sat Oct 01, 2022 3:32 pm
That's fair.
legosoff
#7537 Post by legosoff » Mon Oct 03, 2022 10:04 am
Hi, RESET_9999! I wanted you to do 7/4/2, 7/4/3, 7/4/4 and 7/4/5 command mode save y and n. I need to save RPU.
#7538 Post by RESET_9999 » Mon Oct 03, 2022 11:17 am
these workflows convert/inject without extracting the rpu so I won't do that since it would make the already long process much longer.
You can use 2-2 to extract the rpu of any file.
legosoff
#7539 Post by legosoff » Mon Oct 03, 2022 11:48 am
Yes, I already had a 2/2 he green screen. 7/4/2 RPU excellent screen.
#7540 Post by RESET_9999 » Mon Oct 03, 2022 12:02 pm
what? 2-2 is an extractor/reader mode...
legosoff
#7541 Post by legosoff » Mon Oct 03, 2022 1:31 pm
Yes 2-2 green screen. Okay, I checked again after I'll let you know.
duder
#7542 Post by duder » Mon Oct 03, 2022 1:44 pm
There is a rip mkv video file with following specs: dvhe.08.06, BL+RPU, 3 840*1 600, 23.976 FPS
After muxing it with tsMuxer or with RESET_9999’s DoVi Scripts (infinite gratitude)) 800m2 gives grey bars and 1080p60 signal.
Panasonic tv internal player stretches the image vertically removing black bars and lengthen object on the screen.
Checked with m2ts or mp4 containers.
Is there a way to solve this issues?
#7543 Post by RESET_9999 » Mon Oct 03, 2022 2:10 pm
I'm talking about 2-2... not 7-2-2 or whatever mp4muxer workflow you tried....
please stop with that. you seem confused about what DV profile your input files are.
#7544 Post by RESET_9999 » Mon Oct 03, 2022 2:11 pm
Cropped video(black bars were not encoded in the video).
On the x800m2, there is no solution and it sounds like your TV cant play cropped content properly as well.
datman
#7545 Post by datman » Mon Oct 03, 2022 5:25 pm
I recently bought a sony 77a80j set and now I can get DV. I see none of my MKV files will display in DV, I guess I now recall that limitation at the time was no concern. Buried in this thread are there simplified steps to make new backups or is this still very much a bit complicated.
Something else I discovered what I thought was caused by an update to my Oppo 203 player a few years ago. My MKV Dolby Atmos backups no longer displayed Atmos only multichannel+ dolby. The DTSX remain normal. As far as I can tell the sound is the same. So figuring out DV and playing the original discs both issues go away.
